[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ja weil du nicht vergessen darfst. wenn pp von deinem konto einzieht dauert das 2-3 tage wenn du aber innerhalb dieser tage bereit ne gutschrift erhalten hast, bekommst das NICHT direkt Gutgeschrieben, weil ja erstmal die buchung von deinem Konto durch sein muss. DANACH überweist PP dir dann die knete WIEDER aufs konto. also du kannst auch ned sagen der soll betrag XY jetzt als guthaben verbuchen.
Anders ist das bei Guthaben bei PP, wird ja direkt abgezogen, und wenn die Gutschrift eintrudelt hast du ja per GUTHABEN bezahlt und Instand ist das Guthaben auch wieder verfügbar.
Hängt aber auch viel vom Shop ab. wann sie dir die Gutschrift Gutschreiben, aber hier auch meist nur weniger Stunden.
genau das meine ich, das hat mir den Spaß genommen...
Ich will die Karte nicht testen einbauen um dann zu hören wie schlimm es ist, deswegen überlege ich ob ich die Karte ungeöffnet zurück schicke ;(
Das macht mir Angst...:oops:
Wenn auch Wakü umgebaut wurde, dringt evtl. Fiepen noch stärker durch
Glücklicherweise wurde das Fiepen meiner Strix damals leiser. Aber auch nur, weil ich es NICHT, wie in der Anleitung beschrieben gemcht hab
Es gibt Mittel und Wege, Spulen leiser zu bekommen, aber dazu muss der Kühler runter. Werden die Wenigsten hier machen...
Bei ASUS muss man schon leider von großem Glück sprechen, wenn eine mal ruhig ist. Deshalb war ASUS bei der 40er GEN genau wie die FEs keine Option für mich.
Bei der 30er Gen hatte ich mehrere Strixx und TUFs da, die große Mehrheit war zumindest für unter Wakü aus meiner Sicht unerträglich.
Es gibt aber auch Leute die immer wieder behaupten Ihre wäre ruhig, so auch ein Kumpel von mir. Als ich das Vorort mir dann anhören wollte, hab ich das Coil-Whine fast schon an der Haustür (stark übertrieben) gehört. :ROFLMAO: Also die Wahrnehmung der Menschen ist da auch sehr sehr subjektiv.
genau wie bei Lüftern, der eine bekommt schon bei 500RPM ne kriese, wo der andere bei 1500RPM noch nix hört :)
Alle 3090, die ich hatte (insgesamt 6) habe ich selbst behalten oder weiterverkauft bzw. ungeöffnet (versiegelt) zurückgeschickt ;)
Aber liege ich richtig, dass das Geld nach einem Storno sofort wieder bei PP ist, insofern ich Guthaben dort hatte?
Wenn das Guthaben "0€) war, und man per PP bezahlt, bekommt der Verkäufer das Geld zugesichert (hat es aber noch nicht
Bei einem Storno muss man mehrere Tage warten. Daher vermute (hoffe ich), dass das Geld bei einem aufgeladenen PP-Konto sofort wieder da ist
Kann dazu jmd was sagen, wie schnell das geht?
Storno sollte eigentlich schnell gehen.
Wenn Du die Karte schon erhalten hast, ist das von Händler zu Händler unterschiedlich. Hängt davon ab wie lange die für die Bearbeitung Deiner Retoure brauchen. Asus E-Shop ist zum Beispiel eine Katastrophe, die haben bei mir schon mal nach Erhalt der Ware drei Wochen gebraucht, bis das Geld wieder gutgeschrieben wurde. Insgesamt hat es dann knapp vier Wochen gedauert. Bezahlung lief über PayPal bei eBay.
Ich habe extra ein Drehmomentschraubendreher für den Wasserblock gekauft.
Oh man das klingt echt deprimierend. Wäre es möglich, dass verschiedene Karten des selben Modells unterschiedlich stark fiepen? Oder ist das dann bei allen Strix so?
Das ist bei allen Modellen und Marken jeweils immer anders. War schon immer so gewesen
Es besteht die Möglichkeit die Caps (d.h. die Gehäuse worin sich die Spulen befinden) entweder durch Druck oder Kleber ein wenig zu fixieren. Das kann tatsächlich helfen.
Wenn allerdings die Spule in den Caps so sehr gegen das Gehäuse schwingt, bringt auch das nix und man ist dem ganzen hilflos ausgesetzt.
Man hört ja öfter mal den Mythos das Netzteil tauschen etc bringt etwas, nach meiner Erfahrung bringt das in 99% der Fällen garnichts. Das einzige was tatsächlich passieren kann, die Spulen können sich "einschwingen" und mit der Zeit etwas leiser werden.
Das kann so nicht normal sein und wenn doch habe ich ein großes Problem mit der 4090er Generation.
Ich befürchte, da wirst Du Dich nach einer Karte mit hohen Spulen bzw. Ref-Platine umschauen müssen.
Diese Spulen hatten schon bei Ampere die geringsten Geräusche.
