Preis Widget muss noch umgeschrieben werden...
/var/www/sites/j4hwl/plugins/content/preisvergleich2019/preisvergleich2019.php:244:
object(mysqli_sql_exception)[62844]
  protected 'message' => string 'You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'font-family: verdana; font-size: 11px; line-height: normal; background-color: #f' at line 1' (length=226)
  private string 'string' (Exception) => string '' (length=0)
  protected 'code' => int 1064
  protected string 'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/Mysqli/MysqliStatement.php' (length=84)
  protected int 'line' => int 137
  private array 'trace' (Exception) =>
    array (size=21)
      0 =>
        array (size=5)
          'line' => int 137
          'function' => string 'prepare' (length=7)
          'class' => string 'mysqli' (length=6)
          'type' => string '->' (length=2)
      1 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php' (length=81)
          'line' => int 1089
          'function' => string '__construct' (length=11)
          'class' => string 'Joomla\Database\Mysqli\MysqliStatement' (length=38)
      2 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/DatabaseDriver.php' (length=76)
          'line' => int 1900
          'function' => string 'prepareStatement' (length=16)
          'class' => string 'Joomla\Database\Mysqli\MysqliDriver' (length=35)
      3 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/plugins/content/preisvergleich2019/preisvergleich2019.php' (length=78)
          'line' => int 239
          'function' => string 'setQuery' (length=8)
          'class' => string 'Joomla\Database\DatabaseDriver' (length=30)
      4 =>
        array (size=3)
          'function' => string 'incphp' (length=6)
          'class' => string 'plgContentPreisvergleich2019' (length=28)
      5 =>
        array (size=3)
          'line' => int 45
          'function' => string 'preg_replace_callback' (length=21)
      6 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Plugin/CMSPlugin.php' (length=55)
          'line' => int 289
          'function' => string 'onContentPrepare' (length=16)
      7 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/event/src/Dispatcher.php' (length=69)
          'line' => int 486
          'function' => string 'Joomla\CMS\Plugin\{closure}' (length=27)
          'class' => string 'Joomla\CMS\Plugin\CMSPlugin' (length=27)
      8 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/MVC/View/AbstractView.php' (length=60)
          'line' => int 312
          'function' => string 'dispatch' (length=8)
          'class' => string 'Joomla\Event\Dispatcher' (length=23)
      9 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/View/Article/HtmlView.php' (length=73)
          'line' => int 227
          'function' => string 'dispatchEvent' (length=13)
          'class' => string 'Joomla\CMS\MVC\View\AbstractView' (length=32)
      10 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/MVC/Controller/BaseController.php' (length=68)
          'line' => int 660
          'function' => string 'display' (length=7)
          'class' => string 'Joomla\Component\Content\Site\View\Article\HtmlView' (length=51)
      11 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/Controller/DisplayController.php' (length=80)
          'line' => int 121
          'class' => string 'Joomla\CMS\MVC\Controller\BaseController' (length=40)
      12 =>
        array (size=5)
          'line' => int 693
          'class' => string 'Joomla\Component\Content\Site\Controller\DisplayController' (length=58)
      13 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Dispatcher/ComponentDispatcher.php' (length=69)
          'line' => int 143
          'function' => string 'execute' (length=7)
      14 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/Dispatcher/Dispatcher.php' (length=73)
          'line' => int 56
          'class' => string 'Joomla\CMS\Dispatcher\ComponentDispatcher' (length=41)
      15 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Component/ComponentHelper.php' (length=64)
          'line' => int 361
          'class' => string 'Joomla\Component\Content\Site\Dispatcher\Dispatcher' (length=51)
      16 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Application/SiteApplication.php' (length=66)
          'line' => int 208
          'function' => string 'renderComponent' (length=15)
          'class' => string 'Joomla\CMS\Component\ComponentHelper' (length=36)
          'type' => string '::' (length=2)
      17 =>
        array (size=5)
          'line' => int 249
          'class' => string 'Joomla\CMS\Application\SiteApplication' (length=38)
      18 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Application/CMSApplication.php' (length=65)
          'line' => int 293
          'function' => string 'doExecute' (length=9)
      19 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/includes/app.php' (length=37)
          'line' => int 61
          'class' => string 'Joomla\CMS\Application\CMSApplication' (length=37)
      20 =>
        array (size=4)
          'file' => string '/var/www/sites/j4hwl/index.php' (length=30)
          'line' => int 32
          'args' =>
            array (size=1)
          'function' => string 'require_once' (length=12)
  private ?Throwable 'previous' (Exception) => null
  protected string 'sqlstate' => string '42000' (length=5)
Test
Thecus TopTower N6850 - Fazit
Lieferumfang
Thecus Toptower N6850
Der TopTower N6850 spielt in der Oberklasse - der Enterpriseklassse. Die verbaute Hardware ist enorm leistungsfähig und ganz nebenbei sogar noch aufrüstbar. Die Verarbeitungsqualität ist auf einem enorm hohen Level, gleichzeitig ist aber auch das Design nicht zu kurz gekommen, auch wenn das für diesen Anwendungsbereich meist zweitrangig ist. Der Energieverbrauch ist allemal angemessen. Zwar ist das Gerät nicht das Strom sparendste, allerdings brauchen bis zu sechs Festplatten und entsprechend potente Hardware nunmal sehr viel Energie.
Auch das Webinterface kann sich sehen lassen. Das ist vielleicht nicht so auf Multimedia getrimmt wie die Konkurrenz, allerdings ungemein detailreich und tief gehend. Auch die verfügbaren Anschlüsse können sich sehen lassen, viermal USB 2.0, viermal USB 3.0 und dazu noch eSATA - mehr geht kaum. Eine Lüftersteuerung zur Eindämmung der Lautstärke wäre allerdings schön gewesen. Wo doch das Gerät so schick aussieht, könnte man es doch auch an einem Ort aufstellen, wo man davon auch etwas sehen kann. Bei der jetzigen Lautstärke wird das N6850 vermutlich irgendwo im Keller oder in der Abstellkammer landen. Der lokale Zugriff via HDMI ist eine gute Idee - ist allerdings auch noch ausbaufähig. Mehr Software bzw. mehr Funktionen könnten hier noch Wunder bewirken.
Insgesamt ist der Toptower N6850 aber ein außerordentlich gutes Gerät. Die Hardware ist potent und braucht keine Unmengen an Energie. Die Leistung bei Dateitransfers kann ebenso wie das Webinterface überzeugen. Das Gerät ist sehr gut verarbeitet, solide, schick und außerdem sehr gut aufrüstbar. Ein Schnäppchen ist das Gerät mit einem Preis von rund 1000 Euro auf den ersten Blick natürlich nicht - angesichts der Hardware und dadurch gegebenen Leistung ist der Preis aber angemessen. Aus diesem Grund verleihen wir dem Toptower N6850 von Thecus den Excellent Hardware Award.
excellent hardware award
Positive Aspekte des Thecus TopTower N6850
  • hervorragende Geschwindigkeit
  • robustes und gleichzeitig schickes Design
  • Anschlussvielfalt
  • gute Aufrüstmöglichkeiten
  • lokaler Zugriff möglich
Negative Aspekte des Thecus TopTower N6850
  • Lautstärke
  • Energieverbrauch
Preise und Verfügbarkeit
Nicht verfügbar Nicht verfügbar Nicht verfügbar
