emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
Blackline Frostbyte 996988
8GB (2x4GB) DDR3 PC3-12800 CL9-9-9-24 1.35v
Spezifikationen
Type: DDR3 (XMP entspricht DDR3L)
Voltage: 1.35V
Speed Spec: PC3-12800
Frequency: 1600MHz
Kapazität
Kit Type: Dual Kit
Kit Size: 8GB
Module Size: 4GB
Timings
tCL: 9
tRCD: 9
tRP: 9
tRAS: 24
Bauhöhe der Module: 37mm (zum Vergleich Module ohne HS 30mm)
Kompatibilität
- Intel LGA1156 (getestet emissary42: i3-530, MSI P55A-G55)
- Intel LGA1155
- Intel LGA1366
- AMD AM3 (getestet emissary42: Athlon II 640, ECS A890GXM-A)
Features
- Dual Channel Kit - Engineered for dual-channel architecture.
- Enhanced Frequency - This product has been programmed to operate at the ideal frequency for your system when properly installed.
- Enhanced Timings - This product has been programmed for timings that offer improved performance when properly installed.
- FrostByte Heatsink - This product is equipped with the Frostbyte™ Heatsink.
- Hand-Tested - This product has been tested by hand for quality assurance.
- Lifetime Warranty - Quality guaranteed - we offer a lifetime warranty on this product and genuine, unmatched service and support.
Produktseite: 996988
Preisvergleich: 996988
Das Kit wird in den nächsten Tagen verfügbar und dabei deutlich günstiger als die 8GBECO sein.
Das SPD
Standard Profile
JEDEC Profil 1: 457 MHz 6-6-6-17 / 23-74-3-7-4-4 @ 1.5v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC Profil 2: 533 MHz 7-7-7-20 / 27-86-4-8-4-4 @ 1.5v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC Profil 3: 610 MHz 8-8-8-22 / 31-98-4-10-5-5 @ 1.5v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC Profil 4: 686 MHz 9-9-9-25 / 34-XX-X-XX-X-X @ 1.5v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
CPU-Tweaker Profil JEDEC #0: 666 MHz 9-9-9-24 / 33-107-4-10-5-5 @ 1.5v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
XMP Revision: 1.2
JEDEC XMP-1066 Profil: 533 MHz 6-6-6-16 / 22-86-4-8-4-4 @ 1.35v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
JEDEC XMP-1600 Profil: 800 MHz 9-9-9-24 / 33-128-5-12-6-6 @ 1.35v (CAS-RCD-RP-tRAS / RC-RFC-RRD-WR-WTR-RTP)
CPUz Screen:
CPU Tweaker Screen:
Für diese Angaben übernehme ich keine Gewähr.
Reviews & OC/UV-Werte
Noch keine?
by emissary42: alle Ergebnisse 32m tested @ P55A-G55
1) DDR3-1333 CL7-7-7-24-1T @ 1.35v
2) DDR3-1600 CL8-8-8-24-1T @ 1.50v
3) für Horsi: DDR3-1600 CL7-7-7-21-1T @ 1.65v ---> not stable
NO SCREEN
4) XMP Min Voltage: DDR3-1600 CL9-9-9-24-1T @ 1.287v (BIOS 1.246v)
5) DDR3-1800 CL9-9-9-27-1T @ 1.5v
Problemlos bootfähig, aber nicht stabil. Vermutlich sind 180MHz Bustakt zu viel für das Board / die CPU. Deshalb nun noch:
6) DDR3-1750 CL9-9-9-27-1T @ 1.4v
7) für KeinNameFrei: DDR3-1866 CL9-9-9-27-1T @ 1.5v testing... mit dem nächsten Board dann^^
SCREEN
Bilder
Sieht ja schon ganz ordentlich aus. Wenn 1750 CL9-9-9-27-1T @ 1.4V stabil laufen, dann würde es mich schon sehr wundern wenn bei 1.5V die 1866 nicht drin sein sollten.
