SAVRAYO
Profi
Hi guys.
I want to buy an m.2 drive for my pc and I'm a bit lost.
I have an asus maximus xii apex (Z490) which doesn't have PCI EXPRESS 4.0. My cpu is an i9 10900K
The 3 options are:
1) 7400MB/s
XPG GAMMIX S70 BLADE PCIe Gen4x4 M.2 Up to 7400MB/s
www.xpg.com
2)5000MB/s
Teamgroup CARDEA ZERO Z440 M.2 PCIe SSD Read/Write: up to 5,000/4,400 MB/s
www.teamgroupinc.com
3) 3,900MB/s
ADATA PG GAMMIX S50 Lite PCIe Gen4x4 M.2 2280 Up to 7400MB/s 3900MB/s
www.xpg.com
Option 1 (7400MB/s) won't work at that speed on my platform because it doesn't have pci express 4.0?
Will option 2 (5000MB/s) work at 5000MB/s speed on my platform?
So if I buy any of the 3, will they all work at the same maximum speed?
So which one should I buy?
Will I find speed improvement compared to my current ssd: SAMSUNG evo 850 and evo 840?
My idea is to use it with ROG DIMM.2.
I appreciate the responses!
Thanks.
The 3 options are:
1) 7400MB/s
ADATA
XPG Gaming GAMMIX S70 BLADE PCIe M.2 NVMe SSD with the latest PCIe Gen4 interface, it will help you dominate the competition with sequential read/write performance of up to 7400/6800/MB per second.2)5000MB/s
CARDEA ZERO Z440 uses the latest and fastest PCIe Gen4 x4 interface and complies with the NVMe 1.3 standard. The sequential read/write speed can reach a whopping 5,000/4,400 MB/s.
3) 3,900MB/s
ADATA
ADATA ProductOption 1 (7400MB/s) won't work at that speed on my platform because it doesn't have pci express 4.0?
Thanks.
