[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
850 BeQuiet Platinum mit 666 Bios (bis 655 gelogged in gpu-z) und Ryzen 5800X3D mit 2 NVME und Wakü läuft. Keine resets und nicht mal das rote Undervoltage Lämpchen an der Strix hat geleuchtet. Ob man soviel Watt braucht ist eine andere Frage - die vollen 666W sind halt für VR wo jede missed frame ein Problem sind…sonst ist’s wohl egal ob 77 oder 84 fps…
Mit welchem Game/Bench?
Mit 13900K(F) könnte das noch mehr sein, da sie mehr Daten zur 4090 schaufeln kann
GPU-Z zeigt nur an, was das Bios "vorgibt".
Hättest Du ein 1000W Bios, würde GPU-Z bei der gleichen Leistung 1000W anzeigen.
Hatte ich damals an der 3090. Statt dem 360W-Bios ein 450W-Bios draufgehaun. GPU-Z hat brav 450W angezeigt, aber an der Steckdose hat sich gar nix geändert.
Kann man die 665W an der Steckdose messen? (Plus natürlich dem Restlichen System, oder als Differenz zu den 450W davor). Ansonsten ist die "Messung" von GPU-Z mit Vorsicht zu genießen.
Aber viele Leute die 2K für ne Graka raushauen, haben den 10er für ein Energiemessgerät nicht mehr übrig hab ich manchmal das Gefühl^^
@HisN
So siehts aus...
Hatte auf meiner 3090 FTW3 Ultra ein 366W-BIOS (PL). GPU-Z zeigte irgendwas an (war mir eh egal, weil Fake-Werte)
Mit der "Zange" gemessen kam ich + Slot auf über 520W
Ich erwarte die Tage etwas aus Shenzhen :) (ElmorLabs PMD-AD-P4X16 + PMD-USB + Software etc)
  • Danke
Reaktionen: A6
Scheitert nicht an den 10€ sondern am „Wozu?“
@HisN
So siehts aus...
Das war bei der 3090 weil es verschiedene Anschluss-Varianten gab…dann war der Wert aber um 1/3 falsch und leicht anhand von Temperaturen und Clock Speed zu entlarven. Das Galax 666 bios zeigt es richtig an, da die temps/clock auch proportional zum Verbrauch steigen.
Portal RTX ohne DLSS und ohne FG in 4K.
€2559.-- für eine gebrauchte unvollständige Strix...Alter die bei Alternate haben auch einen an der Waffel .....:poop:
Die denken sich, dass ein Dummer die schon irgendwann kaufen wird. Die Produkte im Outlet dort sind oft teurer als der günstigste Marktpreis und lohnt sich oft nur bei Rabattaktionen, wie letztens für 20% auf alle Outletartikel.
Ich bin gespannt, ob wir heute mal mit der Bitte um nen 4090er FE-Drop erhört werden... :sneaky:
@wolfplayer1: haste gleich zu mir liefern lassen oder wolltest Du sie vorher auch noch kurz anschauen :fresse2: ?
Update: ich hab mir jetzt die Byski für meine TUF bestellt. Bin mal gespannt und hab aktuell keinen Bock auf WC zu warten. Mit 170,- EUR kann man dann immernoch überlegen auf nen Heatkiller zu wechseln, so im Sommer 2024 oder so :hust: :p
Bin gespannt wie er aussieht wenn er da ist (Heatkiller), aber wird wohl noch dauern.
Ich bräuchte keine weiße strix. Kann dieses Strix oder Nix eh nicht nachvollziehen. Darauf ruht sich ASUS auch recht gut aus. Aber ich bin da auch nicht die Käufergruppe für. Habe schon jahrelang keinen PC mehr mit Sichtfenster und bin sowieso auf Wasser umgeschwenkt. Scheinbar finden viele ein weißes Innenleben stylisch.
ich baue sehr viel in meinen PCs und auch da macht sich alles besser als schwarz. Und alles schwarz ist doch depri.
Selbst das grau des TaiChi war da besser, aber wenn man einen farblichen Einklang will grenzt das die Sache schon sehr ein.
