[Sammelthread] Wreckfest
Gestern BeamNG viel gespielt nachm Update. Bissl in Stimmung gekommen, falls das Spiel mal so für max 15€ zu haben ist, gebe ich dem nochmal nen Versuch...
Erster Season Pass Content ist erschienen
Der Season Pass richtet sich doch nur an Spieler die das game noch suchten und für jeden weiteren Content bezahlen, egal wie groß oder klein die DLCs sind.
Bugbear hat schon vor 2 Jahren aufgehört das Spiel weiterzuentwickeln und denn Moddern das Spiel überlassen.
Das ist doch Unsinn.
Ein Blick in die Changelogs und Update Historie reicht um das festzustellen.
Holiday Update released!
Holiday Update released! | Bugbear Community
HIGHLIGHTS
  • Two new tracks: Hellride & Vale Falls Circuit
  • Event voting in multiplayer
  • Player hosted public servers
  • Car customization in multiplayer lobby
  • Visualization for cars that just have been reset
  • Ragdoll can now be reset after driver was ejected
  • Support for DLC Modified Monsters Car Pack
  • Various stability & performance improvements
Update for Rusty Rats Car Pack DLC now available!
We're pleased to announced the availability of the new exciting DLC: Rusty Rats Car Pack!
To coincide with the DLC launch, we've also taken the opportunity to update the game to the latest version on all platforms to bring forth the latest bug fixes and quality of life enhancements, including a number of critical improvements to online functionality. For full information on the latest update please check out the full release notes of the patch below.
DETAILED RELEASE NOTES
Game version
  • Xbox: 1.2.0.3
  • PS4: 1.23
  • PC: 1.255957
CONTENT
  • Added support for DLC Rusty Rats Car Pack.
MULTIPLAYER
  • Increased robustness of the console window.
  • Server no longer crashes when "%" character is used anywhere in a message or a username.
  • All vehicles are no longer shown as "Not Eligible" for the host if "Host's Car" car restriction is set.
  • UI is now correctly handled whenever player is kicked while in the lobby sub menus.
  • AI now correctly uses the difficulty settings as set in the lobby options.
  • (XB1/PS4) Clients can no longer join a server if the owner has already quit.
  • (PC) AI difficulty can be now configured in the dedicated server settings.
  • (PC) Clients are now given more time to load the cars during the countdown, reducing lag spikes in the lobby.
GAMEPLAY
  • Reset effect (car flickering) can now be enabled/disabled in the Settings, Gameplay menu.
  • On Hellride, it should be no longer possible to drive on top of the steel mesh and cause the game to glitch out.
  • On Big Valley Speedway Figure 8, it's no longer possible to cut the first lap short.
  • Track surface information is now correctly displayed for Vale Falls.
  • Added release delay to digital clutch to prevent shifting exploit (previously you could shift instantly, giving unfair advantage).
  • In derby events, AI now has better awareness of the arena boundaries, reducing the chance of it smashing blindly into barriers.
  • AI now uses Roadcutter in Class A.
  • 1st person camera angles now work correctly on Bugzilla.
  • Exhaust backfire effect now works correctly when "Big Headers" are equipped for Starbeast.
  • Improved Wardigger suspension setups.
AUDIO
  • Replaced the engine audio for Hornet.
  • Loudness balancing of vehicle engine audio.
  • 5.1 surround mixdown and 3D attenuations adjusted for more precise spatial positioning of ai vehicles.
  • Adjusted concrete wall collision effect asset design to match game engine implementation.
SYSTEM
  • Fixed a rendering issue that resulted in the skidmarks flickering occasionally.
  • Fixed contact effects for large vehicles such as School Bus and Motorhome.
  • The player starting credits (10 000 CR) are now correctly awarded when launching the game for the first time.
  • Credits rewarded during an online session are no longer lost when terminating the game (instead of quitting properly) while in lobby.
  • Added guards to prevent the save data from becoming corrupt.
  • (XB1X) Resolution can be now changed in the Settings menu between Full HD and 4K.
