Treiber
Radeon Software Crimson ReLive Edition 17.9.3 mit verbesserter mGPU-Unterstützung
7
amd-radeon-software
AMD hat eine neue Version seines Grafikkarten-Treibers veröffentlicht. Der Radeon Software Crimson ReLive Edition 17.9.3 bietet die Unterstützung für Total War: Warhammer II und Forza Motorsport 7. Für Total War: Warhammer II bietet der Treiber auch ein Radeon-Chill- sowie mGPU-Profil.
Weiterhin behoben wurden folgende Probleme:
  • The drop-down option to enable Enhanced Sync may be missing in Radeon Settings on Radeon RX Vega Series Graphics Products.
  • ReLive may cause higher idle clocks on the secondary Radeon RX Vega Series Graphics Product in a multi-GPU configuration on certain AMD Ryzen based systems.
  • Negative scaling in F1 2017 may be observed on Radeon RX 580 Series Graphics products in multi-GPU system configurations.
Noch bekannte Probleme sind:
  • Unstable Radeon WattMan profiles may not be restored to default after a system hang. A workaround is to launch Radeon WattMan after reboot and restore settings to default.
  • Wattman may fail to apply user adjusted voltage values on certain configurations.
  • Radeon Settings may not populate game profiles after Radeon Software's initial install.
  • Overwatch may experience a random or intermittent hang on some system configurations.
  • GPU Scaling may fail to work on some DirectX 11 applications.
  • Secondary displays may show corruption or green screen when the display/system enters sleep or hibernate with content playing.
  • Bezel compensation in mixed mode Eyefinity cannot be applied.
  • When recording with Radeon ReLive on Radeon RX Vega Series graphics products GPU usage and clocks may remain in high states.
Der Download des Radeon Software Crimson ReLive Edition 17.9.3 ist ab sofort bei AMD direkt möglich.
