[Übersicht] Speichertestprogramme 2025
Jeder kann testen, wie er es für richtig hält. Einen pauschal "richtigen" Weg, der für alle potenziellen Probleme und Fehler ideal ist, gibt es sowieso nicht.
Sachliche Diskussionen sind erlaubt und erwünscht, wer aber andere User ihrer Meinung wegen persönlich angreift wird von mir aus dem Thread verbannt (unbefristet).
1. Live DVD/USB Bootable
1.1. Passmark MemTest86
Homepage: MemTest86 - Official Site of the x86 Memory Testing Tool
Hardwareluxx Sammelthread:
Typ & Lizenz: Live-CD/DVD/USB, Freeware + Commercial + Business
MemTest86 is the original, free, stand alone memory testing software for x86 computers. MemTest86 boots from a USB flash drive or CD and tests the RAM in your computer for faults using a series of comprehensive algorithms and test patterns. The latest version of MemTest86 supports all the current technologies, including:
  • 13 different RAM testing algorithms
  • DDR4 RAM (and DDR2 & DDR3) support
  • XMP - high performance memory profiles
  • UEFI - The new graphical standard for BIOS
  • 64bit - From version 5, MemTest86 is native 64bit code
  • ECC RAM - support for error-correcting code RAM
  • Secure boot - With MemTest86 being code signed by Microsoft
  • Graphical interface, mouse support and logging of results to disk
  • Foreign language support (Chinese, German & more)
  • Self booting off USB or CD, without needing DOS, Linux nor Windows
  • Network (PXE) boot - Scalable, disk-less provisioning from a single PXE server
  • Dual booting - Will boot to V4 in BIOS and V7 in UEFI from a single flash drive
1.2. Stessfull application Test (Stressapptest, GSAT)
Homepage: stressapptest - Linux Mint Community
Source: stressapptest @ GitHub
Typ & Lizenz: Linux basiert, Live-CD/DVD/USB, Open Source
Stressful application test (or stressapptest, its unix name) tries to maximize randomized traffic to memory from processor and i/o, with the intent of creating a realistic high load situation in order to test the existing hardware devices in a computer. Stressapptest may be used for various purposes:
  • stress test
  • hardware qualification and debugging
  • memory interface test
  • disk testing
Bild1 Bild2 Bild3​
1.3. GoldMemory (Updated 09/2021)
Homepage: GoldMemory.cz
Typ & Lizenz: Live Medium, Freeware + Commercial (2016)
GoldMemory Advantages
  • an advanced professional memory testing software.
  • written in a "hand-tuned" pure x86 assembly language for x86 and x86-64 based computers
  • a standalone (not require operating system's)
  • supports booting from USB or CD
  • DOS-compatible (supports log file reporting)
  • allowing testing up to 64GB/1TB of memory size
  • uses proprietary algorithms customized for specific cases
  • where other standard solutions do not work
1.4. memtest86+ (Updated 01/2024)
Homepage: Memtest86+ - Advanced Memory Diagnostic Tool
Hardwareluxx Sammelthread: [Guide] Anleitung: Wie testet man RAM-Riegel mit Memtest86+ V2.01/V4.00?
Typ: Live Medium, Linux basiert
Based on the well-known original memtest86 written by Chris Brady, memtest86+ is a port by some members of the x86-secret team. Our goal is to provide an up-to-date and completly reliable version of this software tool aimed at memory failures detection.
