[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann Jemand mal den Sound von der Gainward unter Last aufnehmen? Auch andere Karten würden mich interessieren!
Ja aber laut den Tests soll das PL kaum eine Rolle spielen! Mir gefällt die Suprim X auch, da ich mit der 3090 Ti Vatiante schon zufrieden bin und in den Benchmarks ist kaum ein Unterschied zwischen den Taktstufen zu sehen. Ob die Karte nun mit 2800 oder 3000 läuft macht in FPS Zahlen wenig aus. Aber mal sehen, was es am Ende wird :d!
Ja, solange VGPU limitiert...
Bin gespannt, wann "elmor" mit Infos rausrückt und wie hoch mal volten kann
Ich finde aber der Begriff ist ziemlich passend in der Hardware community. 99% der Leute die eine 4090 bestellen benötigen diese nicht
"Natürlich kaufe ich die beste 4090, auch wenn ich sie nicht brauche, soll ja schließlich keiner denken, ich könne sie mir nicht erlauben ..." :d
Meine Güte, wenn man es nicht mit eigenen Augen gesehen und mit den eigenen Armen gespürt hat, glaubt man es nicht wie massig die Teile sind .... :d :d
Das versuche ich den Frauen auch immer zu erklären....
Gibt es da Besonderheiten im Gegensatz zu zu FAG + PP?
PP nach 30 Tagen wird auch immer gern genommen. :d
Aber wenn es die Möglichkeit gibt, dann sollte man davon Gebrauch machen.
Dann hat man erst mal genug Zeit die Karte zu testen, ohne beim Verkäufer seine sauer verdienten Brötchen zu parken.
Hat jemand noch dieses Problem mit einer Asus-Karte? Rotes Licht bei ausgeschaltetem PC an der Karte.
Alles richtig angeschlossen. Karte läuft auch gut, weiß nicht was das soll...
"Ob sie geht oder nicht, sagt dir gleich das Licht" (Michael Schanze) :d
Naja was benötigt man schon. Da reicht meist ne 3060ti oder 3080 maximal. Man braucht kein 200ps Motorrad oder 300Ps Auto. Man braucht keinen 77zoll TV oder einen Luxus Urlaub. Aber wenn man es sich leisten kann und Spaß hat warum nicht.
Man muss ja heutzutage nicht alles nur noch ernst und schlimm sehen.
Meine ROG Strix 4090 geht zurück zu Alternate, das Spulenfiepen ist extrem. Kenne ich von meiner 3090 nur wenn ich vergesse ein Limit zu setzen und die FPS über 1000 gehen teils in Menüs. Bei der 4090 habe ich schon bei unter 50FPS in Cyberpunk gestern dieses Fiepen gehabt. Ich sitze 1,5 Meter weg vom geschlossenen PC, aber das Fiepen ist lauter als die Lüfter und die Pumpe der WaKü. Egal was man spielt und mit welchen FPS auch immer das Fiepen ist dominant da. Je mehr FPS um so lauter. Und das Fiepen ändert sich auch zwischendurch je nachdem was man gerade auf dem Monitor sieht. Mein Monitor geht bis 240FPS hoch. Das kann so nicht normal sein und wenn doch habe ich ein großes Problem mit der 4090er Generation. Alle Versuche mit Settings habe nichts geändert am Fiepen. Wäre cool man könnte solche Karten irgendwie vorgetestet kaufen mit der Angabe kein Spulenfiepen oder mit der Angabe ab welcher FPS Zahl es einsetzt.
Moin zusammen!
Heute wird meine 4090 FE geliefert. Da ich mit so einem Monster zuvor noch nie hantiert habe, bin ich nun ziemlich verunsichert, wie ich die Karte an das Netzteil anschließen muss.
Ich habe ein Corsair RM750x. Ich werde die Karte zunächst mit 70% PL betreiben, da ich das Netzteil erst aufrüsten möchte, wenn ATX 3.0 so richtig am Markt angekommen ist - falls das überhaupt erforderlich sein wird.
Ist es richtig, dass ich das mitgelieferte Kabel der 4090 FE einfach direkt an das Netzteil anschließe und zwar an die eingerahmten Anschlüsse? Oder benötige ich noch Kabel von meinem Netzteil, die ich zunächst mit dem Kabel verbinden muss? Ich möchte nichts falsch machen. :)
PS: Ich habe hier schon ewig mitgelesen, mich aber heute endlich angemeldet. Also an dieser Stell noch ein "Hey! :)" von mir.
Ich weiss nicht ob Deine Frage schon beantwortet wurde aber das mitgelieferte Kabel ist meines Wissens nur ein Adapter, für den Du mindestens 3x 8-Pin von Deinem Netzteil brauchts, besser natürlich 4x 8-Pin.
