[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es kam auch stark auf die Titel an welche man zockte z.B. Gta war ganz schlimm und RDR2, die Racing Games gingen usw. Karte ging jetzt an den Sohn des Arbeitskollegen und der hört da gar nichts trotz Hinweis. Das eigene Empfinden entscheidet...wobei manche Karten echt crazy sind. Hatte mal ne 3090 FE, da drang das Surren beim gamen trotz größerer Lautstärke über die Kopfhörer mit ein. Das kann Dich wahnsinnig machen...
Hier übrigens mal mein Shipping-Status für den Adapter von Cablemod:
Was für ein Joke... Hohe Preise und hohe Lieferzeiten, die beste Kombination.
Für alle, die sich überlegen eine MSI Liquid X zu holen. Die gemessenen VRAM Temperaturen sind katastrophal!
Über 80 Grad Speicher sind jetzt also schon katastrophal? 😅
So, Gamerock OC vom Kollegen ist jetzt bei mir drin, ist ihm zu bunt :d
Der Kerl hatte zudem Glück bei einem 4090FE Drop
Die non OC geht dann in den Marktplatz bzw. zurück zu Alternate. Mal schauen wie die OC so performt.
Beste Grüße
Beste Grüße
Die Palit sind alle krum oder?
Nein quatsch, beide nicht Krumm bei mir.
Beste Grüße
Diese Aussage ist halt so einfach überhaupt nicht richtig.
Der Vorteil einer Wakü liegt zum einen darin, dass das Temperaturdelta zwischen zu kühlenden Komponenten und dem Kühlmedium (Kühlflüssigkeit) aufgrund des deutlich kleineren Wärmeübergangswiderstandes deutlich kleiner ist und weiterhin darin, dass der Wärmeübergang im Radiator an die Umgebungsluft aufgrund der dort möglichen deutlich größeren Fläche ebenfalls mit einem deutlich kleinerem Temperaturdelta klappt.
Aber egal, ob Wakü oder Lukü. Steht da ein Rechner, der 600W zieht, so werden diese 600W den Raum gleich stark aufheizen.
Davon ab disktutiert ihr gerade vermutlich einfach nur völlig aneinander vorbei.
@Tech Enthusiast
Los gings wohl mit der Aussage von @HisN ?
Kannst Dir sicher sein, das dieser nicht davon ausgeht, das sein Zimmer mit Wakü kühler bleibt als mit Lukü
Es war sicher eher so nach dem Motto: Sollte das Temperaturdelta der Wasserkühler nicht besonders niedrig sein, dann wirds mir im Winter eh nicht auffallen, da der Raum da ja kühler ist und das Temperaturniveau drückt. Spannend wirds dann im Sommer, weil da dann der Raum auch von außen her auf ein höheres Niveau aufgeheizt ist.
Doch das ist richtig, denn das Temperaturdelta zwischen Kühlflüssigkeit und Kühlkörper der GPU ist bei einer Wasserkühlung größer als bei einer Luftkühlung, was die Wärmeabfuhr verbessert, zudem hat Wasser eine deutlich bessere Wörmeleitfähigkeit und eine höhere spez. Wärmekapazität als Luft
Demnach kann es von einem Wasserblock auch wesentlich mehr Wärme abführen, als ein Luftkühler im Gehäuse das unter vergleichbaren Bedingungen könnte, wodurch die GPU und das Gehäuse insgesamt kühler bleiben und auch Last-Spitzen besser abgefangen werden
der Raum wird logischerweise schneller erwärmt als bei einer reinen Luftkühlung, trotzdem wird die Wasserkühlung auch bei steigender Umgebungstemperatur besser kühlen als ein Luftkühler, sodass man sich auch im Sommer keine Sorgen machen muss
Wird im Video ja gesagt, trotzdem ist es unakzeptabel, dass der VRAM so heiß wird und bei anderen Herstellern zwischen 60-70 Grad liegt. Im Sommer kann man dann je nach Raumtemperatur nochmal einige Grad draufrechnen. Für mich ein absolutes K.O. Kriterium bei der Auswahl der Karte, was ich so von der Liquid X nicht erwartet hätte, sollten andere User, welche die Karte besitzen, die Temperaturen bestätigen.
