LG display Problem on thin-itx system.
seb87
Trento ITA
A few days ago I took a thin itx system, which is an all in one with the ability to upgrade components.
My model is an LG-BC 22AM33NB got it used but guaranteed from Amazon.de
once installed the various components, once lit, colorful vertical lines appear.
detachment if the connectors between the display and motherboard interior and connect an external monitor output dvi your pc runs normally, then the problem is in the display.
Being properly fed I think the problem lies in the data connection between the motherboard and the display, you think you can fix it somehow?
here is the screen.
could also be a problem with the inverter or only data connection between the card and the display?
You could try changing the capacitors inside if you don't want to return it. They are most likely to fail after a while.
