Seasonic S12-330 Rev. 3
At the same time, some changes have been made to the accessories bundled with the S12:
* Dr. Cable (a system for cable management) has been dropped in favor of simple cable sleeving.
* The IDE to 5 volt / 12 volt fan-header adapter is no longer included
* A new IDE to 2 x Floppy adapter is included, as there is no longer any floppy connectors on the base cables
* 6 HDD connectors (previously 5) - 330 & 380W models
* 6 HDD connectors (no change) - 430W model
* 9 HDD connectors (previously 6) - 500 & 600W models
* 4 SATA connectors (previously 2) - 330, 380 & 430W models
* 6 SATA connectors (previously 2 or 3 depending on US version or not) - 500W model
* 6 SATA connectors (previously 4) - 600W model
* 1 PCIe power connector (previously 0) - 330, 380 & 430W models
* Longer (black) sleeved cables - All
* RoHS compliant - All
One final change is that the Fan RPM monitor cable has been removed. It is no longer possible to monitor the speed of the internal fan. Most likely, it was dropped because so many motherboards have trouble detecting an RPM signal at the slow speed that the fan spins.
Längen:
* 21" cable for main 20+4-pin ATX connector
* 23" cable for auxiliary 4-pin 12V AUX connector
* 22" cable for 6-pin PCIe connector
* 23" cable with two SATA drive connectors
* 20" cable with two SATA drive connectors
* 28" cable with three 4-pin IDE drive connectors with squeeze grips
* 21" cable with three 4-pin IDE drive connectors with squeeze grips
* 5" splitter from Molex to 2 × Floppy connectors