- IMC polling for live RAM settings
- Preliminary support for ECC polling
- Add support for MMIO UART
- Add debugging options
- Bug fixes & optimizations
- Add support for Secure Boot Signing
- Add support for Headless EFI system
- Add various command line options
- Add support for legacy ATI SB400
- Fix an issue related to BadRAM pattern
- Fix disabling SMP using F2 at startup
- Fix crash on SuperMicro X10SDV
- Various bug fixes and optimizations
- Rewrite code for UEFI 32 & 64 bits
- Add support for x64 Long Mode Paging
- Add support for up to 256 cores
- Add detection for DDR4 & DDR5
- Add support for XMP 3.0
- Add detection for AMD Zen 1/2/3/4
- Add detection for Intel up to 13th Gen
- Add better support for AMD pre-ZEN CPUs
- Add support for older nVidia and AMD chipsets
- Add support for SDRAM
- Many enhancements
- Numerous bug fixes & optimization
2. Windows Anwendungen
2.1. HCI MemTest
Homepage: MemTest: RAM reliability tester for Windows
Typ & Lizenz: Windows Anwendung, Freeware + Commercial
MemTest is a RAM tester that runs under Windows. It verifies that your computer can reliably store and retrieve data from memory. A correctly functioning computer should be able to do this with 100% accuracy day in and day out. A computer that fails these tests, perhaps because of old hardware, damaged hardware, or poorly configured hardware, will be less stable and crash more often. Even worse, it will become even less stable over time as corrupted data is written to your hard disk.
By running MemTest you can ensure that your computer's RAM correctly functions. It is wise to test this when you buy a new computer, install new RAM, or change the configuration of your machine (for instance, to overclock it). Are you the sort of user who likes to push the performance of your machine to the edge? Relying upon whether your machine will boot after your new BIOS tweaks is a poor way to determine the safety of your new settings. Use Mem Test as a true test of stability.
Achtung seit 11/2019 EOL. Unterstützt MemTest Versionen bis 6.1 (Quelle).
Einstellungen: RAM to test, Number of threads, Number of rows, X/Y offset, X/Y spacing, Stop at coverage %, Stop on error (default), Start minimised (default), Window height,
Download: GitHub - integralfx/MemTestHelper: C# WinForms GUI to automate HCI MemTest
2.2. Linpack Xtreme
Homepage: https://www.ngohq.com/linpack-xtreme.html
Typ & Lizenz: Windows Anwendung & Bootable ISO, Freeware
Linpack Xtreme is a console front-end with the latest build of Linpack (Intel Math Kernel Library Benchmarks 2018.3.011). Linpack is a benchmark and the most aggressive stress testing software available today. Best used to test stability of overclocked PCs. Linpack tends to crash unstable PCs in a shorter period of time compared to other stress testing applications.
Linpack solves a dense (real*8) system of linear equations (Ax=b), measures the amount of time it takes to factor and solve the system, converts that time into a performance rate, and tests the results for accuracy. The generalization is in the number of equations (N) it can solve, which is not limited to 1000. Linpack uses partial pivoting to assure the accuracy of the results.
Linpack Xtreme was created because Prime95 is no longer effective like it used to be. LinX, IntelBurnTest, OCCT use outdated Linpack binaries from 2012. Modern hardware requires modern stress testing methodology with support for the latest instructions sets.
Linpack Xtreme is available for Windows, Linux, and as a bootable media. The bootable version is considered to be the most superior as the Linux SMP kernel is a lot more sensitive to hardware instabilities than Microsoft Windows. Watch this video for a short comparison of Prime95 vs. Linpack Xtreme.
Make sure to keep an eye on the temperatures as Linpack generates excessive amount of stress like never seen before.
2.3. Microsoft Windows Memory Diagnoctics Utility (mdsched.exe)
Homepage: -
Typ & Lizenz: Windows integriert (XP/Vst/7/8/8.1/10)
Windows includes built-in features to help you identify and diagnose problems with memory. If you suspect a computer has a memory problem that isn’t being automatically detected, you can run the Windows Memory Diagnostics utility by completing the following steps:
  • Click Start, type mdsched.exe in the Search box, and then press Enter.
  • Choose whether to restart the computer and run the tool immediately or schedule the tool to run at the next restart.
