[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Natürlich kannst du da was drauf geben, allerdings ist das ganze auch abhängig von Takt der GPU und ob die Volt dazu passen. Man kann sich selbst bescheißen und mit einer im Grunde ständig instabilen Karte glücklich sein oder aber Werte ermitteln, die in allen Lebenslagen stabil sind, inklusive max. Raytracinglast stundenlang. Portal RTX ist ebenfalls ein sehr guter Stabitest.
Bei mir ist bei +1150MHz Schluss auf dem Vram, also mit z. B. GPU Werten von 2730MHz bei 0.975V - 2730MHz mit +1250 Vram laufen aber auch mit nur 0.940V durch einen Time Spy Run, aber nicht bei max Raytracinglast oder Speicherempfindlichen Games. Du kannst davon ausgehen, dass der Vram bei 1600 oder sogar darüber heftig in der Fehlerkorrektur läuft, also wenn sich die Karte nicht komplett aufhängt, so viel OC Spielraum, ist da meist nicht beim Vram - viel mehr als +1250 sehe ich da nicht im Schnitt, also dass der Vram nicht in die Fehlerkorrektur läuft, natürlich gibt es aber auch wieder die Ausnahmen, die doch höher schaffen - macht die Karte dann natürlich auch langsamer, wenn der Vram ständig die Fehler ausbügeln muss - manchmal ist eben weniger mehr.
1299 läuft jetzt stabil laut Tool. Werde es wohl so lassen, weil einen großen Unterschied macht es ja eh nicht ob 1299 oder 1499. Denke 1499 war jetzt auch nicht "instabil". Habe damit einen Monat fast täglich unterschiedliche Games gezockt. Also wenn dann wäre das die one in a million Situation geworden wo der RAM crashed oder ein ganz bestimmtes Game, was ich derzeit halt einfach nicht zocke. Aber ohne Fehler fühlt sich dennoch besser an :fresse:
+1600MHz, stabil nach 2h
+1800MHz wollen nicht (y)
Werde noch +1700MHz probieren, glaube aber, dass die Shice auch nicht stabil sein wird. (y)
Während des runs mal Infos zur Radeon 7900er Reihe sammeln. ^^
So die Master wird nun gebencht...
Sie scheint schonmal taktfreudiger als die FE.
Temperaturen soweit ok. Lüfter spinnen bisher nicht rum. habe aber ne frische Win 11 Installation und keine Gigabyte Software installiert. Mal sehen ob sich das ändert sobald die Gigabyte Software drauf kommt
Bios Update hat nicht geklappt. angeblich keine kompatible Bios Version... kp.
Ggf geht heute Abend die FE in die Bucht und macht jemand anderen glücklich :)
Puh. Amd hängt ja echt eine generation hinterher. Haben jetzt mal die 3090ti erreicht. Tun mir echt leid.
Was ich mir einen shitstorm der amd anhänger reinziehen musste, als ich bei der vorstellung sagte, dass die amd karten gar nicht produziert werden müssten, da das auch schon eine 3080ti kann. Ob die die amd karten jetzt immer noch feiern? Schade für amd. Aber die karte ist echt so lahm wie die präsentation schon vermuten lies. Und von effizienz ist nichts zu sehen. Im prinzip eine 6950xt ti.
Ich vermute die 4080 verkäufe werden jetzt steigen.
Na, die XTX ist schon nicht so schlecht, so lange der Preis der 4080 so bleibt. Klar kann sie nicht mithalten insgesamt, wenn einem RT wichtig ist aber mit Raster sieht es schon nicht so schlecht aus. Die XT ist aber unnötiges Beiwerk zu dem Preis. Da hat man sich zu viel von Nvidia abgeschaut.
Und errors bei +1700MHz, dann als nächstes +1650MHz. (y) Man sieht in welche Richtung es geht, weniger als +1600MHz können es nicht moar werden. (y)
Zum Thema Fehlerkorrektur beim Vram
+0 = 369FPS / 259W
+999 = 373 FPS / 262W
+1499 = 379 FPS / 268W
Keine Fehlerkorrektur erkennbar, keine Verlust an FPS, sondern im Vergleich +999 zu +1499 ein Gewinn von 6 FPS den ich mit 6W Leistungsaufnahme bezahle. Stock, +0 zu +1499 sind es 10FPS für 9W. Den Deal nehme ich.
