Neue XP-Chipsätze für 400FSB
Moose
(fast noch) Hamburg
quote an :
VIA KT600, SiS SiS748 ready for upcoming 400MHz FSB Athlon XP
Charles Chou, Taipei; Christy Lee, DigiTimes.com [Wednesday 19 March 2003]
VIA Technologies and Silicon Integrated Systems (SiS) are poised to support the new 400MHz FSB (front-side bus) Barton-core processors from Advanced Micro Devices (AMD) with their respective KT600 and SiS748 chipsets.
Following the recent launch of its K7-based KT400A chipset, VIA is planning to release one more product, the KT600, for the AMD platform in May. According to sources, the KT600 (codenamed KT400A-CE) is pin-to-pin compatible with the KT400A (codenamed KT400A-CD), but is designed to support a 400MHz FSB. The KT400A only supports a 333MHz FSB.
SiS recently debuted its SiS748 for the upcoming Athlon XP processor at CeBIT Hannover.
With the new offerings, both companies are expected to be more competitive in the high-end sector against Nvidia, whose nForce2 chipset has been gaining popularity due to its strong price/performance ratio. According to motherboard sources, monthly shipments of nForce2 chipsets are likely to have exceeded 500,000 units.
Hoping to compete with Intel’s upcoming Springdale products before it launches the K8-core Athlon 64, AMD recently announced that it would add one more processor version to its desktop-use Athlon XP line. Based on the Barton core, the new Athlon XP 3200+ features an L2 cache memory of 512KB and 400MHz FSB, and it may be launched in April at the earliest
quote aus, Frage an :
Ist das nun die offizielle Bestätigung, das die neuen XPs einen 400er FSB haben werden ?
wenn man davon ausgeht, ja.......
aber was bringts
wenn AMD vor demm A64 nochmal einen XP nachschiebt, wäre das eher ein Armutszeugniss
Wieso wäre das ein Armutszeugniss :hmm: Ist doch nicht schlecht, nur das dann der Athlon 64 ausser den 64-Bit nichts neues bringt :p
Ich finds garnicht mal schlecht, das sich da was tut. Aber notwendig ist es eigentlich nur für die OEM Branche, da wir hier eigentlich fast alle mit knapp um die 200Mhz FSB fahren.
Naja, mal schauen was kommt ...
weil sie den A64 schon seit ewig ankündigen und ihn nicht bringen und immer "nur" verbesserte XPs nachschieben...
Nein, ist es nicht.
AMD hat kürzlich Gerüchte um FSB400 dementiert. Die neuen sollen vorerst ohne kommen.
Zudem: Wann sollen diese Chipsätze kommen? In 2 Monaten? Dann ist bereits Juni und im September kommt der Athlon 64.
Sich jetzt noch ein Board zu kaufen, das FSB400 bringt, damit nochmal 2% mehr drin sind bringt nicht mehr viel.
cu
Loores
@Wome
Ja schon, aber gerade beim nForce2 soll das nicht jeder können - und das ist ja jetzt der interessanteste Chipsatz.
cu
loores
