[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Drops gehen langsam wieder los.
Wer hat denn die Gigabyte Windforce? Von den Daten her scheint das ja das Modell mit dem schwächsten PCB zu sein, aber die bisher wenigen Bewertungen sind gut.
Ich habe die windforce und seit Samstag eingebaut. Finde die Karte voll okay. Leise wenn man die Kurve einstellt. Dazu UV und damit läuft sie perfekt.
Wollte erst ne tuf aber keine bekommen. Und sonst ist mir der Aufpreis nicht wert.
Wenn du fragen hast kann dir gerne weiterhelfen.
Die Chipgüte variiert ja Extreme bei der 4090.
Ich hatte jetzt bereits 3 Strix eine TUF und 2 Suprim X und ne weitere Strix ist unterwegs gerade bei der Strix hab ich jetzt 2 Modelle die keine 3GHz gepackt haben und eine die Default 2985 MHz in ihrer Default Curve bei 1,1Volt drin hat und geht auf über 3.1GHz die andere geht nur bis 2970MHz und Default bei 1,1Volt gerade mal 2805Mhz. Die TUF liegt iwo dazwischen und die Suprime lagen beide bei ~2900 in der Curve.
Da reden wir von über 180MHz von einer Strix zur anderen …
Wie sehen denn eure Default Curves im Afterburner aus bei 1,1Volt?
Kannste was zum Spulenfiepen sagen, du hattest ja jetzt doch schon einige Karten bei dir?
Wie CU ihre Scalperpreise rechtfertigt.
Nur komisch, dass ich nicht mal annähernd auf diese VRAM Werte komme. Aber ich muss zugeben, es kann auch eventuell daran liegen, dass ich der Karte nur 1.000 V bereitstelle. Da müsste ich nochmals mit Stock bzw. mit 1.100 V testen. Darf ich noch fragen bei welcher Leistungsaufnahme du die 60-65 °C hast und bei wieviel % die Fans drehen? Danke im Voraus!
Die Leistungsaufnahme liegt bei den Temperaturen irgendwo zwischen 350 und 450W. Lüfterdrehzahl habe ich nicht darauf geachtet, das liefere ich noch nach.
Die Spannung sollte eigentlich keine Auswirkungen auf den VRAM haben, dann schon eher das Powerlimit, der VRAM bedient sich einfach aus dem zur Verfügung stehenden Energiebudget. Ich will nicht ausschließen das es da doch einen gewissen Einfluss gibt, aber er sollte minimal sein.
Undervolting habe ich nicht getestet aber zwischen Stock und +100mV hat der Speicher gar nicht reagiert, er geht auf Stock wie gesagt genau so weit wie mit mehr Spannung und ich habe noch nciht einen Absturz oder Bildfehler bei +1500 provozieren können, nicht in Bechmarks und nicht in diversen Games. Und Cyberpunk schaufelt bei mir auch 17GB in den VRAM, da sollte also was los sein.
Der Filter bei CU ist absolut zum Kotzen...
Selbst mit richtig gesetzem Filter für die 4090, steht entweder was ganz Anderes drin und/oder 4090 teilweise oder garnicht :fire:
Woher kommt denn die Info über eine 4090 Matrix?
Dante hate hier gepostet das zurzeit für Strix und TUF nur aus Topf zwei nimmt und 1 über bleibt für eine kingpin ähnliche Karte da bleibt nur Matrix. Er hate auch eine Quellen Angabe aber hier wird so schnell gepostet.
Die guten Chips werden doch schon beiseite gelegt für ne baldige 4090 Ti soweit ich gelesen habe. Glaube nicht das so ein Modell rauskommt wie Matrix/lightning ect.
Dann müssten ja Brote vom Preis her ins unermessliche steigen. Das kauft jeder. Täglich!
Nein, weil das Angebot an Broten relativ konstant zur Nachfrage an Broten bei uns ist, deshalb ist der Preis konstant. Das Angebot ist mögicherweise sogar höher.
Das Angebot an 4090er ist dagegen aktuell leider immer noch deutlich kleiner als als die Nachfrage, also steigt der Preis.
