I am trying to find the hardware for my first Proxmox server build and would like to ask for your experience.
My requirements are:
Thomas
- The idle/low load power consumption of the system should be at a maximum of around 40-45 watts or better even lower (that's important to me).
- The system shall serve:
- Some LXC containers:
- Plex
- Syncthing
- Nextcloud
- CUPS
- UniFi controller
- FreePBX
- Gitlab
- 2 VMs running Win10
- 1 VM running Ubuntu (just as playground)
- 1 VM running Docker
- Webserver (for private use)
- Portainer
- Zoneminder (maybe)
- I prefer server-grade hardware (if possible)
- Supermicro mainboard
- Xeon CPU (or maybe Epyc)
- ECC RAM
- 10GBASE-T + 1000BASE-T
- IPMI
- The CPU shall have an integrated GPU (for Plex transcoding)
- For the system drive I want to use a ZFS Mirror, either 2x HDD or 2x SSD (will de SSDs do well with ZFS?)
- The board shall provide at least one PCIe for a TV card (for Plex)
- Can you recommend a CPU and mainboard? What about Xeon E3, Xeon E-21xx, Xeon-D...would they be sufficient? Or any better recommendations?
Thomas