  • Windows Memory Diagnostics runs automatically after the computer restarts and performs a standard memory test automatically. If you want to perform fewer or more tests, press F1, use the Up and Down arrow keys to set the Test Mix as Basic, Standard, or Extended, and then press F10 to apply the desired settings and resume testing.
  • When testing is completed, the computer restarts automatically. You’ll see the test results when you log on.
Note that if a computer crashes because of failing memory, and Windows Memory Diagnostics detects this, the system will prompt you to schedule a memory test the next time the computer is restarted.
2.4. Karhu Software RAM Test
Homepage: RAM Test - Karhu Software
Hardwareluxx Sammelthread: [User-Review] RAM auf Stabilität testen mit RAM Test von Karhu Software
Lizenz: kommerziell
RAM Test is a fast and reliable memory testing software capable of detecting both faulty hardware and overclock instability. Its key features include:
  • An easy-to-use graphical user interface
  • Support for up to 8 TB of RAM and 64 threads
  • Optimized code paths for AVX/AVX2 capable processors
  • Portability (i.e. can be run from a USB flash drive)
User Rezensionen:
KGuiX schrieb:
Custom GUI (von jjgraphix)
Karhu-Reous-4200 16-16-19-16 10000_ 2.png Karuhu-Reous-6000 30-36-36 10000_ K259 1375 55.9 7600X2.png
2.5. TestMem5 0.13
Homepage: CoolCmd Github - TestMem5
Lizenz: Freeware
Es handelt sich um ein Rework des ursprünglichen TestMem5 0.12 von Serj (welches hier im Startbeitrag nun mit Legacy-Status geführt wird) mit diversen Fixes und Usability-Updates.
Unter anderen können in den Einstellungen des GUI nun direkt verschiedene Community-Konfigurationen ausgewählt und auch die Laufzeit direkt angepasst werden.
2.6 Aida64 Stabilitätstest
Homepage: Aida64
Typ: Windows Anwendung, kommerziell (Demo verfügbar)
Hinweis: zu finden im Menu Tools / Werkzeuge, es kann ausgewählt werden ob nur der RAM selbst oder in Kombination mit CPU/FPU/Cache getestet werden soll
AIDA64 Extreme has a hardware detection engine unrivaled in its class. It provides detailed information about installed software and offers diagnostic functions and support for overclocking. As it is monitoring sensors in real time, it can gather accurate voltage, temperature and fan speed readings, while its diagnostic functions help detect and prevent hardware issues. It also offers a couple of benchmarks for measuring either the performance of individual hardware components or the whole system. It is compatible with all 32-bit and 64-bit Windows editions, including Windows 10 and Windows Server 2019.
2.7 OCCT
Homepage: ocbase.com
Lizenz: Personal (Freeware max 1H Testdauer, oder kostenpflichtig) & Pro/Enterprise Editionen (kostenpflichtig)
OCCT is the most popular all-in-one stability check & stress test tool available.
It generates heavy loads on your components while checking for errors, and will detect stability issues faster than anything else.
OCCT embeds HwInfo's monitoring engine to get precise readings and diagnose issues faster.
3. Legacy Software
3.1 TestMem5
Homepage: TestMem support page - TestMem V
Lizenz: Freeware
Weitere Infos: Memory Testing with TestMem5 & Custom Configs @ Overclock.net
Features
- mehrere Testalgorithmen
- unterstützt manuelle Konfiguration aller Tests (u.a. CPU-Kerne, Speichermenge, Block Size, Laufzeit)
Es wird empfohlen für moderne Systeme ein Custom Configuration File zu verwenden.
Custom Settings - für Ryzen:
1) TM 5 0.12 1usmus config v3 (Quelle)
TM5 0.12 v3 config
TM5 @ Google Drive
after the first start of the program, delete the file cfg.link otherwise, v3 config will not work
* fixed test crash , when a certain cycle there was a shortage of memory
* 2 new test added
* test number 14 was temporarily removed, because there were few situations in which an error was found there
* special config for HEDT with 4 channel mode
2) TM 5 0.12 1usmus config v2 (Quelle)
Why this test/config?
