[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
28k sind selbst mit nem 9900K zu wenig. 30-31k sollten das schon werden. Hatte mit dem Nachfolger 32k mit ner Stock 4090 und 33,5k mit maxOC.
VSync ist aus. Hatte noch Videobeweis an, aber nun ist alles aus, keine Framelimiter nichts....
So sieht es nun aus...
Hier sind die Werte von Stagfire mit 9900K
Da hast du was zur Orientierung
Gibts das Kabel von Seasonic aktuell irgendwo zu kaufen? Bei Alternate hatte ich es verpasst und jetzt kann man nicht mehr bestellen.
Kauf dir das Fasgear fürs Seasonic und du hast Ruhe.. günstiger als Cablemod und selbe Qualität. Minus Schnickschnack den eh niemand braucht.
Mit Verlaub bei einigen Systemen hier ist definitiv was im Argen, wenn ich mir ein RX 7900XTX + i7-8700k System oder RX 7900XTX @ OC + 5800X3D so anschaue müsste mit einer 4090 + 9900k deutlich mehr bei rumkommen.
Sieht ausreichend aus für mich, hab ich bestellt (y) Wie schnell und mit was liefert LDLC? Scheint ja dann aus FR zu kommen?
*edit*
Gerade erst gecheckt, die ist ja gar nicht verfügbar. Das wurde etwas seltsam von Chrome übersetzt.
Gute Entscheidung, oftmals kommt die eh schneller als LDLC angibt, wenn du keinen Stress hast würd ich die Bestellung aufrecht lassen
Habe gerade meine 4090FE eingebaut und TimeSpy laufen lassen. Passen die Werte für einen 9900K @ 4900MHZ mit Stock 4090 FE ?
Score: 21.697
GPU Score: 26.584
CPU Score: 10.628
Max Takt: 2.820MHZ
Speicher: 1.313MHZ
Ist das nicht zu wenig ? :(
Sehr positiv: Kein Fiepen, Lüfter hörbar aber nicht störend für mich.
Sieht plausibel aus.
Nabend!
Das war gestern wieder eine Hektik wie ichs eigentlich gern vermeiden würde.
Erstmal kam der Hermes Fahrer früher als sonst und hat, trotz das 2 Personen im Haus waren, niemand angetroffen. Naja au Frust bin ich dann Tanken gefahren und dann hat mich son weißer Bulli geschnitten. Zack, war der das, ich schneller u-turn und hinterher in ein Wohngebiet. Karte abgenommen. Mich bedankt und nach Hause.
Zuhause dann Karte eingebaut gegen Abend. Kein Bild und Lüfter drehen nich an.. KLASSE. Erstmal Board resetet und dann Bios update gemacht. Nix passierte. Das Corsair Kabel gegen die Nvidia Peitsche ausgetauscht und die Karre lief an. Ich hab das Corsiar Kabel in allen möglichen Steckerpositionen des Netzteils probiert. Startet absolut nicht. Also mal den support anschreiben.
Ich war eigentlich zu müde und hab die Karte kurz noch mit Timespy gebenched. Iwas mit 26k Punkten, dass war mir zu wenig. Achja da war ja was, Board XMP Profil eingestellt, rbar, pcie gen 4. Jetzt iwas mit 27k Punkte. Rechner aus und pennen gegangen. :d
Die Karte an sich ist wahnsinnig hochwertig, tolle Haptik und absolut massiv. Karte ist 27 von 180.
Die kleine EVGA 3090 daneben.
Es gibt mit der aktuellen Windows 11 Version ein paar Probleme mit den TS
C:
TeamSpeak
:fresse:
Ist vielleicht auch nur Dyskalkulie :d
Ah verdammt wollte das eigentlich noch nicht abschicken, weil ich den Reddit-Post noch suchen wollte. Hat @Tannenzapfen aber bereits verlinkt. Damit sollte klar sein, dass mit TS der Benchmark 3DMark TimeSpy gemeint war :)
leider nicht, auch nicht in corsairs icue Software. Wahrscheinlich ist mein Mainboard einfach zu schlecht.