Die Optik ist jetzt auch nicht so mein Thema, das sieht man bei mir schon anhand der Kabel- und Schlauchführungen :rotwerd:
Die weiße Strix ist in Deutschland ja noch nichtmal gelistet, oder hab ich etwas übersehen?
jo aber das siehst du ja nur wenn du wirklich einen PC mit einem entsprechenden Gehäuse hast in das du reinsehen kannst. Und der PC vielleicht noch auf dem Schreibtisch steht. Ansonsten ist es dir ja eher egal wie es innen aussieht. Wobei ich auch aufs Kabelmanagement achte, obwohl mein PC kein Sichtfenster hat.
aktuell hab ich zum Beispiel garkein Seitenteil drauf, dass die TUF gut Frischluft bekommt, da sehe ich schon einiges, aber wie gesagt ist da der praktische Aspekt für mich auch nicht von der Hand zu weisen.
Keine Frage, ich würde auch eine schwarze Strix nehmen, aber über die HOF-Sachen freue ich mich auch immer. Ich finde das sieht hochwertiger aus
So reicht mir zb. mittlerweile vollkommen .
Muss nicht mal mehr gesleevte Kabel sein .
Halbwegs aufgeräumt die Kabelführung auf beiden Seiten , Airflow und eine schwarze Glastüre damit man schnell rein schauen könnte , wenn ein Fehlercode anliegt.
Jeder setzt seine Prioritäten anders .
genau das meine ich. Damit bestätigst du mich ja direkt. Natürlich hat man dann eher andere Ansichten. Ich würde sogar wetten das die Leute die ihren PC einfach unterm Schreibtisch stehen haben da kein Stück wert drauf legen. Weil man es sowieso nicht sieht.
Aber wie schon gesagt, setzt eben jeder seine Prioritäten anders. Wichtig ist das man am Ende mit dem Ergebnis zufrieden ist.
Wenn die in mein Gehäuse passen würde, würd ich sie auch sofort nehmen!
ja, aber nur teilweise.
Ich lasse ja das Seitenteil nicht offen dass ich reinschauen kann, sondern dass die TUF Luft bekommt. Nur deshalb schaue ich aber nicht in die andere Richtung im Raum. Positiver Nebeneffekt ist auch dass ich so problemlos die Wassertemp am HFN ablesen kann :p
das ist ja normal und mehr Möglichkeiten zur Individualisierung gab es nie, aber es werden trotzdem stetig mehr
so ist es (y)
Strix? Pfff…
Titan!!! (Danke @Don) 😍
Adapterkabel von be quiet! (12VHPWR) aktuell bei Mindfactory erhältlich für 15,21 EUR. Keine Lieferzeitangabe vorhanden.
Ich habe jetzt mal
Kann das einer empfehlen hat da schon eine Erfahrung mit gemacht.?
Lg
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin (12 + 4) 12VHPWR Anschluss für RTX 3090 Ti 4080 4090 | 3x8pin (4+4) CPU-Stecker nur für Corsair / Great Wall / Thermaltake modulares Netzteil https://amzn.eu/d/d7dPlSw
Hab mir das Kabel (für Seasonic in meinem Fall) angeschaut und rumgetestet, da die Zotac Trinity eher Müll ist um so ein Kabel auszulasten, kann ich nichts bemängeln. Gute Qualität, lässt sich gut verlegen, gute Länge selbst in einem Enthoo Pro
Strix? Pfff…
Wusste gar nicht, dass Nvidia die 600W-Stecker vergrößert hat.
Auch den release-klick-Dingsbums des Stromsteckers gibts nicht mehr, man erspart sich die Aussparungen in den Kühlrippen beim Stecker. (y)
Sicher kein Fake, alles legit. (y)
Im Video rumgeskippt, sofort die Aussparungen beim Stecker gesehen. Ka, da läuft wohl was mit deinen Augen falsch.. außer du sprichst von den selbst erstellten Bildern.. aber wieso solltest du das, wenns doch einen Teil mit richtigem Stromanschluss gibt..
Aber dennoch, es ist Moore's Law Is Dead.. der Typ ist auf gut Deutsch gesagt "voll mit Scheiße".
Wozu im Video rumskippen, wenn man es bereits oben im pic sieht. oO
Auch hier keine zu sehen:
Ähnliche Themen
