[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Vielleicht hat er ein 600 Watt custom-Bios drauf, so eins gibt es wirklich.
Hatte ja mal gefragt wie man am besten den Clip vom PCI-e Steckplatz löst. Hab den Plastikgriff von einer Fliegenklatsche genommen, der war schön breit und nicht so gefährlich abzurutschen :bigok:
Ich hatte meine gerade wieder kurz ausgeklippt, da kommt man doch ganz bequem mit dem Daumen drann und er bewegt sich auch sehr einfach.
Ich glaub das hängt dann wirklich arg vom Board ab, ob man "Tools" wie eine Fliegenklatsche braucht.
OMG, ich bin so stolz auf mich. Ich hab den RGB-Stecker vom Pantek Glacier bei eingebauter Karte reingefummelt bekommen.
Damals beim Einbau hatte ich keinen Bock auf RGB, aber jetzt (ich wusste, es fällt mir auf die Füße), wollte ich dann doch noch ein Lichtlein sehen. Wer faul ist muss büßen.
Aber hat erstaunlich gut geklappt, zwei drei Versuche haben gereicht.
Ich meine, zieht euch mal das Mini-Steckerchen rein, das in eine Buchse kommt, die auf der Seite, die zum Mainboard zeigt und auch noch "innherhalb" einer nicht abnehmbaren Abdeckung liegt, rein muss.
250 Watt ist die Grenze bei mir!
880mV und 2500Mhz und wenn nötig werden die FPS etwas zusätzlich reduziert.
In der Regel verbrauche ich 180 bis 220 Watt und bekomme über 100 FPS in 4k.
PL bleibt bei 100%.
Da kannst du von ausgehen. Weiß auch nicht was der Sinn von diesem EU Store sein soll. Die versenden bei mir auch jedes Mal aus China und es dauert ewig.
Ich hab nur ca. 1cm zwischen Grafikkarte und Noctua NH-D15 auf einem MSI B650 Tomahawk
mittlerweile notwendiger, rein bürokratischer blödsinn... die steuer- / zoll-regeln etc. pp. erfordern mittlerweile (soweit ich weiß, muss jetzt nicht alles 100% stimmen und korrekt sein) einen sitz des unternehmes, das dort verkaufen will, in eben diesem land, in dem verkauft werden soll; mit allem verwaltungs- und eben bürokratie-/steuer-wahnsinn, der dazugehört. ist dann meistens nur ein reines büro mit steuernummer, die lager etc. bleiben in china. größere unternehmen haben zustzl. dann auch mal ein lager im entsprechenden land, aus dem sie versenden können.
ich habe heute eine 4090 TUF eingebaut. Dazu habe ich zunächst den bestehenden Wasserkreislauf für die Grafikkarte mit einem Bybass versehen, da der Watercool-Block erst Mitte Mai verfügbar ist.
Netzteil ist ein Seasonic TX Prime 850W mit Seasonic 12VHPWR-Adapterkabel. Board ist ein Asrock X570 Taichi mit 5950x CPU.
Der Rechner startet aber mit der TUF nicht. Das Board ist die Revision mit dem idiotisch im Überhang des Grafikkkartenslots platzierten USB-3.2-Anschluss.
Da die Karte so riesig ist, fällt es schwer zu beurteilen, ob die Karte richtig im Slot sitzt oder hinten an dem USB-Anschluss aufliegt. Slotblech passt und die Arretierung des Slots ist auch eingerastet.
Oder doch ein Netzteil-Problem? 850W zu wenig? Habe leider kein stärkeres Netzteil zum Testen da.
Jedenfalls habe zunächst wieder auf Wasser umgebaut und die alte 3080 Strix wieder im Einsatz. Da kommt Freude auf. :rolleyes:
Falls das Kabel nicht defekt ist, sollte es nicht am Netzteil liegen. Habe auch nur Corsair AX 850 mit dem Corsair 12VHPWR Kabel im Einsatz und merke keine Einschränkungen.