Beste Grüße
Aber eine Karte mit MP anzubieten, heißt nicht, dass man sie zum Selbstkostenpreis abgiebt :P
Ich bin gespannt, wie weit die OC Version geht bei dir. Heute und Morgen kommen nochmal ein paar Karten. Hoffentlich eine OC Perle dabei :)
Trotzdem will man den ja nicht bei der Temperatur betreiben, so wie man eine CPU auch nicht bei 95 Grad betreiben möchte
Bei den AIO Blöcken die gesehen habe wird die Rückseite der Karte gar nicht direkt per Wasser gekühlt, sondern hauptsächlich der GPU Chip selbst, dafür würde ich nicht den dicken Aufpreis zahlen den diese Karten kosten
Ich hoffe ja auch eher auf ein Tauschangebot, bzw. bevorzuge ich es. ;)
Beste Grüße
  • Danke
Reaktionen: SH
Beste Grüße
Das tut weh, scheint ein Ausreißer von mir gewesen zu sein. die Bananenkarte. Aber hätte ich sie nicht zurück geschickt, hätte ich den link für die 4090FE nicht erhalten. Beim einsetzen meiner alten 3090. :)
Ja, @Queue, deine war schon abnormal. Das ist aber auf keinen Fall der Standard.
Beste Grüße
Beste Grüße
Jou, die hat ja auch gut performt, ohne overclock, hatte die ~2750. Bei ~430 Watt. Meine FE geht runter auf 26xx aber mit viel weniger Watt. Brauch für ähnliche Leistung auf alle Fälle weniger Watt.
Bei Amazon gibt es noch eine TUF 4090 für 2727 €.
Für mein mini itx benötige ich leider eine Karte die passt.
Und leider kann ich die 4090 Strix oder TUF nicht nehmen.
Ich werde auch wieder von AMD auf Intel bei der CPU wechseln.
Der 13900K und das itx Board von Asus stehen auf meinem Wunschzettel.
Am liebsten hätte ich eine FE, aber da sind viele Scalper schneller als ich.
Schade, dass Nvidia nicht mehr selbst die FE Karten anbietet.
Zuletzt habe ich mir damalig die 2080 TI bei NVIDIA direkt gekauft.
Nunmehr ist so eine Berliner Schmiede dafür zuständig.
Hoffentlich ändert sich das bald wieder.
Verstehe ich auch nicht. Warum z.B. keine Vorbestellung mit hälftiger Anzahlung und halt dann etwas mehr Wartezeit...das kann doch nicht so schwer sein. Aber anscheinend doch😂
Scalper und Botuser würde ebenfalls bestellen
Ka ob das hilft.
Einzige was hilft wäre pro Perso 1x fe je modell
Ja gut, Du musst aber auch sehen, dass er die Karte in Cyberpunk in 4K mit (wahrscheinlich) Volllast und Stock laufen lässt. Die Spannung von 1.025V und der Verbrauch von ~440W deuten zumindest darauf hin. Wenn man die Karte sanft undervoltet und mit dem Verbrauch eher so bei 330-380W liegt, sieht die Sache schon wieder anders aus. Dafür ist die Karte halt schön leise und nimmt nicht viel Platz weg. Ich warte genau auf dieses Modell, da ich sie mir aus den genannten Gründen holen will.
Außerdem sind 86°C noch völlig im Rahmen. Ich hab dieses Jahr im Hochsommer unterm Dach Quake 2 RTX gezockt und hatte auf meinem Backplate-VRAM 102 °C bei meiner FTW3 3090 und es ist nichts passiert. Und wenn: Dafür hat man ja Garantie und bis die abgelaufen ist, ist schon wieder die nächste Karte im PC...
Ka ob das hilft.
Einzige was hilft wäre pro Perso 1x fe je modeml
Von mir aus Aushändigung nur mit Ausweis oder Abholung in Filiale. Wird trotzdem nicht viel helfen und Ebay KA wird bestückt...es ist wie es ist.
Gestern auch mal in Plague Tale 2 reingeschaut. 4k max Details mit DLSS 3 boostet die Karte bis 2820 Mhz ohne OC im Afterburner zu machen. Das ist doch schon nicht schlecht. Denke ich.
Direkt am Anfang (PT: Requiem) wenn man den Weg runter schaut in 5160x2160 mit DLSS + FG (ja ist ein Bild, wollte es schnell per Telegram wegschicken deshalb siehts auch so scheiße aus, aber ging schneller als ein Screenshot xD)
Was meiner Meinung nach viel ändern würde - wären die Shops, wenn endlich der Warenkorb für 2-3 Minuten gesperrt ist.
D.h. ist eine Karte im Korb - kann sie nicht mehr von jemand anderem gekauft werden.
Bei eventim ist es ja möglich. Dort ist sogar eine längere Zeit angegeben.
Es ist also möglich.
Bei Alternate geht es auch. Wenn man sie im Korb hat, kann man auch sicher bestellen.
Ähnliche Themen