  • (PC) The game now attempts to remove the bogus read-only flag from the save data files that caused the game not to launch.
Thanks for taking the ride with us and happy wrecking!
February Update released
HIGHLIGHTS
  • Two new tracks: Thunderbowl & Tribend Speedway
We're pleased to announce the availability of a new content update!
It's been a long time since new demolition derby tracks were added to the game, and we're happy to let you know that finally derby fanatics get some love too: this content update introduces a thunderous new derby arena called Thunderbowl! This bowl-shaped arena sees the players starting higher up at either end, and making the dash of death to the middle section where total war rages. The shape and design of the arena provides fresh, electrifying gameplay experience, so even if you're not so hot about derbies in general make sure to give it a go!
And that's not all: we're also adding a race track called Tribend Speedway. It's a high-speed crash-fest that started its life in the twisted mind of the ever so industrious modder Theveryend (Tor Ole Lerbæk) and comes also with an alternate layout featuring ramps and additional obstacles, guaranteed to crank up destruction all the way to eleven.
We're also constantly working on improving the gameplay experience based on the feedback. PlayStation 4 users can finally use voice chat in multiplayer as well as enjoy reduced loading times. Also worth noting this time around is the adjustment to the launch logic at event start, bringing automatic, manual and manual clutch users to equal grounds. Please find below a summary of items fixed or improved upon in this release.
RELEASE NOTES (XB1/PS4)
Game version
  • Xbox: 1.3.0.1
  • PS4: 1.31
CONTENT
  • Added two new tracks: Thunderbowl and Tribend Speedway.
SYSTEM
  • (PS4) Added support for Voice Chat.
  • (PS4) Improved loading times by 15–25% depending on the case.
  • Game may no longer crash when selecting Raiden RS.
  • Parts of the vehicle no longer flicker when looking around in the cockpit view.
  • AI Players no longer get stuck after respawning.
USER INTERFACE
  • Fixed "Reset Effect" setting title and description being switched.
GAMEPLAY
  • Digital clutch release is now not as penalizing when shifting sloppily.
  • First gear is now engaged during the race countdown, eliminating the unnecessary gear change when using automatic transmission and making the launch equal between fully automatic, manual and manual with clutch shifting modes.
  • When using shifting modes with automatic clutch, all cars now use the faster shifter profiles in order to make cars more equal.
  • Exhaust backfire effect now works correctly when using upgrades from the Steel & Wheels pack.
  • Improved Hornet model, engine and suspension.
  • Raiden RS is now slightly weaker and maxes out slightly earlier performance-wise.
  • Increased Rebelrat maximum performance points to make it more competitive.
  • Improved Raiden RS mudflaps and a number of other panels.
  • Added an upgrade part to remove the Raiden RS front panel.
  • Fixed an issue when Raiden RS materials turned partially black when a specific exhaust part was installed.
  • Fixed Raiden RS misconfigured locked differential.
  • Fixed Raiden RS grille causing a fatal error when uninstalled.
  • Fixed Raiden RS lod model window pivot, causing the window to float above the car.
  • Fixed Vandal grille causing an error when uninstalled.
  • Fixed Vandal "Upright Side Headers" exhaust.
  • Fixed Vandal "Rallysport" tire upgrade.
  • Fixed Vandal "Hot Dog" prop name.
  • Vandal window glass now breaks correctly.
  • Vandal brake lights no longer break in tandem.
AUDIO
  • Fixed missing Venom engine audio.
  • Improved engine audio volume balancing across different cars.
  • Stationary vehicles no longer repeatedly trigger the contact sound effect.
  • Shifted audio emitter axis of AI vehicles to better match 3D sound location with visual positioning.
RELEASE NOTES (PC)
Note that PC users already received most of the improvements in the previous hotfix.
Game version
  • PC: 1.256814
CONTENT
  • Added two new tracks: Tribend and Thunderbowl.
SYSTEM
  • Fixed a crash during title launch when "Documents" folder is located on a network drive.
