[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Da sieht man mal wie alt der Witz ist... :d
Und wie spiele ich es dann abends gemütlich im Bett? Ist immerhin der einzige Vorteil der Switch.
ich hatte früher auch gameboys aber ich kann mir beim besten willen nicht vorstellen da 2 stunden so ein fettes ding in der hand halten zu müssen.
pc an tv anschließen. ist halt nur machbar wenn der pc im gleichen zimmer ist oder du 2 pcs hast :fresse:
breath of the wild läuft mitlerweile besser als starfield
totk ist noch etwas holprig.
Für Jedi Survivor gibt es einen neuen Patch und es gibt jetzt auch DLSS Unterstützung inkl. Frame Generation:
Zocke gerade schon etwa 30 Minuten und es läuft auch vom Stuttering jetzt deutlich runder. Zumindest so mein bisheriger Ersteindruck in 4K Epic mit RT und DLSS Quality ohne FG. Wenn es so bleibt und die Crashes auch gefixt sind ist es doch tatsächlich spielbar :fresse:
R24 frisst einen Haufen GB auf c:\ - musste erst mal Platz machen...
37.000 Punkte müsste Jeder mit 4090 schaffen
Wie überaus geil, freut mich sehr 👌
Aber jetzt muss erst mal Zelda zu Ende gespielt werden, dass ist der Weg.
Bestätigt mal wieder, EA Games nicht zocken bevor sie ihren Mist patchen. Läuft es denn gut?
Es gibt immer noch Traversal Stuttering hin und wieder aber es ist besser als vor dem Patch. Liegt wohl daran, dass es kein Shader Compilation Stutter mehr gibt bzw hab ich bisher nichts festgestellt. Vorher hatte man nach einer Treiberinstallation immer einen Stutter z.B. wenn man das Lichtschwert gezogen hat. Das ist jetzt weg. Die initiale Kompilierung dauert jetzt auch länger glaube ich. Da scheint was passiert zu sein obwohl nix spezifisches in den Patchnotes steht. Nicht wirklich perfekt aber kann man so spielen. Denke besser wird´s nicht mehr. Ist jetzt ungefähr auf Fallen Order Niveau :fresse:
DLSS sieht ganz gut aus, etwas besser als FSR 2 würde ich sagen, so wie man es mittlerweile kennt. Habe aber auch nur mal kurz hin und her geschaltet. Frame Generation hat aber eine Menge Ghosting und teils deutliche Grafikfehler. Habe da schon deutlich bessere Implementierungen gesehen. Kann man zur Not aber bestimmt trotzdem nutzen, die 4090 bringt mit DLSS Qualität aber genug Frames für meinen Geschmack.
Kurz noch ein Nachtrag: Damit DLSS Super Resolution funktioniert muss man wohl die 3.5.0 Version einfügen. Ansonsten sind alle DLSS Presets einfach DLAA bei nativer Auflösung und dementsprechend ohne Performancegewinn. Ich hatte das direkt anfangs gemacht, daher nicht gemerkt. Und für Frame Generation muss man ein Downgrade machen, damit es weniger Artefakte gibt. Wtf Respawn :fresse:
Gleich ihr das die Preise der 4080 bis Weihnachten noch großartig fallen werden?
Es ist der erste Thread ganz oben bei den Rollenspielen…
Du bist aber auch eine selten faule Sau @****** 😏
Hmm, ich habe mir gestern von Nexus Mod die DLSS 3.5 gezogen und in den Starfield-Ordner gepackt. Anschließend die zweite empfohlene Datei gezogen und ebenfalls neben die exe im Starfield-Ordner gepackt.
In den Einstellungen sehe ich aber nach wie vor nur CAS und FSR2.
Hat wohl nicht geklappt?
Wo ist denn hier der Starfield-Thread?
Ich bezog mich auf Jedi Survivor und nicht Starfield :fresse: Im Bezug auf Starfield: DLSS erscheint durch die Mod nicht im Einstellungsmenü. Du musst da FSR2 anlassen und wenn du die Mod richtig installiert hast kannst du über die "Ende" Taste das Menü dazu aufrufen. DLSS ersetzt FSR in dem Fall, deswegen muss es aktiv sein.
Irgendwo kann ich MSI zwar verstehen, aber bissel shady find ichs trotzdem...
Das ist das was ich euch mal von Gigabyte berichtet habe. Als die ganze Story mit den schmelzenden Adaptern aufkam habe ich sie gefragt was im Falle eines Falles abgedeckt ist und was nicht und mir wurde damals bestätigt dass sie sich komplett rausnehmen wenn man was anderes als die 4 schwänzige Adapterpeitsche aus der Packung nutzt.
Die Leute haben es damals nicht glauben wollen, weil nVidias Statement war, dass sie und ihre Partner 12VHPWR Issues immer übernehmen. Jetzt ist der Fall da und es wird abgelehnt. Die AIBs waren nicht gemeint mit "Partners". Das hatte ich seinerzeit von nVidia schon auf Nachfrage erklärt bekommen.
Es erschreckt mich allerdings, dass auch MSI den Gigabyte Weg geht. Von Asus habe ich auch schon sowas gelesen. Was soll man da in Zukunft noch kaufen? Nur noch FEs von nVidia direkt?
LoL, einfach die Karte, die Du haben möchtest? Cablemod hat doch nun zig Beispiele geliefert, wo deren Produkte an einer Schmelzaktion beteiligt waren. Gab es ein Beispiel mit einem Seasonic oder Bequiet Kabel? Cablemod will den schwarzen Peter schön wegschieben aber am Ende haben sie einfach Scheisse gebaut, auch mit ihrem Adapter.
Also Kabelpeitsche oder Netzteilherstellerkabel nutzen und gut is.
Naja. Die Ableitung ist ja, dass die Ablehnung auch käme, wenn dir das (warum auch immer) mit einem Netzteilherstellerkabel passiert. Da hätte früher keiner einen Gedanken verschwendet weils einfach nur Kabel sind.
Wieso sie Garantieren die Verwenung mit ihrem Adapter, wenn dir ein Bequiet Netzteil deine Karte schmilzt ist auch Bequiet schuld.
In dem Fall hat halt Cablemod scheiße gebaut und müsste für den Schaden herhalten, aber das wollen sie natürlich nicht.
Bisschen Bammel habe ich auch, deshalb habe ich das originale Seasonic 2x 8PIN auf 12VHPWR gekauft, damit das Kabel nicht geknickt wird noch den Thermal Grizzly Wireview dazwischen.
So sollte eigentlich nix passieren oder? Also mal schön fast 100€ in Kabel investiert, nur weil Nvidia sich einen neuen Stecker eingebildet hat :fresse:
