[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat irgendjemand heute mal eine Bestellung für eine 4090 bei Mediamarkt/Saturn durchbekommen? Macht echt keinen Spaß mehr 🙃
Heute Morgen um ~ 1:50 ... Saturn schickt allerdings aktuell den Bestand aus Filialen.
Warum bestellst du 4 Grafikkarten für jeweils mindestens über 2k?
Weil manche hier im forum den Hals nicht vollkriegen. Um eventuell ne karte zu erwischen die 15mhz mehr pakt
Ging mir heute und gestern auch so. Erst mit der Windforce und heute mit der KFA2. Bin auch langsam echt richtig genervt.
Nutze einen Oled C1 für Games am Sessel und am Schreibtisch einen 4K 120Hz HDR Monitor von BenQ. Wenn es gute oled Monitore so 27 Zoll gibt hole ich mir einen. Am besten ohne Lüfter.
Bild ist schon wichtig :)
ich würde nen 27" 4k oled monitor nem tv vorziehen. warum?
- aufgeräumter und cleanerer tisch
- knackscharf
- USB HUB
- schneller
Einfach kaufen... :-)
Bei der Leistung habe ich mir gedacht, dass ich mir ein paar auf Reserve lege falls mal eine kaputt geht zund es keine mehr gibt...
Ne Spass. Manchmal kommt bei dem ganzen F5 Stress etwas Sarkasmus auf :-)
Naja alles was der Bot hier zu MM bringt ist instant weg, da hilft auch kein F5
sind das immer nur einzelne karten bei MM ? das ist ja schlimmer als alles :d
Also ich konnte die Tuf jetzt mei MM in den Warenkorb legen... Weiß gar nicht was Ihr habt?
Warenkorb ja, aber nicht weiter... :fresse:
Also ich hab die Karte noch immer im Warenkorb, und wäre 3 mal zum Abschluss gekommen. Zumindest bis zu der Seite, wo man die KK-Daten eingeben muss. Die Vernunft haut dann aber immer von hinten zu :d
Wenn Ihr hier Warenkorb Ping Pong spielt dann kann sie ja nicht vernünftig gebucht werden :-)
hat man beim Kauf auf Ebay-Kleinanzeigen/im Forum auch Herstellergarantie? Weil Händler-Gewährleistung gilt nur für den Erstkäufer.
wenn der händler/Hersteller eine Abtretungserklärung akzeptiert ja afaik
Die gesetzliche Gewährleistung kann abgetreten werden. Die freiwillige Herstellergarantie kann auf den Erstkäufer beschränkt sein, das hängt von den Garantiebedingungen ab.
Habe den Block gestern vorbestellt und mir wurden folgende Lieferdaten genannt.
Hab den schwarzen Acetal für die Strix am 13.10. bestellt und es steht 18.11. als estimated shipping date.
Sorge macht mir nur, dass genau bei dem auf der Produktseite kein Datum steht und „pre-order“ während bei allen anderen 4090 EKWB „vorbestellen“ und „early November“ steht…
Mein PC ist derzeit frankensteins Monster…
so habe jetzt die strix 4090 mit 4 kabeln installiert aber er zeigt mir nur max power target von 90% an ?!
A Plague Tale : Requiem ist das erste Game das ich mit der 4090 inkl. DLSS3 getestet hab, echt heftig was da an Frames rauskommt wenn man dieses zusätzliche Zwischenbildberechnung anschaltet :oops:
Interessanter Effekt: Mein Monitor macht 144 Hz, weswegen ich die max. FPS in der NVIDIA System Steuerung auf 144 FPS limitiert habe.
Bei Plague Tale ist mir direkt aufgefallen dass die FPS über die 144 FPS hinausschießen, das Limit funktioniert ansonsten in allen anderen Games aber eigentlich recht zuverlässig.
Eben bin ich darauf gekommen woran das liegt: Der Treiber erkennt das zusätzlich berechnete Frame nicht und limitiert bei 288 FPS.
Man muss die Systemsteuerung also auf max 72 FPS setzen, dann werden bei Plague die Frames im Game auch auf 144FPS limitiert.
Ich hatte zuvor noch von 08.10 eine EKWB order offen welche ich aber storniert hatte, weil ich dachte wie das läuft bekomme ich meine Wunschkarte [Founders Edition] erstmal nicht.
Da ich aber einer der glücklichen bin, welcher gestern eine bestellen konnte, hat habe ich erneut den pre order durchgeführt.
1. Bestellung stand 11.11
2. Bestellung nun 21.11
aber passt schon.
Ähnliche Themen