GAMEPLAY
AUDIO
Happy wrecking!
Tournament Update released!
HIGHLIGHTS
  • Tournament Mode
  • A new demolition derby arena: The Maw
  • Support for American All-Star Car Pack
  • Up to 80% shorter loading times
  • Stability and performance improvements
Neues 4,7GB schweres Update...
We're actively working on improving the gameplay experience based on the feedback. Please find below a summary of items fixed or improved upon in this release.
RELEASE NOTES
Game version
XB1: 1.4.0.3
PS4: 1.43
PC: 1.259651
SYSTEM
  • (PC) Game no longer crashes when quitting while vehicle mods are enabled.
  • (PC) Invalid analytics data will no longer prevent the game from launching.
  • *PC) Date stamps of conflicting files are now shown in the Steam Cloud popup.
  • (PC) Fixed a crash in the effect system when using certain mods.
GAMEPLAY/VEHICLES
  • Added upgrades for Super-Venom.
  • Fixed Super-Venom deform glitch.
  • Fixed Roadcutter rear spoiler deform glitch.
  • Fixed Speedbird tournament reward livery UV mapping bug.
  • Improved Wardigger upshift/downshift logic.
TOURNAMENT MODE
  • FP (Fame Points) earned from completed challenges should be now received correctly, even for past challenges.
  • (PC) Player can now choose to remove ineligible local result in case there's amismatch between the local and leaderboard result.
    This can occur for example due to the upload of the result failing, or in case your (cheated) result has been deleted from the leaderboard.
AUDIO
  • In-game: AI vehicle mixdown adjustments & perf improvements.
  • In-game: Initialize each AI vehicle engine sound with a range randomized pitch offset, to improve separation / uniqueness between for multiples of same vehicle.
  • In-game: Adjusted player vehicles to use similar distance-based playback prioritization sorting as AI vehicles, to address possible active voice stealing in free cam mode.
  • Big Rig / Doom Rig: Optimized DSP effect usage.
  • Roadslayer / Roadslayer GT: Fixed broken soundbank, mixdown and engine sound tweaks.
  • Hellride: Added missing position tracking to flame barrel objects for correct surround panning.
Thanks for all the feedback and happy wrecking!
Bis auf @Ak1504 posted ja hier irgendwie niemand (Selbst ich bin noch oben auf Seite 16 von 2018!).
Das Spiel ist mit Season Pass / Deluxe ja bei 31€grad im Angebot (Was ich für sehr viel halte für das Alter und lala Physik). Wie siehts da aus? Sonderlich viele Spielens ja scheinbar nicht (Im AVG 1000 Leute). Ist der MP dadurch tot?
Ich spiels ab und zu mit Kumpels am Wochenende und wir finden immer Server. Wie es unter der Woche aussieht weiß ich leider nicht ob da was los ist. Ansonsten machts immer noch Bock, je nach Server und Regeln sind auch schöne Wheel to Wheel Duelle möglich. Kann dir aber auch passieren das du einfach ohne Not abgeschossen wirst was frustrieren kann. Aber das kommt wie gesagt sehr auf den Server an, manche wollen ja auch einfach nur crashen, was auch ok ist. Zu den DLC`s kann ich nix sagen,die habe ich nicht.
Tournament Update: Banger Bash!
HIGHLIGHTS
  • New Tournament Season: Banger Bash
  • Two new free tracks: Kingston Raceway and Mudford Motorpark
  • Support for new DLC: Banger Racing Pack
  • AI Players now use DLC vehicles
XB1/PS4/PC: Version 1.6.0.2/1.62/1.265410 released
Update Released: Season 2 Starts NOW!
Hatte vorhin mal das Free Getaway Tournament gestartet und der GTR Verschnitt macht so ein Spaß zu fahren, dass ich mir das Carpack als erstes DLC für das Spiel geholt habe.
Von den Standardfahrzeugen kenne ich keins, was sich so präzise driften lässt :)
Tournament Update: Wasteland Wreckers!