Most of the tests work on a strict template. I think it's all a waste of time. In this configurator, the pattern is random. There is a re-allocation of memory for tests. Also, temperature-related tests for errors are added, tests in which the write and read offset occurs. For a dual rank of 5 cycles, for a single - 10, (recommendation).
Download config: Google Drive
Replace MT.cfg with it in the BIN folder.
3) anta777 Universal 2
Memory Test config file v0.02
Copyrights to the program belong to me.
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=Universal2
Config Author=LMHz
Cores=0
Tests=16
Time (%)=100
Cycles=3
Language=0
Test Sequence=4,12,2,7,9,1,14,15,2,10,11,1,5,13,2,12,4,1,9,7,2,15,14,1,13,5,2,3,1,8,2
[Global Memory Setup]
Channels=2
Interleave Type=1
Single DIMM width, bits=64
Operation Block, byts=64
Testing Window Size (Mb)=1024
Lock Memory Granularity (Mb)=16
Reserved Memory for Windows (Mb)=128
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=653
WindowPosY=397
[Test0]
Enable=1
Time (%)=100
Function=RefreshStable
DLL Name=bin\MT0.dll
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=0
[Test1]
Enable=1
Time (%)=250
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test2]
Enable=1
Time (%)=250
Function=MirrorMove128
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test3]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
Test Block Size (Mb)=4
[Test4]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test5]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test6]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test7]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=8
[Test8]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x88888888
Pattern Param1=0x88888888
Parameter=0
[Test9]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test10]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=1
[Test11]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test12]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test13]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test14]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=16
[Test15]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
4) anta777 Extreme1 (Quelle)
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=Extreme1
Config Author=anta777
Cores=0
Tests=16
Time (%)=500
Cycles=3
Language=0
Test Sequence=4,6,1,12,2,4,12,2,5,7,1,13,2,5,13,2,8,9,1,14,2,8,14,2,10,11,1,15,2,10,3
Channels=2
Interleave Type=1
Testing Window Size (Mb)=1408 ; еще лучше установить 1536 но не во всех железных конфигах получится
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=63
WindowPosY=124
[Test0]
Enable=1
Time (%)=100
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test1]
Enable=1
Time (%)=20
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test2]
Enable=1
Time (%)=100
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test3]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0x1E5F
Pattern Param1=0x45357354
Parameter=256
[Test4]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test5]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test6]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test7]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test8]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Parameter=0
[Test9]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x2305B
Pattern Param1=0x97893FB2
Parameter=2
[Test10]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x98FB
Pattern Param1=0x552FE552
Parameter=0
[Test11]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0xC51C
Pattern Param1=0xC5052FE6
Parameter=2
[Test12]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test13]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
[Test14]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0xB79D9
Pattern Param1=0x253B69D4
Parameter=256
[Test15]
Enable=1
Time (%)=100
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x2305A
Pattern Param1=0x1789AB54
Parameter=256
5) anta777 absolute (Quelle)
Serj
testmem.tz.ru
serj_m@hotmail.com
[Main Section]
Config Name=ABSOLUT(01102021)
Cores=0
Tests=16
Time (%)=1250
Cycles=3
Language=0
Test Sequence=1,4,6,15,3,2,7,15,5,2,8,15,4,2,9,15,3,2,10,15,5,2,11,15,4,2,12,15,5,14,15
Channels=2
Interleave Type=1
Testing Window Size (Mb)=1536
