[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das Fiepen auf der GPU kann auch durch das Netzteil oder andere Komponenten kommen...aber pssst. :popcorn:
Verstehe nicht warum du mich zitiert hast. Ich bin diesbezüglich informiert. Oder willst du mir unterstellen das das fiepen noch kommt?
Ich schreibe was ich für richtig halte. Ich frage dich nicht um Erlaubnis. Sorry ;)
Warum verkrüppelt manchma die Curve?
also hinten raus?
ich hab die nicht mehr angetastet.
Ach da fällt mir noch eine wichtige Frage an die Experten ein!!!
Eine RTX 4090 soll vom 13900K sogar in 4K gebottleneckt werden, stimmt das??
Somit wären dann ja die bisher veröffentlichten Gaming Benchmarks über die absolute Leistungsfähigkeit einer RTX 4090 also nur bedingt aussagekräftig 🤔 ist da etwas dran!?
Hallo zusammen, ich klinke mich mal ein.
Ich konnte zuerst eine Strix ergattern, die ich aber schweren Herzens wieder zurück geschickt habe, da sie mich selbst bei 900mV noch angeschrien hat. Außerdem war sie selbst bei 2500Mhz im UV nicht stable. Nach oben gab es so gut wie gar keinen Spielraum. Selbst im Idle hat sie gerasselt. Das beste waren aber die Lüfter, die waren ein Traum, deswegen komme ich zum nächsten Problem:
Ich habe daraufhin die FE bei NBB bestellt und bin an sich total zufrieden. Nur eine Sache stört mich und ich glaube dass hier im Thread mal darüber berichtet wurde.
Der obere Lüfter bei normalem Einbau macht schon ab 30% Fan Speed komische Lager-/Motorgeräusche, die der untere nicht macht, der ist dagegen Flüsterleise. Man merkt es deutlich wenn man sie kurz anhält.
Bei NBB habe ich gefragt, ob es dazu irgendwelche Auffälligkeiten gibt. Die haben mir aber nur das Ret.Label zugeschickt :cautious:
Ich kann wenn nötig dazu auch mal ein Soundfile hochladen.
Aber erstmal die Frage an diejenigen, die eine FE haben/hatten ob das Normal ist. Wenn ja bau ich evtl auf WK um.
Möglich. Kommt aufs Spiel an.
Wofür ? Für das ehrliche Antworten auf eine Aussage und das völlig legitime Schreiben einer Sache ? Kannst auch gerne in einer PN antworten. Unverständlich.
Deine Meinung als Fakt darstellen und gezielt einen Streit mit einem anderen User vom Zaun brechen, weil dir die Meinung des anderen Users nicht passt.
Wenn sich hier nur gegenseitig angegiftet wird hilft das niemandem.
Danke!
Wüsstest du darauf evtl eine Antwort?
Unbeantwortete Frage von gestern abend:
Weiß einer von euch, wie gut eine RTX 4090 in Ai Video Enhancer Software ist, zB. Bei AVC Labs?
Zuletzt habe ich es mit meiner noch eingebauten RX 6900 XT LC getestet und um ein 20 minütiges gering aufgelöstes Video auf 1080p umzuwandeln, hat es locker 7-8 Stunden gedauert!! (CPU 5800X, 4 x 8GB 3600Mhz CL 14 RAM)
Ne ich meine damit TomCom... 8 mal dieselbe Karte, aber das Problem liegt woanders...
Das es auch Leute gibt die kein Fiepen haben, ist ein Zeichen dafür das vielleicht der PC Schuld ist und nicht die GPU.
Aber was soll er nun stattdessen machen? Die Teile des PCs sind ja bestimmt LAAANGE außerhalb des Widerrufes, also kann er nur neue Teile kaufen oder sich damit abfinden das er keine Strix nutzen kann.
Nur die Hoffung stirbt ja bekanntlich zuletzt...
Ich habe das Geräusch nur beim anlaufen und beim stoppen … aber ist bei mir sehr leise.
warum könnte das denn nicht sein? das ist nichts außergewöhnliches.
zwischen einem 13900k mit 0815 rams und schnellen und getunten rams liegt aber auch noch mal einiges
wenn in 4k die cpu trotzdem zu langsam ist, dann muss man das spiel eben rausnehmen und andere hernehmen in denen die cpu eben nicht vorher dicht macht.
Achso. Dann hättest du aber eigentlich ihn zitieren müssen.
Ja wurde eventuell nie in Betracht gezogen .
Möchte er doch auch nicht. Wenn er mit einer anderen Karte glücklich ist ist doch alles gut.
Aber was soll er nun stattdessen machen? Die Teile im des PCs sind ja bestimmt LAAANGE außerhalb des Widerrufes, also kann er nur neue Teile kaufen oder sich damit abfinden das er keine Strix nutzen kann.
