Razer Copperhead unter Vista 64 Bit
I just tested it and it will install without problem on vista 64 it even creates a 64 bit driver directory in the installation folder but. It does not seem to work. All you get is that the razer software cant find the mouse.
Das selbe Problemchen habe ich auch! Ohne Razer Konfigurationssoftware kann ich mir ja gleich ne 10€ Maus anschließen...