Welches hast Du denn? Mein Prime-A ist nun auch nicht gerade ein High End Board.
Achso ein AM4 Board aus 2018, ok da weiß ich natürlich nicht, ob das funktioniert.
Den Müll können sie behalten.
Mein letzter von denen war einfach nur der letzte Schrott.
Schraube rausgerissen.
Diese wurde durch nachträgliches senken versucht zum halten zu bringen.(werkseitig)
Stands nicht richtig eingeschraubt, was dazu geführt hätte das der Kühler die Karte bei Montage sicher gekilled hätte.
Und als das dann alles gefixed war, war die Kühlleistung auch mehr als dürftig.
Bei einem Kollegen war der Anschluss für die aktive Backplate undicht...
Die sollen erstmal wieder an ihrer Qualität arbeiten bei deren Preisen.
War ein riesen Fan, aber mit dem Haufen Schrott was sie mir beim letzten mal geliefert haben, haben sie sich ins abseits geschossen.
Der alphacool war 100€ preiswerter und perfekt verarbeitet. Leider nur hässlich gewesen das Teil 🤣.
So nach dem das ganze System eingerichtet ist läuft alles endlich rund.
Die 4090FE macht einen Top Job bis her kein Lüfter brummen vernommen liegt vielleicht an der RPM Auto dreht sie derweil um die 1200-1300 .
Mit UV sollten die dann noch etwas weniger drehen.
Bin froh das ich mich für die Retour der STRIX entschieden habe so hab ich dafür das Geld im AM5 versenkt und hab am Ende auch mehr Leistung wen es auch erstmal nur geringfügig ist den Rest übernimmt dann später der 7000X3D.
Das freut mich zu lesen das es endlich passt und Du zufrieden bist👍. Es ist immer wieder super ätzend wenn Du was neues holst und irgendwas passt nicht. Hätte auch gerne wieder ne Strix gehabt aber das Gerassel wollte ich mir diesmal ersparen. Hatte nach der Lüfter Gainward ne Gaming OC und die blieb drin bis heute. Eine FE hatte ich auch aber die direkt an den Arbeitskollegen gegeben und bin nach wie vor zufrieden. Hadere nur noch mit nem Upgrade auf die 13er Intel Serie oder ob ich auf die 14er warte oder nur nen 13700k ins Z690 Board klopfe. Aber ihr wisst ja wie das ist😂🤗.
Ich habe vermutlich den seltsamsten Geschwindigkeitsschub einer 4090:
Ich habe ja 128GB Ram, die ziemlich auf Anschlag bei meinem uralt b450 Board mit 5950X laufen, daher braucht der POST relativ lange und ich bin erst nach 1-2 Minuten im Windows.
Seit der 4090 wird dieser "übersprungen?" und ich sehe nicht mal mehr den Ladebildschirm von Windows. Nach ca 7-8 Sekunden kann ich mich einloggen. Ich vermute langsam, dass meine alte 2060S einen Schlag weg hatte? Auch drehen die GPU Lüfter nicht mehr hoch, sondern der Rechner bleibt leise.
Ja ich hab auch hin und her überlegt 13900K oder AM5 .
Da ich bastel faul geworden bin hab ich mich für den AM5 entschieden der sollte mir lange Freude bereiten und auch noch für die RTX 5000 reichen.
Voller m.2 5.0 Support für die Platten ist eigentlich alles drin und dran für die nächsten Jahre.
So jetzt können die neuen Games kommen ich glaub Starfield wird ein tolles Spiel für die 4090 aber auch sehr CPU fordernd man erinnere sich an Fallout 4 .
Es stehen dieses Jahr ja einige Games in den Startlöchern.
Atomic Heart wird bestimmt ein Spass usw.
Das ist nen Bug des FE Bios, dass der Bootscreen nicht mehr sichtbar ist, kannste hiermit aber beheben:
Aber wenn du damit klar kommst, wie es jetzt ist, kannst es natürlich auch so lassen und die schnellere Bootzeit genießen :)
Ähnliche Themen
Antworten
6K
Aufrufe
310K
