AMD hat eine neue Version seines Grafikkartentreiber veröffentlicht. Die Radeon Software Adrenalin 2019 Edition 19.1.1 richtet sich vor allem an Spieler von Fortnite (Season 7) und soll dahingehend einige Leistungsverbesserungen mit sich bringen. AMD spricht von einem Leistungsplus im einstelligen Prozentbereich.
Folgende Probleme sollen behoben worden sein:
- Virtual Super Resolution may not show up as available on some 1440p Ultra-Wide Displays.
 - Some Radeon RX Series graphics products may experience system lag when Alt+Tab is used during gameplay.
 - Radeon Settings Advisor may incorrectly suggest older versions of Radeon Software as an update.
 - Radeon Settings software update notifications may appear more often than expected.
 - Application profile settings for Radeon WattMan may not reset to default correctly when using the reset button.
 - Radeon Settings may experience a crash when clicking the restart button after a driver installation or while switching between some Radeon WattMan tabs when changing fan settings.
 - Zero RPM control may fail to enable correctly when toggled on/off in Radeon Settings.
 - Radeon ReLive gallery upload queue may sometimes fail to upload videos.
 - Radeon Settings may sometimes incorrectly display the previously installed Radeon Software version after upgrade.
 - Custom color profile options may fail to retain in game on clone or Eyefinity display setups.
 - Performance metrics overlay feature may scale incorrectly when changing resolution in game.
 - Screen tearing may be observed with Enhanced Sync enabled on Vulkan API games.
 - Some systems running multiple displays may experience mouse lag when at least one display is enabled but powered off.
 - Upgrade Advisor may intermittently fail to detect games and provide compatibility recommendations.
Weiterhin vorhanden sind die folgenden Probleme:
- Battlefield V players may experience character outlines stuck on screen after being revived.
 - Uninstalling Radeon Software may fail to remove Radeon Settings.
 - Pixel Format settings may not retain after system restart.
 - HDMI Underscan settings may not retain after system restart.
 - Radeon Overlay’s new in overlay video player may experience smoothness issues while adjusting the playback slider.
 - Scene Editor may have issues with scrolling when many elements are added to a scene.
 - Custom settings in Radeon WattMan may sometimes fail to apply on Radeon RX Vega series graphics products.