Viel mehr tippe ich hier auf Bios Version Shenanigans von AMD und Nvidia. Gibt ja genug Threads zu nicht bootenden System bei dieser Kombo.
Ja, vor Einbau der Karte habe ich selbstverständlich das Bios geflasht, mit dem die Kompatibilität mit RTX 40-Karten "verbessert" werden soll. Mehr kann ich diesbezüglich nicht tun.
Nur damit ich es richtig verstehe: Die GPU soll bei einem Power-Limit von 50 % noch 300 Watt ziehen?
Bei meinem BIOS schon ;)
Geht die rote LED an der Buchse nicht aus?
Na er meint den Stromstecker. Die TUF und Strix haben da eine rote LED, über deren Funktionsweise hier verschiedene Meinungen gepostet wurden.
Meine funktionierten aber auf allen Strix und auf der TUF so, wie sie es meiner Meinung nach sollen und wie es auch Sinn macht: (korrektes) Kabel dran, LED aus. Kabel ab, oder nicht richtig drauf oder kaputt: LED an. Egal ob stand by, idle oder unter Last.
Alles klar, danke. Ich muss mich diesbebezüglich noch ein wenig einlesen.
Na an der Karte :d
Jede 4090 hat so eine :fresse:
Wenn der PC aus ist, leuchtet die rote LED. Wenn er an ist, sollte sie aus sein bzw. nicht blinken
@Gurkengraeber
Bei vier ASUS-Karten hab ich immer die gleiche Funktionsweise gesehen
Dabei kamen zwei verschiedene Adapter/Kabel und zwei verschiedene NTs zum Einsatz
Wie war denn die Funktionsweise bei Anderen? Hab es nicht weiter verfolgt, da ja alles funktioniert
Na an der Karte :d
@Gurkengraeber
Ber der tuf und dem dark power 12 1200w Netzteil war die LED immer an wenn der PC aus war da voraussichtlich das Netzteil noch Strom lieferte. So meine These
Habe Corsair AX 1000 Titanium und TUF RTX 4090 . Bei mir hat bisher nie die LED der Karte geleuchtet . Sowohl mit dem Aorus Z490 Master Board und dem Asus z790 strix D4 . Kabel das von Corsair seit Release verwendet .
hi,
wie mein name schon sagt, kenne ich mich nicht so sehr gut aus.
habe einen omen komplettrechner mit einer 4090 und frage mich, weshalb laut gpu-z niemals mehr als als maximal ca. 300w (scheint kein hardcap zu sein) gezogen werden.
selbst wenn die fps mal unter 100 droppen und die gpu auslastung steigt.
hätte schon gerne meine konstanten 144fps v-sync analog zu den lg bildschirmen.
kann ich die leistungsaufnahme bzw das verhalten zum aufnehmen der leistung in irgendeiner form beeinflussen?
@newb1
Welche CPU ist denn verbaut?
hi,
Was steht denn bei CPU-Z unter dem Reiter "Graphics"? Steht die TDP da auf 450W? Ich könnte mir vorstellen, dass HP da ein eigenes Custom Design verwendet, was auf 300W limitiert ist.
da steht tatsächlich 450W
Ok und wenn du einen Benchmark machst geht die auch nicht über 300W oder nur in Games? Kannst z.B. mal Furmark probieren.
das verwundert mich jetzt positiv, bei furmark geht es bis 450 in spitzen auch bis 460W hoch.
also wieso dümpelt die grafikkarte ingame bei rund 50+% gpu load und knapp unter 50% power consumption herum, wenn damit nicht konstant die 144 vsync fps gehalten werden können
und auch mit deaktiviertem vsync steigert sich die leistung nicht.
oder habe ich ein grundsätzliches verständnisproblem?
Ich hänge mich mal bei dem Thema ein. Meine 4090 verhält sich ähnlich. Habe die Tage wieder mit 3D Mark Time Spy gebencht und mir ist aufgefallen das die Karte zwischenzeitlich zwischen 70 und 100% schwankt. Die Auslastung der GPU sinkt doch nur wenn man ins CPU Limit läuft oder nicht?