Lock Memory Granularity (Mb)=64
Reserved Memory for Windows (Mb)=512
Capable=0x0
Debug Level=7
[Window Position]
WindowPosX=400
WindowPosY=400
[Test0]
Enable=1
Time (%)=8
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test1]
Enable=1
Time (%)=240
Function=SimpleTest
Pattern Mode=2
Pattern Param0=0x77777777
Pattern Param1=0x33333333
Parameter=0
[Test2]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=1
Pattern Param0=0
Pattern Param1=0
Parameter=0
[Test3]
Enable=1
Time (%)=20
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=2
[Test4]
Enable=1
Time (%)=20
Function=MirrorMove
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=4
[Test5]
Enable=1
Time (%)=20
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=1
[Test6]
Enable=1
Time (%)=240
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test7]
Enable=1
Time (%)=120
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test8]
Enable=1
Time (%)=60
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test9]
Enable=1
Time (%)=30
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=32
[Test10]
Enable=1
Time (%)=16
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=64
[Test11]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=128
[Test12]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=256
[Test13]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
Test Block Size (Mb)=512
[Test14]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=0
[Test15]
Enable=1
Time (%)=8
Function=SimpleTest
Pattern Mode=0
Pattern Param0=0x0
Pattern Param1=0x0
Parameter=256
3.2. RightMark Memory Analyser (2008)
Homepage: RightMark Memory Analyzer. Products. CPU Rightmark
Typ: Windows Anwendung, Open Source
Before this test packet was created there was no proper software for measuring vital system parameters such as CPU/Chipset/RAM providing steady and reliable (reproducible) test results and allowing for changing test parameters in a wide range. Vital low-level system characteristics include latency and real RAM bandwidth, average/minimal latency of different cache levels and its associativity, real L1-L2 cache bandwidth and TLB levels specs. Besides, these aspects are usually not paid sufficient attention in product technical documentation (CPU or chipset). Such test suite, which combines a good deal of subsets aimed at measuring objective system characteristics, is a must have for estimating crucial objective platform parameters.
3.3 TechPowerUp Memtest64
Homepage: MemTest64 - Memory Stability Tester
Hardwareluxx Sammelthread: [Sammelthread] TechPowerUp MemTest64 (Windows XP/Vst/7/8/10)
TechPowerUp Memtest64 is a free lightweight, standalone utility that lets you check your system memory for problems at the hardware-level. It has a graphical interface, and can be run from within Windows.
Features
  • Runs on Windows XP, Vista, Windows 7, Windows 8, Windows 10. 64-bit OS only
  • Supports all modern processors, including Intel Core and AMD Ryzen
  • No reboot or DOS-mode required
  • You can control how much memory to test, to reduce operational impact
  • Memory is tested using various detection algorithms
  • Errors will be detected automatically
  • Does not require Administrator privileges
  • No installation or registry modifications required
attachment.php
Corsair Vengeance RGB CMR32GX4M4C3000C15 - XMP - MemTest64 V1.0 - 26 loops.png
Link zum Vorgänger-Thread (aus 2007): Speichertestprogramme Übersicht
NEW!!! DRAM Calculator for Ryzen™ 1.4.1 (overclocking DRAM on AM4) - Page 432 - Overclock.net - An Overclocking Community
TM5 0.12 v3 config
TM5 – Google Drive
* 2 new test added
Danke, ist hinzugefügt.
Hallo, ich teste gerade (auf die Schnelle) mit Karhu Ramtest. Über Nacht würde ich gerne entweder über das Windows-eigene Tool testen lassen oder ein anderes über USB-Stick.
Ist das windows-eigene Programm Zeitverschwendung oder ist es brauchbar?
System: Broadwell-E mit versucht niedrigen Cache und Speicherspannungen.
Es ist dann auch 10h Passmark Memtest geworden. Keine Fehler. Jetzt teste ich mit Spielen und ob er Kaltstarts sauber hinkriegt ohne Hänger.
Gibt es eigentlich eine Möglichkeit z.B. durch Einstellungen der Test Methodik heraus zu finden ob es Cache oder RAM Fehler sind?
z.B. die Größe der Test Blöcke wie bei Prime95.