Das hatte ich mal ausgiebig getestet mit der 3000er Serie und 6 verschiedenen Netzteilen. Der Effekt dass das Fiepen geringer wird kommt meist davon, dass manche Netzteile da sSpulenfiepen aufnehmen und selbst mit Fiepen, was das Geräusch natürlich verstärkt. Wechselt man dann auf ein NT welches nicht mit Fiept, hört sich das natürlich besser an, obwohl die Karte genauso laut fiept wie zuvor.
Hab eine "Phantom" storniert...
Geld war sauschnell, wie auf der Revolut-KK
Gerade, wenn man auf Drops wartet, finde ich wichtig, dass es schnell geht. Da sind "mehrere Stunden" wie du oben schreibst, viel zu langsam
Aber immer noch besser, als mehrere Tagee/Wochen zu warten...
Am liebsten sind mir Echtzeit-Transfers
Weil es ja heißt nvida gibt den Ton an beim Pricing, hier ein kleines Beispiel von mir. Kunde bestellt bei uns eine Suprim X, die Karte kostet ihn 1695 Euro EK, sind mit Mwst 2030 Euro herum, er verkauft diese in seinem Shop um 2437 Euro. Das sind 20% Marge. Die Händler sind irre
Hat mir jemand einen tipp warum die gigabyte gaming oc in hw Info nicht angezeigt wird ?
Hat denn irgendwer schon eine Inno3d Frostbite ergattern können?
Hat jemand noch dieses Problem mit einer Asus-Karte? Rotes Licht bei ausgeschaltetem PC an der Karte.
Alles richtig angeschlossen. Karte läuft auch gut, weiß nicht was das soll...
Wieso Problem?
Dann seh ich wenigstens auf einen Blick durchs Seitenfenster, ob der Rechner an oder aus ist:
Spaß beiseite: Mit Einschalten des Rechners geht die LED aus.
Ich frag mich gerade, wie genau Asus die Prüfung, ob eine Versorgungsleitung angesteckt ist, umgesetzt hat.
Karte hängt an einem be quiet! Dark Power Pro 12 1200W. Vielleicht schaltet das im ausgeschaltet Zustand die Masse von den Anschlüssen weg, wodurch es für die Karte so wirkt, als ob nichts angeschlossen ist.
@Dampfkanes Die Folie auf der Karte, die schon fast weggeschmolzen ist, triggert mich unnormal
Für 2500 Euro war mir das Spulenfiepen zu extrem, auch wenn es jetzt sicher länger dauert eine Alternative zu bekommen so ist das völlig unakzeptabel. Und ich bin sonst eher nicht so sehr empfindlich. Wenn man sowieso zu 90% mit Headset spielt mag das unproblematisch sein, ich spiele kaum mit Headset da ist das dann nicht OK. Davon mal abgesehen das die Karte nur einmal kurz über 2900 ging, von den über 3000 die hier oft zu lesen sind war auch nichts zu sehen. Würde ich bei 2500 Euro auch mehr erwarten. Wobei ich das noch hätte locker akzeptieren können. Insgesamt wohl aber eine Montagskarte...
Was sind das für Modelle?
keine Ahnung, obs das Ref-PCB ist, aber die Gamerock hat z.B. die hohen Spulen (schwarze Blöcke):
die Zotac auch:
hier im Vergleich eine Karte mit den flachen (grau, "IPP" steht drauf):
Die sollen endlich mal gescheite Spulen verbauen?
Was nutzt einem das "0dB-Feature" (stehende Lüfter), wenn die Karte herumzirpt
Verstehe nicht, dass da keiner was machen will. Hauptsache Gewinnmaximierung mit günstiger Spulen :rolleyes2:
Diese unbändige Gier regt mich auf...
Wieso Problem?
Jo, hatte mich nur über die Farbe gewundert, weil das damals bei Turing noch weiß war... Etwas nervig, aber ist dann wohl halt so.
Das warten auf die Karte ist jetzt das schlimmste!
Gerade noch Schlauch verlegt und den Thron für das AORUS MASTER MONSTER vorbereitet noch ein bissel Putzen und schick ist !
Die GTX 650 ist so schnuckelig !
Ich bin mir nicht sicher, dass es der Preis ist.
Wenns der Preis wäre, dann müssten die lauten Spulen doch eher auf den MSRP-Karten drauf sein und nicht umgekehrt.
Ich hab dazu 2 Gedanken:
Man nimmt die flachen, weil sie weniger Bauhöhe haben. Dadurch muss der Kühler weniger komplex sein. Siehe Wasserkühler, die wegen der hohen Spulen je nach Bauart sehr dick ausgefallen sind (weil man über die Spulen mit dem Wasserkreislauf drüber musste).
Oder man nimmt sie, weil sie vielleicht die besseren elektrischen Eigenschaften haben.
Aber wie gesagt, man findet die Dinger eher auf den teueren Karten. Liegt imho dadurch eher nicht am Preis.
Gigabyte hat auf jeden Fall eine schöne Figur mit beigelegt :)
Ähnliche Themen
Antworten
6K
Aufrufe
314K
