[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
wenn jemand von einem 5950x erwägt auf einen 5800x3d zu wechseln dann hat derjenige in der regel die Prio auf games statt multicoreanwendungen gelegt ;)
er nimmt den verlust dort also bewusst in kauf.
der 5800x3d sollte bei optimaler nutzung des 3d caches mehr als 10% schneller sein als der 5950x
und da der preis vom 3d gerade gedroppt ist könnte so ein wechsel ohne kosten von statten gehen
Bzgl. der Kabel: Das kommt ganz einfach auf die Art und Menge eingesetzten Materials an (Kabeldurchmesser Innen vor allem). Corsair beispielsweise hat hier eine Statistik/Liste veröffentlicht, welche Kabel welcher Netzteile mit bis zu 300W belastet werden dürfen, und welche dafür nicht geeignet sind.
Standardmäßig sind 150w vorgesehen, manche Hersteller haben aber bereits vor Jahren großzügig gerechnet/hergestellt und können so jetzt mit 2x 8Pin auf 600 Watt gehen.
Also wird der 5950x nicht schneller wenn er ihn von 4,2 auf den standardtakt von 4,9Ghz laufen lässt?
Meiner meinung nach kommen da 10% mehr raus. Stattdessen hohlt er den 58003d der dann max noch 10% schneller wäreaber dafür in jeder multikernanwendung eine krücke isr.
Bei modernen Prozessoren kommt es nicht nur auf den Takt an, sondern auch auf die Anbindungsgeschwindigkeit zum Motherboard/Chipsatz/Festplatten/Cache etc. Deshalb kann zB ein 58003D Prozessoren in den Schatten stellen, die mit 1 Ghz höher takten können - bei Anwendungen, die davon profitieren.
Insgesamt ist ein 5950x natürlich die deutlich bessere Wahl, da er mit - verhältnismäßig - viel weniger Abwärme und größerer Effizienz viel mehr leisten kann (Leistung pro Watt). Der 5950x ist aktuell - für das Geld - der effizienteste Prozessor auf dem Markt. Auf 100 Watt kappen und das Teil wird Rennen und Rennen. Ob jetzt bei FHD 310 oder 360 FPS zustande kommen, ist irrelevant - und in höherer Auflösung wird stets die GPU limitieren (es sei denn, jemand hat sich den aktuell beliebten Brandbeschleuniger ins Haus geholt).
Das Problem ist aber, dass der 5950 mindestens in 50% der spiele schneller ist.
Bedenken sollte man zudem, dass viele Anwender heute eine ganze Menge im Hintergrund laufen haben - Discord, Steam, Ubisoft, Browser, Windows macht irgendwelche Updates, whatever. Das alles frisst Leistung.
Benchmarks werden stets von Reviewers unter Optimalbedingungen gemacht - also in cleanen Systemen, auf einem Benchtable mit perfekter Belüftung... einen 5950x kannst Du auch 3 Instanzen von WoW laufen lassen, in irgendeinem stickigen Silent Gehäuse und der wird sich immernoch langweilen. Ein 5800x3D wird bei Multitasking deutlich schneller in die Knie gehen. Wenn man ausschließlich ein einziges Spiel auf hat, nichts anderes macht und sich ansonsten auch in keiner Weise nicht-gaming mäßig durch die Weltgeschichte bewegt, dann macht ein 5800x3D großen Sinn - wer jedoch mehr macht, sollte sich immer überlegen, wieviel Leistung er anderswo für dasselbe Geld noch haben könnte.
oder man ist in der lage mit reglern umzugehen :)
1 regler. cpu limit oder gpu limit ;) 3440x1440
das video ist aber leider nicht seriös und somit für die katz
das bastel ich dir in ner halben stunde auch zusammen. spiele videos saugen. in einem videoschneideprogramm zusammenkloppen. paar balken dazu und ein paar zahlen ausgedacht.
schwub die wub bin ich youtube bencher
Hat jmd einen 5800X3D und einen 5950X und kann sagen, ob ein stark oc´ter 5950X @ 5,1GHz bei cachebegünstigten Games mithalten kann?