Unterscheiden die Test Programme zwischen RAM, IMC und Cache oder wird das in der Fehlermedlung ersichtlich wo genau der Fehler liegt?
Meiner Erfahrung nach sind GPGPU und openCL von der Auslastung her "aggressiver" als die Test Programme.
Zur Zeit nutze ich PrimoCache, damit wird der RAM als L1 Cache für die Datenträger genutzt, es sind ständig 22GByte belegt bei mir.
Edit: sieht dann so aus: https://abload.de/img/primocache_22gbyte9okmx.jpg
Hey Leute,
welche Settings unter "Advanced" soll ich nutzen bzw. nutzt Ihr?
Alles auf Default uns "Stress FPU" OFF/ON?
Danke im vorraus. :)
Ich nehme an du meinst Karhu??
CPU cache: Enabled
RNG: Default
Stress FPU an, wenn du CPU noch mit stressen willst.
Oh Sorry, ja ich meine Karhu RAM Test.
Alles klar, dann weiß ich was ich zu tun habe -Danke Dir. :)
Es gibt eine aktualisierte version von MaxxMem². Das ist dann nicht mehr das Preview sondern eine Finale so wie es aussieht. Aktuelle Version ist v3.00.23.24.
Das gute Teil erkennt jetzt auch 32 GB, Win10 und modernen RAM. Also ich kann's besonders empfehlen für die Durchführung von Leistungstests. Benutzt habe ich es bisher um die Leistungsunterschiede zwischen verschiedenen Ram Geschwindigkeiten (Mhz) und Timings zu messen (CL). Nehmt es am besten mit auf. Ich habe sehr lange danach gesucht und hätte mir eine Menge Zeit erspart, wenn es hier mit erwähnt gewesen wäre :)
Link: MaxxMem²
Bisher geht es hier im Thread nicht um Performance-, sondern eher um Stabilitäts-Tests. Wenn es entsprechendes Feedback aus der Community gibt, wäre ich aber bereit den Thread auch noch in der Richtung zu erweitern.
ps: Aber nachdem MaxxMem/Pi in der Vergangenheit durch Malware/Adware aufgefallen sind, würde ich empfehlen Downloads von der Seite immer mit Virustotal gegen zu prüfen.
Vielen Dank für diesen Thread und die beiden Vorschläge zu
Karhu RAM Test und TestMem5.
Habe Probleme 32GB DDR4-4000 CL17-17-17 stabil zum laufen zu bekommen.
Das interessante die o.g. Programme in anfangspost finden eigentlich keine Fehler,
aber sobald ich mit Marcium Reflect Home ein Backup erstelle und dieses überprüft wird
gibt es Differenzen.
TestMem5 war jetzt als einzigstes Programm in der Lage bereits in 7 Minuten Fehler zu finden,
wo ich fast gedacht hätte "es müsste eigentlich jetzt laufen).
Habe jetzt die Holzhammer Methode angewendet:
CPU VCCIO 1,250V
CPU System Agent Voltage auf 1,250v
(Das Asus Board gibt auf Auto über 1,4xv!).
und bis jetzt toi toi toi!
Edit: doch nicht... :P
Hallo, ich möchte hier noch RealBench 2.56 vorschlagen:
RealBench Leaderboard V2 | ROG - Republic of Gamers Global
Das Tool ist zwar eher ein "normaler" Stresstest aber schien bei mir genau DA die Fehler zu finden,
warum bei mir Macrium Reflect Home Backups beim verify CRC Error zeigte (hab meist 3x hintereinander Backups gemacht - da manchmal Macrium auch durchlief)!
Das Tool rendert und vergleicht die Hash Werte miteinander, relativ schnell kam ich so an Fehler!
