[Übersicht] Ultimative AM4 UEFI/BIOS/AGESA Übersicht
Asus Prime X470-Pro:
6042 scheint jetzt auch final zu sein. Quelle Asus:
Inzwischen haben wohl alle Asus B550 Boards die finale Version des BIOS 2803 erhalten...
PS.: Habe noch einmal nachgesehen: Auch die anderen Chipsätze auf den Aus Mainboards haben jetzt durchgehend finale BIOS-Versionen.
Großes Beta Update bei Asrock
ModelVersionDateDescriptionDownload
L1.826/13/2022
Update AMD AM4 AGESA Combo V2 PI 1.2.0.7​
Download
L2.116/13/2022
Download
L2.116/13/2022
Download
L1.926/13/2022
To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU​
Download
L2.226/13/2022
Download
L2.226/13/2022
Download
L2.226/13/2022
Download
L2.226/13/2022
Download
L2.316/13/2022
Download
L2.226/13/2022
Download
L2.126/13/2022
Download
L2.126/13/2022
Download
L2.326/13/2022
Download
L2.116/13/2022
Download
L1.926/13/2022
Download
L3.916/13/2022
*To support Renoir/ Ryzen™ 5000 processors, it requires to update the BIOS with Matisse CPU.
*To support Ryzen 5000 G-series processors, it requires to update the BIOS with Matisse, Renoir or Vermeer CPU.​
Download
L3.916/13/2022
Download
L2.026/13/2022
*ASRock do NOT recommend updating this BIOS if you are going to use Pinnacle, Raven or Summit Ridge CPU on your system.
*Before updating this BIOS, please also read the description in previous BIOS version.
Download
L4.356/13/2022
Download
L4.356/13/2022
Download
L4.826/13/2022
*If you use Pinnacle Ridge or Picasso, please use ASRock Flashback function to update this BIOS.​
Download
L3.916/13/2022
Download
L3.916/13/2022
Download
L4.826/13/2022
Download
L1.736/13/2022
Download
AMD over the weekend reportedly released the AGESA V2 PI 1.2.0.7 microcode to motherboard vendors and PC OEMs. This particular version of AGESA gains importance to those on Windows 11, as it corrects a performance-stuttering issue caused due to frequent polling of the fTPM by the OS. The new version of AGESA is also bound for AMD 300-series chipset motherboards, where it adds official (stable) support for Ryzen 5000 series processors, letting those on the 5-year old platform enjoy an IPC uplift as much as 60% (Zen 3 vs. Zen). 1.2.0.7 is also rumored to address certain stability issues with the Ryzen 7 5800X3D, and enables BCLK overclocking on the chip, as long as the processor doesn't draw more than 1.35 V in the Vcore voltage domain. It's now over to the motherboard vendors and PC OEMs, to encapsulate 1.2.0.7 with their firmware and release to end-users.
Quelle:
ist das Beta Bios fürs Taichi wieder verschwunden? Ich kann nichts finden, letztes Beta ist das L4.65
Mfg
macom
Quelle:
Vielleicht packt es Gigabyte ja dann auch irgendwann mal nen finales UEFI damit zu releasen.
Die Hoffnung stirbt zuletzt.
Ich hoffe immernoch auf eine Uefi Version ohne Probleme. Bis jetzt vergebens. Aber wer weiß die Kenobi Episode heute war immerhin okay, vielleicht lohnt es sich zu hoffen. XD
MSI MAG X570 Tomahawk WIFI BIOS:
7C84v1A
- Update to AGESA ComboAm4v2PI 1.2.0.7.
- Change the default setting of Secure Boot.
  • Danke
Reaktionen: MDG
Wann sollten die USB Abbrüche gefixt worden sein? Ich wollte Grade Bilder vom Handy ziehen und das war eine 8 stunden Sache.... Manche kann ich gar nicht ziehen weil dann alles zusammenbricht...
Oft hilft es die SOC (IO-Die) Spannungen anzupassen.
Schon ewig... Bios Updates helfen
@rossi94
Weißt du noch bei welchen Boards das war? Kann mich selber nämlich nicht erinnern das irgendwo gesehen zu haben.
@rossi94
Habe das gestern zufällig im PCper Podcast aufgeschnappt. Die haben noch keinen Artikel / Links zu 681 online - vielleicht steht es auch nicht im Changelog.
Thema ist es aber auf jeden Fall, hier wird es z.B.: auch angesprochen: (Hoffentlich ist das Thema mit 1.2.0.7 endlich durch). Ich habe selbst auch Aussetzer mit 1.2.0.5.
Moin, das Thema USB wird immer wieder mal etwas verbessert, ist aber nicht vom Tisch. Ich hatte seit diesem Wochenende 2 Aussetzer und jetzt gerade beim Schreiben, wie der Zufall es will, auch einen kurzen. Trotz Combo 1.2.0.7. Glücklich denen, die verschont werden. ;)
Hallo.
Ich habe wo anders gelesen das B550 USB-Probleme haben soll, stimmt das, wenn ja welche sind es, oder wurden sie schon behoben?
Ich habe kürzlich ein B550 gekauft und keine Probleme festgestellt, GIGABYTE B550 AORUS Elite V2, mit aktuellster BIOS Version (AGESA 1.2.0.7).
MfG
Ich glaube es liegt wirklich an den soc Spa
also ich habe das MSI x570 creation und habe keinerlei usb probleme mehr mit 1.2.0.7 bis jetzt für mich das beste uefi läuft super stabil
Oft wird es in der Hitze schlimmer, liegt denke ich an den SOC Voltages. Wenns kälter ist braucht man weniger Spannung, dann merkt man nix.
Ich denke auch, dass es mit höherem Fabric Takt häufiger Auftritt.
Und schon wurde die AD3 Datei gelöscht. Hat jemand ein Backup?
Genau die lässt sich eben nicht mehr herunterladen, da der Eigentümer die Datei in den Papierkorb gepackt hat.
Also ich kann die Downloaden (y)
Lässt sich bei mir nicht herunterladen.
Habe ich gerade Runtergeladen:
Ich habe die Datei als .zip gepackt kann sie aber nicht hochladen weil sie 17,5 MB groß ist.
