Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'F:\Nero\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25.06.2002 16:34:54
Nero Version: 5.5.10.0 (Nero Express)
Recorder: <TEAC CD-W512EB> Version: 2.0E - HA 1 TA 1 - 5.5.10.0
Adapter driver: <IdeChnDr> HA 1
Drive buffer : 2976kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <TOSHIBA DVD-ROM SD-M1712>Version: 1004 - HA 1 TA 0 - 5.5.10.0
=== Scsi-Device-Map ===
DiskPeripheral : IC35L090AVV207-0 IdeChnDr Port 0 ID 0 DMA: On
DiskPeripheral : IC35L040AVER07-0 IdeChnDr Port 0 ID 1 DMA: Off
CdRomPeripheral : TOSHIBA DVD-ROM SD-M1712 IdeChnDr Port 1 ID 0 DMA: On
CdRomPeripheral : TEAC CD-W512EB IdeChnDr Port 1 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 269MB (275676kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: On
20.1.2003
CD-ROM (ISO)
14:52:22 #1 Text 0 File Isodoc.cpp, Line 7328
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:52:22 #2 Phase 72 File dlgbrnst.cpp, Line 1649
BURN-Proof activated
14:52:22 #3 Text 0 File Reader.cpp, Line 115
Reader running
14:52:22 #4 Text 0 File Writer.cpp, Line 123
Writer TEAC CD-W512EB running
14:52:22 #5 ISO9660GEN -11 File geniso.cpp, Line 4519
First writeable address = 0 (0x00000000)
14:52:22 #6 Text 0 File Burncd.cpp, Line 3790
Turn on Track-At-Once, using CD-R/RW media
14:52:22 #7 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 133357 (133357) = #133357/29:38.7
relocatable, CD pos for caching/writing not required/required, no patch infos
14:52:23 #8 Text 0 File DlgWaitCD.cpp, Line 202
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 133356 (29:40.06)
14:52:23 #9 Text 0 File DlgWaitCD.cpp, Line 207
Write in overburning mode: FALSE
14:52:23 #10 Text 0 File DlgWaitCD.cpp, Line 1419
Recorder: TEAC CD-W512EB;
CDRW code: 00 97 32 11; OSJ entry from: Prodisc Technology Inc.
ATIP Data:
Special Info [hex] 1: D1 00 C6, 2: 61 20 0B (LI 97:32.11), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 02 4A B0, 2: 5A C8 06, 3: 00 00 00 (invalid)
14:52:23 #11 Text 0 File ThreadedTransferInterface.cpp, Line 811
Prepare recorder TEAC CD-W512EB for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 273422336
14:52:23 #12 Text 0 File ThreadedTransferInterface.cpp, Line 839
Removed 2 run-out blocks from end of track 1.
14:52:23 #13 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 133355 blocks [TEAC CD-W512EB ]
14:52:23 #14 Phase 36 File dlgbrnst.cpp, Line 1649
Burn process started at 4x (600 KB/s)
14:52:23 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1952
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
14:52:23 #16 Text 0 File Mmc.cpp, Line 17129
Set BUFE: BURN-Proof -> ON
14:52:31 #17 SCSI -1114 File Cdrdrv.cpp, Line 1393
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x02540000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x29 0x00
14:52:31 #18 MMC -1114 File Writer.cpp, Line 331
Reset occurred
14:52:31 #19 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
14:52:31 #20 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
14:52:37 #21 CDR -201 File WriterStatus.cpp, Line 194
Invalid write state
14:52:37 #22 TRANSFER -18 File WriterStatus.cpp, Line 194
Could not perform EndTrack
14:52:37 #23 Text 0 File Mmc.cpp, Line 12011
<TEAC CD-W512EB > start Close Session
14:52:42 #24 Text 0 File Mmc.cpp, Line 12035
Fixation : Second step for unclosed Sessions
14:52:42 #25 SCSI -1114 File Cdrdrv.cpp, Line 1189
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
14:52:45 #26 CDR -1124 File WriterStatus.cpp, Line 168
Unknown medium format
14:52:45 #27 TRANSFER -39 File WriterStatus.cpp, Line 168
Could not perform EndSession
14:52:46 #28 Phase 38 File dlgbrnst.cpp, Line 1649
Burn process failed at 4x (600 KB/s)
14:52:46 #29 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
14:52:48 #30 SCSI -1114 File Cdrdrv.cpp, Line 1189
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x1E 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Existing drivers:
File 'Drivers\IdeChnDr.sys': Ver=2.2.0.2126, 04/10/2002, size=93594 bytes, created 22.04.2002 00:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
