Th4R4t
habe ein Problem mit einem WOL Script das ich im Internet gefunden habe. Es soll dazu dienen meinen Server per WOL der Fritzbox zu wecken.
Wenn ich per Terminal die Datei ausführen will erscheint immer folgende Meldung:
Wo liegt der Fehler bzw. was mache ich falsch? :/ Hab den Code in Textmate eingefügt und normal mit der Endung ".py" gespeichert.
Code:
#!/usr/bin/perl
# (c)2012 speaker
use strict;
use warnings;
use LWP::UserAgent;
use Encode;
use Digest::MD5 qw(md5_hex);
my $ua = LWP::UserAgent->new;
### start of config section
# if you don't want to store your credentials within this script just keep the
# following three dummy values and set $ask_auth = 1
my $httpuser = "<http auth user>";
my $httppass = "<http auth password>";
my $fritzpass = "<fritzbox admin password>";
my $ask_auth = 0;
my $host = "<hostname or ip>";
my $port = 443;
my $mac = "<mac for wake up>"; # use mac format 01:23:45:67:89:AB
# uncomment the following line if you get ssl certificate warnings
#$ua->ssl_opts(verify_hostname => 0);
### end of config section
### do not change anything below!
sub readcreds() {
use Term::ReadKey;
print "http auth user: "; chomp($httpuser = ReadLine(0));
ReadMode('noecho');
print "http auth pass: "; chomp($httppass = ReadLine(0));
print "\nfritzbox pass: "; chomp($fritzpass = ReadLine(0));
ReadMode('restore');
print "\n\n";
readcreds if ($ask_auth);
$ua->timeout(30);
push @{$ua->requests_redirectable}, 'POST';
$ua->credentials($host.":".$port, "HTTPS Access", $httpuser, $httppass);
my $url_base = "https://".$host;
my $url_login = $url_base."/login.lua";
my $url_wakeup = $url_base."/cgi-bin/webcm";
my $r = $ua->get($url_login);
if ($r->is_success) {
my $c = $r->decoded_content;
if ($c =~ m#(?:g_challenge|var challenge|\["security:status/challenge"\]) = "([a-f0-9]+)"#) {
my $challenge = $1;
my %data = (
username => $httpuser,
response => sprintf "%s-%s", $challenge, md5_hex(encode("UTF16-LE", sprintf "%s-%s", $challenge, $httppass))
$r = $ua->post($url_login, \%data);
if ($c =~ m#(?:home|logout)\.lua\?sid=([a-f0-9]+)#) {
my $sid = $1;
%data = (sid => $sid, "wakeup:settings/mac" => $mac);
$r = $ua->post($url_wakeup, \%data);
print "wakeup done.\n";
} else {
printf "error: %s\n", $r->status_line;
} else {
print "error: could not find a session id\n";
} else {
print "error: could not find a challenge\n";
} else {
printf "error: could not login - %s\n", $r->status_line;
exit 0;
Code:
File "1.py", line 5
use strict;
SyntaxError: invalid syntax