Witzigerweise brachte Asus am nächsten Tag ein neues Bios update (v1302 für ROG MAXIMUS XI HERO)
welches schlagartig alles änderte:
32GB DDR4-4000 Mhz CL17-17-37-2N
Mode: 1
DRAM Voltage 1,35v
CPU VCCIO Voltage 1,05v
CPU System Agent Voltage: 0,975v
lief nun 8 Stunden RealBench durch und Karhu RAM Test läuft seit über 11 Stunden und 9510% coverage.
Stress FPU hatte ich deaktiviert da experimental
CPU Cache & RNG auf: Default
Realbench kenne ich gut, da ich es auch selbst lange Zeit für meine User Reviews verwendet habe. Als reiner Speichertest ist es aber meiner Meinung nach eher ungeeignet, auch wenn einzelne Tasks durchaus Speicherfehler aufdecken können. Ich habe bei meinen Tests damit etliche durch instabile Speichereinstellungen verbuggte Runs gesehen. Während es manchmal sofort am Ergebnis auffällt, weil dieses viel höher ist als es sein sollte, so gab es darunter auch unauffälligere.
Speicher mit Benchmarks zu testen aber durchaus nicht neu, entsprechende Empfehlungen findet man auch zu PCMark, 3DMark und Co. Hier im Thread sollte es aber primär im Programme gehen, deren Hauptfunktion der Speichertest ist.
Alles Klar!
Neue Erkentnisse:
RealBench lief stabil durch (8 Stunden) / Karhu RAM Test (lief über 12 Stunden durch mit über 10.000% coverage).
Dass gleiche hatte ich "eigentlich" von HCI MemTest auch erwartet - ABER:
Memory error found copying between 0xecb793e8, 0x50d28b68, difference =100
bei 811,6% coverage (hatte die Option ausgewählt dass er den ganzen Speicher testen soll und öffnete hierbei 10 Instanzen (9900KF).
D.h. jetzt aber nur das eine Instabilität vorliegt - richtig?
Edit:
Memory error found copying between 0xc09103ec, 0x25b40108, difference =1000 (jetzt hat HCI bei 43% schon angeschlagen.
Dein Setting ist bestimmt stabil, du machst da bei HCI taktische Fehler.
Pro Thread soll bei HCI ene Instanz gestartet werden. Also beim 9900k 16 Instanzen.
Dann der Totalfüllgrad. Beim Memtest soll ein Totalfüllgrad von 80% des Rams nicht überschritten werden. Ab 80% Füllstand beginnt Windows auszulagern und das sollte während eines Memtestes nicht sein. Bei 16GB test ich 12GB und mach sonst nix am PC während dessen.
@meckswell
Eigentlich hatte das immer gut funktioniert - hatte ne Batch Datei geschrieben für 32GB:
@echo off
CD C\MemTestDeluxe\
start memtestpro /t1875
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
CD C\MemTestDeluxe\
Jetzt bei der 6.4er Version und 64GB habe ich es auch beobachtet das HCI auf 80% limitiert und die Werte gegenenfalls nach unten korrigiert.
a propos hci memtest: habt ihr für die neue version ebenfalls alan anschreiben müssen und ihn damit um einenink für die neue paid version gebeten, weil sie auf der homepage als käufer nicht herunterladbar ist, ohne den kaufvorgang nochmal anzustoßen? da fehlt imo eine registrierung, ein account, über den das als kâufer selber geregelt werden kann.
Das "Problem" hatte ich auch. Alan anschreiben, er wird den ursprünglichen Downloadlink verlangen und Dir dann einen neuen schicken.
Momentan ist aber unterwegs und kann mir die neue Version erst am Anfang Januar schicken (bzw. den Link).
Ich möchte gerne den Ram mit dem Stressapptest prüfen. Die meisten hier machen es unter Windows mit Ubuntu als Subsystem. Aber das möchte ich nicht. Da ich mich mit Linux Null auskenne, benötige ich Hilfe. Ich möchte das vom USB Stick laufen lassen.