Warum? Wegen Raytracing? Nicht jeder benötigt Raytracing und hwunboxed hat durchschnittlich 20% weniger FPS ohne RT/Upscaler gemessen vs 4090 in 16 games (4k/wqhd)
Ich finde die generation unnötig. Die kann nicht mehr als eine 3090ti. Amd hätte die runde aussetzen können. Und nur für rasterization braucht man keine aktuelle karte.
Igor war in seinem video zu recht enttäuscht. Die 4080 ist wesentlich effizienter. Und ja. Wenn ich eine karte kaufe will ich auch unbekannte zukünftige spiele zocken. Nicht nur ein paar ausgewählte ohne rt wo sie mal schneller ist. Ich hätte amd aus marktkonkurenzgründen auch mehr leistung gewünscht.
Gibts hier eigentlich jemanden der so mutig war eine 4090 FE in ein Meshlicious einzubauen? Mich würde vor allem interessieren wie es mit dem Stromanschluss aussieht. Theoretisch sollte sie reinpassen, die 3090FE ging auch rein aber die Geschichte mit dem berüchtigiten Adapter zur Seite macht mir da Sorgen.
Wer nicht wagt, der nicht schmort.... :fresse:
Hat aber "Klick" gemacht und bewegen kann sich da jetzt auch nichts mehr vom Kabel ^^
Bin echt zufrieden muss ich sagen, sehr wertige Karte. Brummenden Hecklüfter höre ich nicht, Spulenfiepen höre ich, aber ist sehr dezent, kein Vergleich zur 3080ti Strix, die vorher drin war.
Wir sind hier alle Enthusiasten und wollen natürlich das beste und neuste, bei mir nicht anders. Allerdings gibt es eine große Esport Szene die möglicherweise durchaus eine 7900xtx bevorzugt. Zb rast die xtx der 4090 in COD davon auch wenn man COD nicht wirklich Esport nennen kann :-)
Da zählt nunmal DLSS oder Raytracing überhaupt nicht
Ok. Hat die dann 600 statt 500fps? 😀
COD hab ich in 4K nur 130--155FPS ohne DLSS. Mit dann 180-230FPS. von 500 FPS ist man da weit entfernt. Da bringt es btw auch nichts in 1080p mit low Settings zu spielen, weil selbst ein i9 13900K mit 250FPS im Limit läuft.
Fanboys mag halt wirklich niemand, sind meist recht widerliche Charaktere, manches mal sogar beängstigend.
Und extrem vielen Leuten ist Raytracing völlig wumpe und die freuen sich nun auf die Karte die ja fast immer 4080er Leistung bringt ohne RT.
Aber sie hatten als argument, dass ich ein doofer zu viel zahlender nvidia fanboy bin. 😀 ja und jetzt? Jetzt zahlen sie weniger und bekommen auch weniger mit höherem stromverbrauch.
Ja stimmt eigentlich. Im Endeffekt ist man in den esport Titeln fast immer im cpu Limit. Dann bleibt wirklich nicht mehr als ein paar Taler die man spart
Aber in MW2 kann ich mir DLSS leider nicht geben, im MP mag das noch gehen, aber in Warzone 2 stören mich die Schwarzen "Trails" die da bei bewegten Objekten dranhängen schon teilweise :d
Haben sie denn wirklich unrecht gehabt? Was sagt dir deine Eigenreflexion?
Ich habe eine amd cpu. Und die mag ich. Ein firmenname hat keine relevanz für mich. Die qualität eines produktes ist für mich entscheidend. Trage auch keine kleidung mit markennamenaufschrift weil ich mir da viel zu blöd vorkommen würde kostenlos werbung zu tragen welche ich dann noch evtl. teuer bezahlt habe.
Hätte amd die 4090 rausgebracht hätte ich sie genau so gern gekauft.
MP spiele ich 4K mit DLSS Balanced in LOW Settings. Damit komme ich auf meine 240Hz/FPS und es ist butterysmooth. DLSS ist halt bissl ausgewaschen, aber MP zählt die Performance halt mehr.
Ähm Latenz ist die nicht so wichtig im Multiplayer ?
wozu 240fps wenn die Latenz über 100ms ist ?
CableMod trollt doch :d
Ähnliche Themen
Antworten
6K
Aufrufe
353K