Hat jmd einen 5800X3D und einen 5950X und kann sagen, ob ein stark oc´ter 5950X bei cachebegünstigten Games mithalten kann?
5950x zu übertakten macht nicht viel Sinn, der wird 60% mehr Watt fressen für 4-10% mehr Leistung (und die Abwärme wird direkt eine mächtige Wasserkühlung bedürfen). Die Teile laufen schon fast an der Kotzgrenze. Moderne Prozessoren sind schon weit jenseits vernünftiger Effizienzkurven unterwegs.
Undervolten ist wieder ein anderes Thema, hier ist die Chiplotterie + Motherboard aber kriegsentscheidend, da kann von 2-15% mehr Leistung alles drin sein. Da kann man nur ausprobieren und im Nachhinein entscheiden.
Am wichtigsten heutzutage für Mehrleistung ist am Ende immer die Chiplotterie, deshalb sind irgendwelche Benchmarks und Tests von anderen auch immer nur bedingt hilfreich. Manche können aus ihren Karten zweistellige % mehr rauslocken, anderen wird das System direkt abschmieren.
Wichtig ist auch zu bedenken, dass es viele Overclocker gibt, die LN2 Nutzungen nicht immer ehrlich zugeben. Da schweben dann Erwartungen im Raum, die der User mit seiner gurkigen Luftkühlung niemals erreichen kann.
da ist der 5950x und 3d dabei
acc wäre ein spiel wo der 3d gut geht z.b.
Das sind alles Fake-Benchmarks. Der einzige seriöse "Benchmark-Youtuber , den man eventuell mal als Anhaltspunkt nehmen kann, ist "Bang4Buck Gamer".
Hier mal aus dem CPU-Leistungsindex der aktuellen PCGH: Der 5800X3D ist in JEDEM einzelnen getesteten Spiel, das zum Index beiträgt, schneller als der 5950X.
die aero 4080 ist sehr hübsch. warum gibts keine 4090er? -.-
würde gut zum apex passen :d
Ich überlege meinen 5900x mit einem 5950x zu ersetzen. Wenn Du ihn loswerden willst sag mal bescheid?
Ich glaube du hast recht... habe mich auch immer gefragt wie die die 3 szenen alle 100% synchron bekommen :-)
Gibt aber auch seriöse benchmarks. Bei Hardware Unboxed zum Beispiel.
Aber die Regler will ich gar nicht bei einer 4090 runterregeln. Ich will maxed out zocken. Sonst hätte ich auch die 3090 behalten können.
also das nebeneinander synchron ist kein akt. dafür gibts timelines in die man reinzoomt und dann kannst du den beginn jedes videos perfekt timen
feierabend, geht nach hause
alles ausverkauft :d
jay hat cablemod leerräumen lassen mit seinem aufruf :d
EDIT: US STORE
im EU STORE GEHTS NOCH
ich check mal meinen ab
Auf Reddit gibt's mittlerweile lauter amüsante Lösungen für das Bending Problem. Hier mein aktueller Favorit:
Berücksichtigt diese Liste auch die Fälle aus Südkorea? Die haben auch ein Forum, in denen sich betroffene gemeldet haben.
Bisher glaub ich nur 1 Fall den sie aus dem Asiatischen Raum aufgenommen haben den mit der Galax der Gestern bekannt wurde
Die Liste hat nun auch den 14ten Fall mit aufgenommen
Link direkt zum Fall :
Dazu sollte man aber folgendes nicht vergessen:
Zitat CB:
„ Noch eine große Stufe darüber ist die UHD-Auflösung angesiedelt, die Grafikkarte entscheidet nun de facto allein.
Hier bleibt die alte Erkenntnis, dass sich mit jeder modernen CPU gepaart mit den besten Grafikkarten in dieser Auflösung quasi gleich gut spielen lässt.
Quelle:
Ähnliche Themen
