Antec DP31
microATX-Gehäuse mit krallenförmigen Lufteinlässen und ARGB - Technische Spezifikationen
Dimensions:378 x 200 x 398 mm (DWH)
378 x 212 x 398 mm (DWH) (With handle)
Form Factor:Mini Tower
Materials:Steel + Plastic
Mainboard Support:Micro - ATX, ITX
Front Access & Controls:Power
LED Control Button
1 x USB3.0
2 x USB2.0
MIC / HD - AUDIO
Side Panel:Tempered Glass
Expansion Slots:4
3.5" /2.5":2/1
2.5":1
Front-Fans:2 x 120 mm / 2 x 140 mm
Top-Fans:2 x 120 mm
Rear-Fans:120 mm
Included Fan:1 x 120 mm fan in rear
Radiator Front:120 / 140 / 240 mm
Radiator Rear:120 mm
Max GPU Length:? 275 mm (with front fan)
? 300 mm (without front fan)
Max CPU Cooler Height:? 150 mm
Max PSU Length:? 175 mm (with HDD)
? 300 mm (without HDD)
Dust Filter:Bottom
Quellen und weitere Links KOMMENTARE (5)
