[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kein Platz im Gehäuse … das muss der Lego Mod wieder herhalten! :fresse:
Die Karte geht direkt zurück! Kann mich nicht erinnern jemals so eine laute Karte gehabt zu haben ... für den Preis absolutes NoGo.
Bilder-Quote :hust: ;)
Mir ist bewusst dass die 4090 nur 4 Monitore GLEICHZEITIG ansteuern kann, aber kann man 5 Monitore anschließen und über windows wechseln?
bis auf 5 bin ich auch noch nicht gekommen, aber bei DP gibt's ja DaisyChain, werden die Displays in Reihe geschalten.
Ich weiß nicht ob techn. nur 4 gehen oder ob es sich auf die Anzahl der Anschlüsse bezieht 🤔
Bin erschrocken, wie "schlecht" der RAM meiner TUF (Non-OC-Version) geht...
Links Strix OC @ Luft (22°C Raumtemp.) und +1.915MHz in AB (= 1.552 MHz in GPU-Z) - rechts die TUF @ 3°C Wasser + EVC2 mit 1,45V auf VRAM (default sind 1,35V)
Ich komme nicht mal ansatzweise über 1.500MHz in Speedway. Bei normalen Settings sogar nur bis 1.375-1.400MHz :rolleyes2:
Das ist der Preis für die 24gb, denn der vram ist immer nur so gut wie der schlechteste Chip und bei der Größe ist die Gefahr groß, dass ein schlechter Chip dabei ist./:
Daher sehe ich auch die Titan mit 48gb auch als kritisch an was oc angeht.
Hätte ich Übung und vor allen Dingen Zugang zu DDR6X-Chips, würde ich mich vielleicht dran wagen, Chips zu tauschen
Dazu müsste ich aber erstmal wissen, welcher Chip so lahmt
Wo ist @f!P[z]y ? Der macht sowas... :)
Also ich kann hier noch eine Erfahrung beitragen,
seit dem ich meine Suprim vertikal verbaut habe, scheint mir diese deutlich heißer zu werden.
Offensichtlich arbeitet die Vapor Chamber dort nicht mehr so gut.
Können das andere auch betätigen mit ihren Karten, gibt ja auch noch andere Modelle mit Vapor chamber?
🤣 das ist ein alter Hut das ne gpu vertikal wärmer wird als Horizontal. Blätter mal nach 2017 oder so zurück, zu der Zeit als die riserkabel auf den Markt kamen.
Du sollst deine Karte auch endlich unter Wasser setzen. ;) hast dir extra nen Mora und so angeschafft und nun lässt du sie mit den Luftkühler arbeiten.
Hätte sogar zufällig einen Kühler über. :d
Hab mir heute eine Strix gezogen, wenn die gut ist und auch der Speicher mal 2000+ oder so läuft, dann werde Wakü nicht aus schließen ;)
Er kauft 2k gpus wie andere Unterhosen 🤣.
Mach mal lieber beim gskill cup mit 😁
Nur um das gerade zu rücken, es wäre dann meine 2te 4090 sollte hier im Rahmen sein.
Aber gut, danke für die Antworten bzgl. der Einbaurichtung, werde dann besser wieder horizontal einbauen (y)
Flach spielen, hoch gewinnen. :d
Hattest du nicht eine fe, eine suprim und 2x ne strix da?
Nein das hatte funky in seinem 4090 bench thread iwi falsch eingetragen ;)
Apropos FE... :oops:
K.A. was sich die Hersteller, der Blöcke gedacht haben
Hab leider keinen Vergleich zu horizontal, da meine mit Lukü nur vertikal ins gehäuse passt, aber ich habe den Eindruck, dass die Temps niedriger sind als bei einer FE@horizontal. Zumindest hat die Suprim mehr Reserven wenn man die Lüfter mal voll aufdreht.
Für welchen Kühler hast du dich auf deiner Suprim letztendlich entschieden?
Habe eine Alphacool Eiswolf 2 ist es ein Nachteil, wenn man sie vertikal verbaut . ?
Lg
Habe aktuell den Alphacool verbaut. Der gefällt mir optisch noch ein bisschen besser als der Phanteks. Überlege vllt irgendwann noch den Corsair zu testen, den finde ich zumindest optisch am stimmigsten für die SuprimX.
Würde man Anleitungen lesen, hätte man gesehen, das wenigstens bei einem der Blöcke aus dem Test ein Pad zwischen Backplate und PCB im Bereich des Steckers vorgesehen ist.;)
Interessant. Danke für das Video. Hab gerade geschaut, bei meinem Phantecs Glacier ist da auch NIX.
Aber man könnte über die Backplate, wenn man denn wollte ...
Moin,
Szenario bei mir wäre: am Schreibtisch 4k fernseher plus 27" hdmi Monitor und am Simrig 3x32 1440p DP monitore.
Würden nie beide Monitor Setups parallel an sein...
Hat das schonmal jemand getestet?
Schon zu Maxwell-Zeiten.
Warum sollte man nicht jeden Anschluss mit einem Monitor beglücken können? Da fährt ja jetzt keine Metallblende vor das 5. Loch wenn Du vier andere Löcher mit Anschlüssen zustopfst.
Warum solltest Du denn keine 5 Monis anklemmen können? Was soll denn da passieren?
Zu viele Gedanken :-)
Endlich, Block ist unterwegs (y)
Es gibt keine fünf Ausgänge bei der 4090.
Edit. Ausser Asus?!
DaisyChain bei DP ;)
ich weiß nicht wie viele da in Reihe gehen