Wenn Deine CPU mit 1x8-Pin auskommt, dann wären es die drei verbleibenden Buchsen die Du rot umrandet hast. Wenn Deine CPU 2x 8-pin braucht, dann hast Du ein Problem.
1x 8 pin hat 150 watt laut spezifikation .... klar kannst do dort auch 1 kw durchjagen ...aber eben nur kurz. über was reden wir hier, dass leute nicht wahrhaben wollen, dass man sein billo PSU nicht an ne 2000 euro grafikkarte hängen sollte ?
Die Spezifikation bezieht sich auf die Steckerseite und das was eine Grafikkarte über einen Anschluss abrufen darf, auf der Netzeilseite ist es aber nicht spezifiziert, da kann jeder Herstellerin gewissem Rahmen machen was er will. Denn die Spezifikation sagt nur was über die Zuleitung und den Stecker aus und weiss nichts von modularen Netzteilen, sie ist so definiert als wären das alles feste Stränge zum Netzteil. Deswegen kann Corsair für ihre 8-pin Buchsen und Kabel durchaus auch 300W freigeben, weil sie auf der Seite die Kontrolle haben was sie da genau verbaut haben. Nur darf man das keinesfalls einfach auf andere Herstller übertragen, auch deswegen kann man nicht einfach Kabel von einem anderen Netzteil nehmen, weil auf der Netzteilseite eben jeder Hersteller sein eigenes Süppchen kocht.
Und deswegen stimme ich Deinen Warnungen auch grundsätzlich zu, weil ich hier viel zu viel "alles geht kein Problem, ist bisher auch nix passiert" im Forum lese, ohne das die Leute wissen wo es Reserven gibt und wo nicht.
so einfach mal lesen .... 1 - 8PIN hat eine SPEZIFIKATION von 150 !!!!! WATT NICHT MEHR NICHT WENIGER
2 x 8 pin 300 watt ..... und so weiter .... ohne worte das hier einige diese tatsache klein oder wegreden wollen
Auch hier wieder, Steckerseite, die Spezifikation weiss nichts von modularen Netzteilen und deckt nicht ab, was der Hersteller an seiner Seite des Kabels macht. Am Netzteil könnte er auch eine 15-pol Buchse erfinden und auf 8-pin am Stecker zusammenführen, solange an der Grafikkarte ein 8-pin mit 150W ankommt ist der Spezifikation genüge getan. Ich habe den Eindruck für viele sind die modularen Netzteile schon so selbstverständlich, daß sie vergessen das es früher nicht so war, da gab es keine netzteilseitigen Buchsen.
ohman... offiziell 150 watt !!! wenn ein ingeneur von irgend ner firma sagt, dass da mehr durch kann ist das seine persöhnliche meinung und das gilt vielleicht für corsair (intern) aber eben nicht für sharkoon oder china mist ....die werden ihren kram so bauen, dass dort die offizielle spezifikation von 150 watt (dauerleistung) anliegt .... wenn corsair meint hier mehr bereitzustellen ist das so aber eben nur inoffiziell .... du kannst auch ein komplettes haus mit einer stromleitung versorgen .... das entspricht nur leider keinerlei VDE NORM !!!!!!! gehen tut es .... punkt verstanden ? das risiko liegt dann eben bei EINEM SELBST !!!!
Die VDE-Norm hat nichts mit der PCIe Spezifikation zu tun. Die häufig verwendeten Molex Mini-Fits sind in der Lage 9A bei 12V pro Kontakt zu verarbeiten bei AWG16, das sind bei 3 Kontakten dann 324W die ein einzelner Stecker transferieren kann ohne zu schmelzen oder die Betreibssicherheit zu gefährden. Manche Modelle können sogar von bis zu 13A pro Kontakt bei AWG16. Kann man alles bei Molex nachlesen. Diese Molex-Verbinder sind nicht PCIe exklusiv, sie werden für alle möglichen Arten von elektischer Verkabelung verwendet, auch außerhalb des PC Bereichs. Die PCIe Norm schreibt wie gesagt nur vor, daß der Stecker 150W an der Grafikkarte anliefern können muss, wenn der Hersteller tiefer in die Tasche greift und bessere Terinals auf seiner Seite verbaut und gute Kabel liefert, dann kann man locker auch 300W durch einen 8-pol netzteilseitig leiten. Aber diese Aussage kann eben nur der jeweilige Hersteller für sich selber treffen, keinesfalls ist das auf andere Hersteller übertragbar und nur weil Corsair sagt das geht bei uns heißt das noch lange nicht, daß es bei Sharkoon auch geht. In dem Punkt stimme ich Dir völlig zu.
