Intel Speed Shift Technology Skylake | Page 2 | TechPowerUp Forumsunclewebb schrieb:ThrottleStop also lets you access the Speed Shift - Energy Performance Preference (EPP) setting. This can be adjusted from 0 to 255 which gives a user full control of their CPU so they can switch between full performance or maximum energy savings or anywhere in between.
If you are the type of person that always runs their CPU at maximum MHz then Speed Shift is not for you. If you usually use the Windows Balanced power profile then you should consider turning on Speed Shift instead. Compared to the Windows Balanced profile, Speed Shift does a better job managing the CPU and it will increase off idle performance.
Hat jemand schonmal zuvor dies aktiviert und gibt es nennenswerte Vorteile? Also in einem c't Test zum Skylake viel der Effizienzgewinn ziemlich mager aus, deher die Frage ob OS gesteuert oder doch via Speedshift Setting?
Ich habe in Throttlestop 128 (Balanced Profile) mal aktiviert.
CPU ist i5-8400.