Es ist lediglich ein jahrtausened altes marktwirkschaftlichens Prinzip das nicht extra erst für Grafikarten erfunden wurde. Es mag frustrierend für den Kunden sein und deswegen nennt er es gerne "scalping" weil es ihm dann besser geht, aber es ist trotzdem ein völlig normaler Prozess, weil wir nicht in einer kommunistischen Planwirtschaft leben. Und das finde ich gut so.
Wenn man bei CU bestellt hat und jetzt als Status in der Bestellung steht: „Lagerbestand leider zwischenzeitlich abverkauft, wir bemühen uns um kurzfristigen Nachschub„ Dann bedeutet das das man zu spät war bei der Bestellung richtig? Dabei steht beim Artikel auf der Seite selber noch das ein Bestand von drei Stück vorhanden ist. Scheint ja dann nicht so dolle zu sein deren System.
Deswegen hatte ich letztens auch geschrieben, daß der Begriff "scalping" hier zu 80% falsch verwendet wird, es ist lediglich ein jahrtausened altes marktwirkschaftlichens Prinzip das nicht extra erst für Grafikarten erfunden wurde. Es mag frustrierend für den Kunden sein aber es ist trotzdem ein völlig normaler Prozess, weil wir nicht in einer kommunistischen Planwirtschaft leben. Und das finde ich gut so.
Aber Scalping erzeugt im ersten Moment eine künstlich erhöhte Nachfrage und ein künstlich verringertes Angebot. Was bei weitem schlimmer ist, da genau beides den Preis NOCH höher schießen lässt.
Davon profitiert vor allem der Scalper selbst, also sind sie schlimmer als nur reine Parasiten.
Parasiten würden nur ein wenig vom Gewinn abschöpfen, aber nicht Preis nicht beeinträchtigen.
Nunja es ist wie es ist...in ein paar Monaten wenn die Nachfrage gering ist, verschwinden wieder die Scalper....außer bei der FE...
Hier ist der Status auch nicht besser:
"Wareneingang in Kürze erwartet"
Werden Saturn/Mediamarkt auch schon gebottet? Bekomme nichtmal dort so eine blöde Gigabyte ohne Seitenfehler zu bekommen
Okay. Ja ich muss nochmals testen. Bei mir sind einige Spiele abgeschmiert wenn ich über +450 VRAM ging. Als Beispiel Halo Infinite oder COD Vanguard. Hast du mal getestet, was das in Games 4k an mehr FPS bringt? Stock zu +1500? Wäre mal interessant ob sich da nochmals ein ordentlicher Sprung ergibt.
Also die Asus hatten es alle.
Leider. Ab 200-250 FPS schon sehr deutlich. Mit WaKü bleibt abzuwarten. Leider war das ja bei der 3090 mit WaKü noch schlimmer.
MSI fand ich deutlich besser. Also aktuell würde ich eher die MSI als die Asus empfehlen.
Sofern da ein 600 Watt BIOS kommt, ist dass die beste Wahl.
Wem das mit den 600 Watt eh egal ist und der der mit der MSI Software klar kommt (bzgl. RGB) kann ohne bedenken zur MSI greifen.
Wollte gerade auch was dazu schreiben. Versuche seit gestern da eine Windforce zu bekommen. Wenn ichs mal bis zum letzten Schritt schaffe, kommt wieder irgend ein Fehler. Entweder droppen die immer nur so 5 Karten pro Drop oder der Andrang ist extrem hoch.
lol habe gerade von @MS1988 das TUF OC Bios auf meine non OC TUF geflasht:
Die Curve bleibt bei 1.05v bei 2700 MHz -> es spielt keine Rolle, ob TUF oder TUF OC Bios - was ein SCAM.
(vorausgesetzt @MS1988 hat wirklich eine TUF OC)
BIOS / MHz / bei 1.05v
TUF = 2700 MHz
TUF OC = 2700 MHz
STRIX OC = 2745 MHz
Ja laut GPU Z sollte es das auch sein .
Die normale TUF hat einen Boostclock von 2520 MHZ .
Ähnliche Themen
Antworten
6K
Aufrufe
392K
