[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also der P Mode bei der Strix läuft bei mir nicht richtig, Lüfter verhalten sich komisch und ich habe Abstürze.
Ich habe nichts verändert, ausser das offizielle Bios Update drauf gemacht.
Seitdem steht beim Powerlimit nicht mehr 90% sondern 100%, hab Abstürze und kann im Afterburner immer noch nicht das Powerlimit erhöhen (was ich eh nicht machen würde, aber komisch ist es trotzdem).
was ist denn der p mode?
Ich bin ja mal gespannt wie ein Flitzebogen wie sich der 5800X3D im Vergleich zum 5900X schlägt. Bei 5120x1440 hänge ich bei so vielen Spielen im CPU Limit, hätte ich nicht gedacht. Freitag soll das Teil kommen.
Über wieviel FPS reden wir denn, wenn es um das CPU Limit geht?
Das P(ower) Bios.
Edit: Hab gerade geschaut, heisst wohl Performance und nicht Power.
Die Strix haben doch so einen kleinen Schalter wo man zwischen Q(uiet) und P umschalten kann.
Unterschiedlich. Far cry 6 habe ich um die 80% load und um die 90fps.
Spiderman hab ich 60% load und hartes pendeln zwischen 60 und 120fps ohne dlss.
COD Cold War 70% load um die 100fps.
Dann bin ich auch extrem interessiert an deinen Ergebnissen, habe auch eine 5900X und überlege schon länger zur Zocker CPU 5800X3D zu wechseln.
Ich werde berichten. Ich behalte den auch nur wenn es sich lohnt, wenn nicht wird halt doch der 13900K geholt 😂
Aber probieren wollte ich es wenigstens mal.
Hier "Bildzeitung"
xD
Danke euch für den Tipp mit dem Klack-Geräusch und dem Stecker!
Habe bei mir gerade auch nochmal nachgeschaut und der Stecker saß auch nicht richtig drin.
Dass man dafür schon ein bisschen Kraft aufwenden muss fühlt sich aber nicht richtig an.
Hier "Bildzeitung"
xD
Der scheint keine Ahnung zu haben. :d
Das "richtige" Ergebnis gibt es morgen vom Labor de Igor.
... ohne Spaß!
Was man sich für ~2000€ alles antun muss ...
Gerade die Gainward Phantom 4090 verbaut. Auch hier schreien die Spulen und die Lüfter geben ihren Rest dazu: Brummen und Surren vom Feinsten.
Was denn für ein klack Geräusch? Sollte der Stecker beim einstecken ein solches machen. Tat meiner nämlich nicht. Einen Spalt oder dergleichen kann ich trotzdem nicht erkennen, er scheint fest drin zu sitzen. Allerdings ohne "Einrasten"
Ich habe einen 5950X drinne, aber nutze noch UV...
Ich bin echt am kämpfen ob ich nicht zum 5800X3D umsteigen soll....die 16 Kerne brauche ich jetzt nicht unbedingt, da ich am PC nur zocke...
Damit ich mir ein besseres BIld machen kann suche ich einen direkten Vergleich vom 5950X zum 5800X3D in 4k und mit einer 4090...aber ich finde keinen :d
Finde nur in 720p, 1080p oder 1440p...
Spar dir den aufwand
Geht mir ähnlich, jetzt läuft hier ein 5800x mit etwas über 5 GHz und custom curve. Tue mich schwer jetzt noch mal Geld in die alte Plattform zu stecken. Der 3D würde mich aber reizen, keine Frage. Ist auch immer eine Preisfrage.
Argh, schade das du nicht in 4K zockst, dass wäre ansonsten tatsächlich hochinteressant geworden 😕
Wie jetzt, ist es etwa doch ein grundsätzliches Problem? Dachte, sie lief bei Dir problemlos. Oh,warte, der Fehler liegt beim Nutzer, wenn ich das richtig verstanden habe ;)
Genau so war es bei mir auch und ein Spalt war auch nicht zusehen. Hab dann nochmal mit etwas Kraft nachgedrückt und es machte "klack".
Habe allerdings den 4-Zack von Nvidia.
Ich habe das Kabel nicht richtig reingesteckt -> Mein Fehler -> Userfehler.
Ja, vor allem ging es bei Ampere viel viel leichter bei mir.
Fazit von Jay: Selbst mit grobem Fehlverhalten ist bei ihm nix passiert. Ist ja schonmal ganz interessant.
Ich bin eigentlich kein großer Fan von diesem Jay2Cent, aber das Video fand ich gelungen. Er probiert echt harte Fails die kaum jemand hier so machen würde und das Kabel hält. Für seine Zielgruppe sollte das erstmal passen.
Igor will ja morgen ein Mega Skandal Video liefern....
Im Grunde ist allen Youtubern so ein kleiner Aufreger sehr recht, bringt das doch meist mehr Klicks als ein anständiges Review. Leider ist das bei Games inzwischen wohl auch so.
Davon abgesehen fand ich die gezeigten Cablemod-Adapter ziemlich hübsch, sehen deutlich solider aus als alles Andere.
das sind fake kanäle und balkenvideos sind sowieso immer ganz seriös :d
jay hat nur das kabel. der 90grad adapter kommt ja noch :)
das ding ist > er kann das jetzt noch 10 mal machen und es würde mit hoher wahrscheinlichkeit nix passieren.
aber bei tausenden verkauften karten und somit auch adaptern die aktuell im einsatz sind kann eine blöde verlegung der kabel unter bestimmten umständen dann vll doch zum einem problem kommen.
nur weil jay da keinen fehler heraufbeschwören kann, musst das nicht heißen dass der adapter nicht das problem ist
Thx 🙏
Ist schon krass, da würden mich nun tatsächlich 4090 Werte interessieren
wenn du die 4090 wert sehen willst guck dir einen 4090 bench an mit der stärksten cpu.....
und nochmal. diese youtubekanäle sind allesamt fake
warum in 4k? du willst doch wissen was die cpu kann
wenn ein 5800x3d 70 fps in 720p bringt, bringt er sie auch in 4k. fertig. jetzt brauchst du nur eine gpu die das schafft.
Der 5900x und 5950x skalieren in Games richtig gut mit FCKL 1900 und RAM dementsprechend 3800 MHz mit 15/16er Timings.
Wenn die Tester nen Stock 59X0x gegen den 5800x3D testen, ist auch Käse.
Zwar ist der 5800x3D meistens dennoch gut schneller aber drauf geschissen, wenn man in 4K oder WQHD 21:9 zockt.
Du hast recht?! Woher kam dann das Geräusch? Hab ihn zweimal drangesteckt um auf Nummer sicher zugehen 🤨
Ähnliche Themen
Antworten
6K
Aufrufe
330K
