Treiber
AMD Radeon Software Adrenalin Edition 18.7.1 für Earthfall
2
AMD hat mit dem Radeon Software Adrenalin Edition 18.7.1 einen neuen Grafikkarten-Treiber veröffentlicht. Mit dieser Version richtet sich AMD an Spieler von Earthfall. Mit verschiedenen Grafikkarten und Grafikeinstellungen spricht AMD von einem Leistungsplus von 22 bis 28 %.
  • Up to 28% faster performance using Radeon Software Adrenalin Edition 18.7.1 on the Radeon RX Vega 56 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.6.1 at 2560x1440 (1440p).
  • Up to 22% faster performance using Radeon Software Adrenalin Edition 18.7.1 on the Radeon RX 580 (8GB) graphics card than with Radeon Software Adrenalin Edition 18.6.1 at 2560x1440 (1440p).
  • Up to 27% faster performance using Radeon Software Adrenalin Edition 18.7.1 on the Radeon RX 560 (4GB) graphics card than with Radeon Software Adrenalin Edition 18.6.1 at 1920x1080 (1080p).
Außerdem will AMD die folgenden Fehler behoben haben:
  • Fortnite Season 5 may experience an application hang on some Radeon graphics products when throwing stars are visible on screen.
  • Hellblade: Senua’s Sacrifice may experience flickering or corruption on some Radeon graphics products.
  • Display modes may sometimes appear as not available when setting resolution or refresh rates of a display.
  • CorelDraw may experience slower than expected performance.
  • Memory clocks may remain at higher than expected values on some displays after changing resolution or refresh rates.
  • Some displays may exhibit black screen flickering when booting to desktop when using DisplayPort.
Noch bekannt sind die folgenden Fehler:
  • Virtual Super Resolution settings may not retain after updating to this Radeon Software release.
  • Wolfenstein II: The New Colossus may experience an application crash when disabling Asynchronous Compute via game settings.
  • Graphics and memory clocks may remain at higher than expected values after watching a video or using Windows DVR while in game. A workaround is to reboot the system.
  • Cursor or system lag may be observed on some system configurations when two or more displays are connected and one display is powered off.
  • Radeon WattMan gauges may report as zero on secondary graphics products in multi GPU enabled system configurations.
Der Download des Radeon Software Adrenalin Edition 18.7.1 ist wie immer in den verschiedenen Versionen für Windows direkt bei AMD möglich.
