Was habt ihr in der Zwischenablage?! 3
Give a man fire and he will be warm for a while.
Set a man on fire and he will be warm for the rest of his life.
Das Internet ist für uns alle Neuland
Sniper
Ist schon ein echter komiker der Spieler von den gelb-roten ;)
iptables -t nat -A PREROUTING -i wlan0 -p tcp --dport 80 -j REDIRECT --to-ports 3128
1. Go to Steam Library
2. Go to "Arma 3" Right Click then select "Properties"
3. Select "Set Launch Options"
4. Copy and paste the correct launch command line below to what your system is setup for and click "OK".
For AMD CPU users:
AMD Dual Core with 4GB System Ram:
"-noSplash -cpuCount=2 -high"
AMD Quad Core with 4GB Ram:
"-noSplash -cpuCount=4 -high"
AMD Six Core with 4GB Ram:
"-noSplash -cpuCount=6 -high"
AMD Eight Core with 4GB Ram:
"-noSplash -cpuCount=8 -high"
______________________________________________
If your running more than 8GB Ram then apply this to the end of the launch line:
"-maxMem=8192"
This will allow your game to utilize 8GB system Ram instead of 4GB.
Intel CPU:
For Hyperthreaded CPU's such as a Quad Core you will apply this:
-cpuCount=8
This will enable your Hyperthreads on your CPU so your CPU will act as an eight core when running Arma 3.
If you are running a Hyperthreaded Six Core then:
-cpuCount=12
If you are running a Hyperthreaded Eight Core or Eight Core Xeon then apply this:
-cpuCount=16
If you are running just a non Hyperthreaded CPU such as a Quad Core then select "4" instead of "8" same for a Dual Core you will select "2" instead of "4".
All AMD CPU's are NOT Hyperthreaded so Hyperthreaded options is highly not recommended as this can cause system failure or damage.
I will not be responible for system failure and damage if you choose to select more cores then you have on your command line!
-high:
makes your operating system prioritize services and processes to run your game better but this can cause system failure and instability if you dont have a good running system. If you Overclock this can cause system instability.
-noSplash:
disables startup videos and advertisements.
-cpuCount=#:
enables extra CPU cores and Hyperthreads.
-maxMem=#:
when set to "6144" (6GB) and up lets your game use more system Ram then 4GB.
Do not set to higher than 4GB if you dont have at least 8GB. You can set to "8192" (8GB) if you have 12GB+ Ram.
Wenn der Einzelunternehmer ein Kaufmann ist, muss seine Firma (der Name des Unternehmens) die Bezeichnung "eingetragener Kaufmann" oder "eingetragene Kauffrau" oder "e. K." oder "e. Kfm" oder "e. Kfr" enthalten. Andernfalls kann der Inhaber den Namen seines Unternehmens — nach den Vorschriften der Gewerbeordnung — frei wählen.
Kid, ich bin der Mac in diesem Business und ticke dicke Packets an die Kids
Step mit der glitzernden Kette in den Club, zerre deine Bitch auf Toilette
Und ficke dann den arroganten Blick aus der Fresse
Du holst dir mein Album und sagst, ich bin der Beste
Doch ich dreh' mit deiner Mutter Porn-Tapes
Komm in deine Villa mit der Basy, gebe deinem Body Punches
Alle deine Rippen zerbersten wie Cornflakes
Gesendet von meinem GT-N7100 mit der Hardwareluxx App