Ich hab mehr als ein Netzteil hier sowie eben sehr viel Hardware … ich habe diese Entscheidungen nicht leichtfertig getroffen diese Karten zurück zu schicken. Ist kein Thema ich erkläre das ja … viele wissen ja auch das ich hier ziemlich viel Hardware kaufe die ich eben nicht zurückschicke!
habe meine TUF gerade mal freilauf gegeben
PT 100%. default clocks, Stray aufn desktop getappt. gpu war bei 100% load. fps cap ist glaube durchs raustabben nicht aktiv gewesen und die karte hast du im raum defintiv gehört weil High Load + High FPS :)
bei 70% wirds etwas dumpfer
bei meinen 118 fps cap ist es fast weg
Bei mir wird es langsam echt wild :stupid:
Es fing eines Tages alles mit der RTX 4090 TUF an. 1949€ konnte ich nicht widerstehen. Fuck. Naja was soll's ist einfach zu gut. Hm scheiße der dumme nividia Adapter wird im O11D XL zu stark geknickt -> Lian Li 4.0 Riser Card + PCI-Slot-Blende bevor die Bude abfackelt :fire:-> hm CPU Limit in CP 2077 -> Mist. :poop: Okay neuer Unterbau, Wie ersetzt man ein Z490 Formula standesgemäß? Bingo Z690 Formula :shot:, nice endlich ein PCI4.0 Board, muss man ja irgendwie ausnutzen. 2TB Seagate Firecuda 530. Nice. :love:Aber DDR5 nun Pflicht, ah Speicherpreise sind stark gefallen, da kann man ja auch gleich zu 32GB 6000 mit CL30 greifen :cool: Neue intel Gen geht ja ab. Okay 13700kf soll es sein, bisschen was einsparen, muss ja nicht gleich Flagship sein.. Hm aber neuer Sockel, AIO passt nicht. Mountig Kit für die AIO, was sind schon 13€. :rolleyes: Ach da war noch was... Contact Frame ist ja auch Pflicht. OKAY. Das wars aber jetzt. Nope... der nvidia Adapter ist immer noch Müll... 12VHPWR Cable direkt zur PSU von bequiet muss sein, bestellt ... wird einfach nicht geliefert. :wut: Puuuuuh, was macht cablemod? Nice endlich be quiet Kabel im Angebot. Haben muss. Der Preis gesalzen.
Okay, das wars jetzt oder oder? Nope AW3423DW bei Dell im Angebot für 1099€ ......... sheesh
Welche bequiet kabel bei cablemod?
Doch, ich denke auch, dass das sein kann, wollte mich nur vergewissern bei Leuten, die sich damit besser auskennen.
Dann sind die bisherigen imaginären Vergleiche zwischen der 4090 und der RX 7900 XTX ja auch eher schwammig verglichen mit den tatsächlichen Leistungsunterschiede oder?
da müssten eben die reviewer und tester offenlegen ob die spiele im cpu limit waren oder nicht.
denn ein gpu test wird 1x cpu gemacht und zwar die möglichst stärkste für das anwendungsgebiet.
wenn dann eine 3080ti und 4090 die gleichen balken haben, wars ein cpu limit.
wenn ich aber spiele dabei habe, wo das passiert, schmeiß ich sie raus bevor ich mit den ergebnissen verwirrung stiffte :)
anno1800 macht in einem gpu test relativ wenig sinn. wobei 4k + 8x MSAA natürlich gut scheppern kann. ^^
war auch schon beim dell am überlegen aber der lüfter.... diggi das geht gar nicht :d
Bin noch am liebäugeln mit einem 42" OLED.
Linus hatte dazu ein Video gemacht, was man aus den schwammigen Infos der AMD Präsentation ggf. Schließen könnte.
Natürlich alles Spekulatius, weil niemand konkrete Zahlen genannt hat.
Kurzfassung:
Spekulation aufgrund unscharfer Datenlage:
7900xtx wird etwa 10% hinter der 4090 erwartet
Wehe irgendwer stellt diesen Post als Fakt dar und dichtet ihn mir an...!
Ich glaube dass erst wenn ich echte Benchmarks gesehen habe.
Wenn ich es richtig verstanden habe fällt das NDA mit dem offiziellen Launch, also 13.12.
Erfahrungsgemäß ist es am besten selbst zu testen. Völlig frei von vorherigen Infos.
Können wir evtl bitte wieder mehr über die 4090 schreiben und nicht mehr über Userverhalten?
Wir sind hier im Luxx. Das Luxx ist ein Tech Forum.
Kein Soziologie Forum. Kein Psychologie Forum. Und nix anderes.
Danke.
Achso. Die mit 4 oder 3 pcie? Haben beide 600w? Warum habfn die mal keine 90° gewinkelte. Dsmn braucht man auch keinen adapter.
der 90 grad adapter kommt ja. kabel brauchste dafür aber nochmal dazu
extension für 8pin
fertige direkt für "alte" nts
für bq übern configurator
Kurzfassung:
Bei durchschnittlich nur 10% hinter der 4090 würde sich die RX 7900 XT defintiv viel mehr lohnen, wenns um reine Gamingleistung geht und wenn es dann tatsächlich so sein sollte.
Ja, kann es kaum abwarten echte Zahlen zu sehen und vor allem was AMD noch mit einer möglichen RX 7950 X3D so abliefern wird.
Das würde mich auch interessieren (nicht, daß Jura nicht auch interessant wäre 🙄)!
Das war bei meiner Zotac und jetzt auch bei der FE so. Ebenfalls nur 3x8 Pins dran. Kann das sein, dass wir die Sense-Leitung "versehentlich" nicht angeschlossen haben? Soweit ich das interpretiere für nur eines der vier Kabel die Sense-Leitung, oder habe ich das falsch verstanden?
Wenn wir wieder zurück bei Tech-Themen sind. Ich zitiere mich ja ungerne selbst, aber hat dafür sonst noch jemand eine Erklärung?
Mit der Sense-Leitung lag ich falsch, aber was könnte sonst den hohen powerdraw erklären?
Der letzte Post besagt, dass das Update Tool buggy ist, aber nicht das Bios.
Also kein Grund zur Sorge :)
ja einfach entpacken den installer, mit GPU-Z das richtige BIOS suchen und von Hand flashen
