Treiber
AMD veröffentlicht den Radeon Adrenalin Edition 18.2.1 Beta
6
AMD hat eine Beta-Version des Radeon Adrenalin Edition 18.2.1 veröffentlicht. Dieser soll die ersten Optimierungen für Final Fantasy 12: The Zodiac Age enthalten. Mit dieser Beta-Version behebt AMD auch einige Fehler, die dann sicherlich bald in eine finale Version des Treibers überführt werden.
Behobene Fehler:
  • Radeon FreeSync may rapidly change between min and max range when enabled causing stutter in fullscreen games on single display system configurations.
  • Sid Meier’s Civilization V may fail to launch on Hybrid Graphics system configurations when using DirectX 9 API.
  • Radeon FreeSync may exhibit a black screen on some games when using Samsung CF791 displays.
  • Radeon Chill game settings profiles may fail to enable on Vulkan API games.
  • Radeon Overlay may fail to open in some Vulkan API games.
  • Need for Speed Payback may exhibit corruption on some terrain.
  • Textures in Hyperdimension Neptunia Re;Birth3 V Generation may appear corrupted or exhibit flickering colours.
Noch bekannte Fehler:
  • Radeon FreeSync may intermittently incorrectly engage during Chrome video playback resulting in playback flicker.
  • Radeon Overlay hotkey may fail to bring up the overlay or may cause a Radeon Host Application crash intermittently on a limited number of gaming titles.
  • Radeon FreeSync may rapidly change between min and max range when enabled causing stutter in fullscreen games on multi display system configurations.
  • Flickering may be observed on the performance metrics overlay when Enhanced Sync is enabled on some Radeon FreeSync connected displays.
  • A random system hang may be experienced after extended periods of use on system configurations using 12 GPU’s for compute workloads.
  • Water textures may appear to be missing in World of Final Fantasy.
  • The GPU Workload feature may cause a system hang when switching to Compute while AMD CrossFire is enabled. A workaround is to disable AMD CrossFire before switching the toggle to Compute workloads.
Der Download des Radeon Adrenalin Edition 18.2.1 Beta ist ab sofort direkt bei AMD möglich.
