Mit DX9-Fix
Radeon Software Adrenalin Edition 18.1.1 veröffentlicht
2
AMD hat mit dem neuesten Grafikkarten-Treiber Radeon Software Adrenalin Edition 18.1.1 die mit der Alpha-Version eingeführten Verbesserungen für Spiele mit DirectX-9-Grafik-API in eine finale Version überführt. Neue Funktionen sind nicht eingebaut worden und so hat sich AMD auf das Beheben von Fehlern konzentriert.
Diese listet AMD wie folgt auf:
  • OverWatch may experience a random or intermittent hang on some system configurations.
  • Tom Clancy's Rainbow Six Siege may experience an application hang when breaching walls with grenades or explosives.
  • Netflix playback in a browser or via UWP application may experience stutter.
  • After recording with Radeon ReLive GPU usage and clocks may remain in high states.
  • Assassin's Creed: Origins may experience bright or saturated lighting in cave missions.
  • Mass Effect Andromeda may have issues enabling HDR10 on an HDR capable display.
  • Forza Horizon 3 may experience corruption on rocks or foliage during gameplay.
  • Halo Wars 2 may experience a crash on game launch.
  • Enabling HBCC on Radeon RX Vega in multi GPU system configurations may cause the secondary graphics card to be hidden in Radeon Settings until reboot.
  • Resizing the Radeon Settings window may cause the UI to restart or hang with HBCC enabled.
Weiterhin sind folgende Fehler bekannt:
  • Upgrading Radeon Software with Radeon RX Vega series graphics products in multi GPU on X99 chipsets may cause system instability after reboot.
  • Radeon Settings may experience a hang when enabling AMD CrossFire with three or more graphics products.
  • Performance Metrics Overlay may hang if enabled when cycling display power off and on.
  • Trimming videos may fail to create a thumbnail if the video contains non-English characters.
  • 3x1 display configurations may experience instability during Eyefinity creation or during gaming.
  • The "Reset" function in Radeon Settings for Display, ReLive, and Video may not work as intended when using Radeon Settings in certain regional languages.
  • Radeon WattMan may intermittently fail to load profiles for Radeon RX Vega on the global Radeon Wattman page.
  • Rise of the Tomb Raider may experience an intermittent application hang during gameplay.
  • A random system hang may be experienced after extended periods of use on system configurations using 12 GPU's for compute workloads.
  • The GPU Workload feature may cause a system hang when switching to Compute while AMD CrossFire is enabled. A workaround is to disable AMD CrossFire before switching the toggle to Compute workloads.
Der Radeon Software Adrenalin Edition 18.1.1 kann ab sofort direkt bei AMD heruntergeladen werden.