Könnte jemand eine kleine Anleitung, eine Anleitung, die auch für einen Laien verständlich nachvollziehbar ist, schreiben? Also wie das geht, Linux bootbar auf den Stick zu bringen, Stressapptest zu installieren und die nötigen Befehle für Stressapptest, um den Ram zu testen?
Das wäre super.
Edit: Mein Wlan Adapter geht nicht unter Linux, hat sich also erledigt.
Startbeitrag für XenForo angepasst.
Hallo Leute.
Frage: Ist es problematisch, wenn an einen HCI-Run durchführt und im Hintergrund (Autostart) ein Tool namens "Intelligent Standby List Cleaner (ISLC)" läuft?
Intelligent Standby List Cleaner" ist ein überaus praktisches schlankes Tool, das Ihren RAM-Speicher freiräumt, um so für ein besseres Spielerlebnis zu sorgen.
Also eigentlich kann Windows den RAM ganz gut selber managen.
Was dein Programm macht ist von Windows als inaktiv erkannte Programme schließen wenn deren Gesamtkapazität einen eingestellten Schwellenwert überschreitet. Was Windows macht wenn du Platzprobleme bekommst ist den Müll auszulagern/ komprimieren etc. Wenn du ne SSD mit DDR3 cach hast sollte das eigentlich nur in Ausnahmesituationen vorkommen dass es ruckelt. Ich weiß nicht wie die Testprogramme funktionieren, da memtest ja aktiv ist. Ich empfehle aber generell alle möglichen Programme beim Testen zu deaktivieren, alleine schon der Ressourcen wegen.
Soweit Prinzipiell. Allerdings kann alles was mit dem Speicher spielt auch Fehler hervorrufen. Musst dir also schon sicher sein können, dass der Fehler den du siehst auch durch Timings und nicht durch irgendwelche Zwischenfunker kommt. Es wird ja getestet, ob der RAM Daten halten und verarbeiten kann. Im zweifel lieber aus.
@BF2-Gamer Das Programm / den Hintergrundprozess würde ich für einen HCI-Testlauf beeenden/anhalten.
memtest86+ lebt, nach 6,5 Jahren wieder ein Update auf v5.31b. Grad auf Computerbase entdeckt.
Danke für den Hinweis! :wink:
Edit, laut Hersteller-Webseite: "After a long hiatus without updates and following numerous requests, I've started compiling many codes branches to release public builds again! Here is Memtest86+ 5.31b, with many bug fixes in the core functions. This build is not ready for production yet, because it lacks some feedbacks from beta-testers. Additional features and updated detection code will follow soon, as soon I have access to my lab with all the reference test platforms. It's currently inaccessible due to the COVID19 lockdown. If you find a bug or regression in this build, please send your feedback to memtest (-A-) memtest.org. Thank you!"
Ich werde das Update einpflegen sobald die Version einen offizielleren Status besitzt.
@emissary42 Es gibt Probleme mit HCI 7.0 Freeversion im Zusammenspiel mit dem Memtesthelper 2.2.0. Man startet den Helper, gibt seine Rammenge ein und drückt Start. Nach ca. 2 Sekunden geht der Memtesthelper komplett aus. Das war früher nicht. Der Helper is auch EOL hab ich gesehen.
Wollt nur Bescheid geben, dass das auftritt.
Strike ich hab die Ursache und Lösung gefunden. Es liegt an HCI 7.0. Ich hab noch eine ältere HCI-Version gefunden 6.1, da verhält sich der Helper ganz normal. Da haben die HCIler wohl in 7.0 was eingebaut, dass der Helper unkomfortabel wird. Aber mit 6.1 alles gut.
Ja, das ist wohl ein bekanntes Problem und war der Grund dafür, warum es keine Updates für den Helper mehr geben wird. Im Github-Rep ist auch eine Nachricht dazu vom Entwickler. Ich hab einen Hinweis im Startbeitrag hinzugefügt.