weil corsair hier lügt und sich ausserhalb der spezifikation bewegt.... evtl haben die aber hier wesentlich dickere querschnitte in ihren kabeln UND ihren netzteilen, und die RAILS sind so ausgelegt, dass über 1 8 PIN 300 watt dauerhaft gehen. das garantiert dann aber nur corsair so ..und gilt sicherlich nicht für alle anderen ...
ich würde dieses Kabel NIE verwenden,
Corsair "lügt" hier nicht (vorsichtig mit dem Wort, es ist justitiabel und Corsair könnte Dir da an den Karren fahren) und sie bewegen sich auch nicht außerhalb der Spezifikation, solange am versorgen Gerät (hier Grafikkarte) die Leistung ankommt die von der PCIe Norm vorgeschrieben wird. Corsair macht wohl genau das was Du beschrieben hast, hochwertigere Molex Mini-Fits und dickere Kabel verwenden. Dann ist es sehr wohl erlaubt. Zudem verkauft Corsair diese Kabel offiziell und hat auch genau spezifiziert, mit welchen Netzteil-Leistungen diese Kabel an ihren Netzteilen verwendet werden dürfen. Hält man sich an all diese Bedingungen, dann unterliegt Corsair auch der Produkthaftung, was bedeutet wenn Du es wie von Corsair angegeben anschließt und Dir brennt die Bude ab, dann haftet Corsair dafür. Das sind keine "Benutzung auf eigene Gefahr" Kabel hier. Aber wiederum darf man das nicht einfach auf andere Hersteller übertragen. Jeder Netzteilhersteller muss eigene Kabel und eigene Spezifikationen bereitstellen und man sollte keinesfalls Spezifikationen von einem Hersteller einfach auf den anderen übertragen, das ist gefährlich. Auch bei Custom-made Kabeln die man kaufen kann bleibt ein Risiko, ob das Szenario in dem man es einsetzen will, auch wirklich so garantiert wurde.
Ich muss aber auch einräumen, daß eine 3x8-pin oder gar ein 4x8-pin auf 12+4Pin Umsetzung statt der 2x8-pin mit auch lieber gewesen wäre, einfach weil ich immer gerne Reserven habe. Aber elektrisch ist es zumindest bei Corsair kein Problem, eine Kühlung der Aschlussseite des Netzteils habe ich aber trotzdem sicherheitshalber.
Hat jmd. schon New World mit seiner 4090 ausprobiert? :d
Oh man das klingt echt deprimierend. Wäre es möglich, dass verschiedene Karten des selben Modells unterschiedlich stark fiepen? Oder ist das dann bei allen Strix so?
Alle 3090, die ich hatte (insgesamt 6) habe ich selbst behalten oder weiterverkauft bzw. ungeöffnet (versiegelt) zurückgeschickt ;)
Aber liege ich richtig, dass das Geld nach einem Storno sofort wieder bei PP ist, insofern ich Guthaben dort hatte?
Wenn das Guthaben "0€) war, und man per PP bezahlt, bekommt der Verkäufer das Geld zugesichert (hat es aber noch nicht
Bei einem Storno muss man mehrere Tage warten. Daher vermute (hoffe ich), dass das Geld bei einem aufgeladenen PP-Konto sofort wieder da ist
Kann dazu jmd was sagen, wie schnell das geht?
genau das meine ich, das hat mir den Spaß genommen...
Ich will die Karte nicht testen einbauen um dann zu hören wie schlimm es ist, deswegen überlege ich ob ich die Karte ungeöffnet zurück schicke ;(
meist innerhalb einiger stunden
Bei ASUS muss man schon leider von großem Glück sprechen, wenn eine mal ruhig ist. Deshalb war ASUS bei der 40er GEN genau wie die FEs keine Option für mich.
Bei der 30er Gen hatte ich mehrere Strixx und TUFs da, die große Mehrheit war zumindest für unter Wakü aus meiner Sicht unerträglich.
Es gibt aber auch Leute die immer wieder behaupten Ihre wäre ruhig, so auch ein Kumpel von mir. Als ich das Vorort mir dann anhören wollte, hab ich das Coil-Whine fast schon an der Haustür (stark übertrieben) gehört. :ROFLMAO: Also die Wahrnehmung der Menschen ist da auch sehr sehr subjektiv.
Wenn ich das von Asus lese bin ich echt auf meine Gigabyte gespannt 🤭 sonst geht die auch zurück. Fiepen ist nicht meins.
Werde euch morgen oder abends berichten
Ähnliche Themen
