Wichtig ! @Sonoma und Napa Notebookbesitzer (USB Problem)
dröfl
Semiprofi
D4rkCloud schrieb:
Ansonsten ist abzuwarten, ob Windows oder Intel das Problem in den griff kriegen.
Selbst ist der Mann (man kanns ja mal versuchen):
Warning: Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. To resolve this problem, add the EnIdleEndpointSupport entry to the USB registry key. To do this, follow these steps:
1. Click Start, click Run, type regedit, and then click OK.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\USB
Note: If the USB subkey does not exist, create it. To do this, follow these steps:
a. Select the Services key. On the Edit menu, point to New, and then click Key.
b. Type USB in the New Key #1 box to name the new key "USB."
3. Right-click USB, point to New, and then click DWORD Value.
4. In the New Value #1 box that appears, type EnIdleEndpointSupport, and then press ENTER.
5. Right-click EnIdleEndpointSupport, and then click Modify.
6. In the Value data box, type 1, leave the Hexadecimal option selected, and then click OK.
7. Quit Registry Editor.
Resultat (usb 2.0 aktiv):
Aber da das Asus A6JA eine integrierte Kamera hat und diese über usb 2.0 die ganze Zeit connected ist ... :rolleyes: :d
"Adding an external USB 2.0 device to either ASUS notebook does result in an additional drop in battery life, but the initial damage is done by the integrated camera that you can't unplug. To truly isolate this problem, we'll need two notebooks that don't have any integrated USB 2.0 devices, which is why we turned to the Lenovo Thinkpad T43 and T60."
Quelle: anandtech.com
P.S: Es geht mur um USB 2.0 nicht um USB 1.0/1.1 Geräte. (aber natürlich auch um den Ruhestand)
Ausserdem sieht man das es auch bei Sonoma Plattform was bringt und nicht nur an der Napa Plattform:
So far, it is looking like this is not a Core Duo problem and indeed a problem that affects all Intel systems at least.
Zu guter letzt: Microsoft ist ne Blödbacke
Wollts hier nur mal extra posten ,weil es sonst untergeht.
Ihr könnt es mal testen,have fun.
€dit: Es kann sein das man ne Batch Datei schreiben muss (bis windows das hotfix herausbringt),weil laut cb (anadtech hab ich nur überflogen) das Notebook wieder Saft zieht sobald man aus dem standby wieder usb 2.0 Geräte anschliesst. Soll anscheinend nur ein Restart helfen.
Es funktioniert macht es...
Hab bei mir jedoch noch die Kamera im Gerätemanager deaktiviert...
Bevor ich in meiner Registry rumbohre...worum geht es und was tut diese Änderung genau?
es geht um das problem mit der akkulaufzeit wenn man ein usb gerät angeschlossen hat und die registry änderung behebt dieses problem anscheinend ;)
Das hab ich mitgekriegt ;)
Nur, bin als Sonoma User betroffen oder nicht? Und was genau tut dieser Fix?
Einfach mal den ersten Beitrag lesen ;)
