Gehaeuse
Gigabyte C200 Glass kommt mit RGB-Beleuchtung - Technische Spezifikationen
Case Form Factor:Mid Tower
M/B Type:mini-ITX/m-ATX/ATX
Color:Black
Materials:Steel, Plastic, Glass
Dimensions:H=480 W=210 D=435 mm (Within ± 1% error)
Expansion slots:7
5.25" Driver Bays:None
3.5“/2.5” Driver Bays:2
2.5" Driver Bays:2
I/O Panel:2 x USB 3.0
RGB LED Switch
Reset Button
Audio In & Out (Supports AC97 / HD Audio)
Fan Support:Rear : 120mm x1 (Pre-installed)
Top : 120mm x2 / 140mm x2
Front : 120mm x3 / 140mm x2
Radiator Support:Rear : 120mmx1
Top : 120mm x2 / 240mm x1
Front : 120mm x2 / 140mm x2 / 240mm x1 / 280mm x1
Power Supply Type:Standard ATX
Maximum Compatibility:CPU Height : 165mm
GPU Length : 330mm
PSU Length : 170mm
Quellen und weitere Links KOMMENTARE (2) VGWort
