Star Swarm Benchmark
joergera
bei Köln
habe eben bei Steam den "Star Swarm Benchmark" gefunden.
Ist sogar kostenlos. ;)
Habe es direkt mal getestet.
1x DirectX
1x Mantle:
MIT Motion Blur: 47,82 Average FPS:
Oxide Games
Star Swarm Benchmark - ©2013
C:\Users\Christian\Documents\Star Swarm\Benchmark_14_01_31_1706.txt
Version 0.95
01/31/2014 17:06
== Hardware Configuration =================================
GPU: NVIDIA GeForce GTX TITAN
CPU: GenuineIntel
Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Physical Cores: 4
Logical Cores: 8
Physical Memory: 17134678016
Allocatable Memory: 8796092891136
== Configuration ==========================================
API: DirectX
Scenario: ScenarioAttract.csv
User Input: Disabled
Resolution: 1920x1080
Fullscreen: True
GameCore Update: 16.6 ms
Bloom Quality: High
PointLight Quality: High
ToneCurve Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Motion Blur Frame Time: 16
Motion Blur InterFrame Time: 2
Detailed Frame Info: Off
== Results ================================================
Test Duration: 120 Seconds
Total Frames: 5739
Average FPS: 47.82
Average Unit Count: 3767
Maximum Unit Count: 5449
Average Batches/MS: 916.40
Maximum Batches/MS: 2103.97
Average Batch Count: 20151
Maximum Batch Count: 143089
OHNE Motion Blur: 99,36 Average FPS:
Oxide Games
Star Swarm Stress Test - ©2013
C:\Users\Christian\Documents\Star Swarm\Output_14_02_02_1520.txt
Version 1.00
02/02/2014 15:20
CPU: GenuineIntel
Physical Cores: 4
Logical Cores: 8
API: DirectX
Scenario: ScenarioFollow.csv
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Deferred Contexts: Disabled
Temporal AA Duration: 16
Temporal AA Time Slice: 2
Test Duration: 360 Seconds
Total Frames: 35769
Average FPS: 99.36
Average Unit Count: 4815
Maximum Unit Count: 6520
Average Batches/MS: 337.50
Maximum Batches/MS: 1393.95
Average Batch Count: 3897
Maximum Batch Count: 19587
Specs: i7-3770K @ Standard, GTX Titan @ Standard, 16 GB DDR3-1600 @ 11-11-11-28 2T.
Motion Blur "An" oder "Aus" knallt also ganz schön rein!
