AMD veröffentlicht Radeon Software Crimson ReLive Edition 16.12.2
14
Nach der öffentlichen Präsentation und Verfügbarkeit der ersten Version des Radeon Software Crimson ReLive Edition schiebt AMD nun die zweite Version mit der Nummer 16.12.2 nach. Mit dieser Version behebt AMD die ersten groben Fehler im ursprünglichen Release, denn echte Neuerungen sind in dieser Version nicht zu finden.
AMD nennt fogende Fehlerverbesserungen:
  • AMD FreeSync technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays.
  • Radeon ReLive may fail to install during installation on some system configurations.
  • Battlefield 1 may experience flashing or corruption when running in Multi GPU with Radeon RX 400 series.
  • Instant Replay fails to enable itself after it has been turned off due to content protection.
  • Radeon Settings may not load on system boot for some system configurations.
  • Fixed some errors in translations for Radeon Settings and Radeon ReLive.
  • Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
  • Audio recorded by Radeon ReLive may sometimes exhibit slow motion when played back.
  • Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive.
  • Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement.
  • In AMD Multi GPU configurations the secondary graphics product will exit low power state when Radeon ReLive is enabled.
  • Radeon ReLive may sometimes not be able to take screenshots of secondary displays.
  • Chromium may fail to utilize hybrid decode for VP9 content.
  • DOTA 2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations.
Der Download des Radeon Software Crimson ReLive Edition 16.12.2 ist auf Radeon.com möglich.
Quellen und weitere Links KOMMENTARE (14)