HIGHLIGHTS
  • New tournament: Wasteland Wreckers
  • New free tournament reward vehicle: Battle Bus
  • Engine upgrades for many special vehicles
  • Handling improvements for special vehicles
  • Stability and quality of life enhancements
Big Update: Tournament Update: Racing Heroes
Tournament Update: Winter Fest
HIGHLIGHTS
  • New tournament: Winter Fest
  • New free reward car: Starbeast SS
  • Bug fixes and improvements
We're thrilled to announce the availability of a new tournament!
As you know, in many parts of the world it's that magical time of the year again that the white powdery stuff covers everything into its blanket. Yes, that's snow! As some of you might remember, a few years back we did a holiday special featuring snow, and since many of you have been hoping to see something similar again, we just couldn't leave you all out cold. So, sure enough winter has arrived in the Valley of Bugbear once again and during this tournament, all tracks are covered with snow! And what's even more fun is that this time we got snowballs too!
That's right: No winter would be complete without glistening snow, slippery roads, and of course, snowball fights! Since we're talking about Wreckfest here, the snowballs in the headlining tournament event "Snowball Run" are of pretty destructive type, and tossing one unleashes a whirlwind of vehicular destruction wrecking anything in its path. Let's see who's going to be the toughest snowball fighter! The sideshow events are keeping it in the spirit as well, with winter themed demolition races, demolition derbies and time attacks guaranteed to offer sideways going, sheet metal tearing wintry fun. Make sure to check them all out because awaiting the top players we have a very special prize: a wicked new tournament reward car Starbeast SS, sure to strike the right chords with the fans of the Early Access version of the car.
Besides, we're always actively working on improving the gameplay experience based on the feedback, and thus this release contains a number of additional enhancements and bug fixes. We invite you to check out the release notes below for a complete summary of items fixed or improved upon. As always, thanks for all the feedback!
RELEASE NOTES
Game version
PC:1.269477
PS4: 1.90
XB1: 1.9.0.0
TOURNAMENT
  • New tournament season: Winter Fest.
  • New free tournament reward car: Starbeast SS.
  • The DLC promotional screen is only shown once per session for each respective DLC.
SYSTEM
  • (PC) Fixed an issue which caused DualShock and DualSense controllers to not function correctly.
  • (XB1) Online features now work correctly after disconnecting the controller before the initial interactive screen.
  • (PS4) Game no longer freezes after signing out of PlayStation™Network while in a multiplayer lobby.
GAMEPLAY
  • Improved Speedie handling and engine to make it more competitive.
  • Small special vehicles no longer take excessive damage even from small shunts.
  • Rammer and Roadcutter AI Player setups are now more appropriate for their respective classes.
  • The rear spoiler of the Nexus RS "BB Racing" bundle is now parented correctly to the trunk lid.
  • Exhausts no longer get distorted after deforming.
  • Roof decorations no longer deform wildly.
  • Fixed Boomer RS taillight cover glitch.
AUDIO
  • Rebel Rat engine audio now plays correctly.
  • Fixed an issue with Stellar where clicks in sound would occur when idling in neutral gear.
  • Cockpit view audio now includes more low and mid range frequencies.
  • Audience sound effects are no longer played during loading screens.
  • In the settings, the "Interface Sound Effects" now changes volume of UI sounds independent from the "Effects" volume.
  • In the settings, the "Ambiance" volume control now affects all track-side sound sources.
Have fun!
jetzt auf Steam fuer 14,99
Spielt es noch jemand?
Lohnt sich der SinglePlayer Modus ?
Seit einigen Tagen auch im Gamepass (Xbox) und Gamepass Ultimate (PC) inkludiert...
Tournament Update: Woodland Dash
HIGHLIGHTS
  • New tournament: Woodland Dash
  • New routes for Pinehills Raceway
  • New free reward car: Hammerhead RS
  • 60fps/4K support on Xbox Series X
  • Improvements and bug fixes
Next Gen Versionen angekündigt..!
