[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit B-Die (Q1)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
OK danke dir für die Infos, das hilft mir schon weiter :)
Welchen mit AMD Expo ist empfehlenswerter?
Hatte durch Zufall nun beide hier und auch kurz getestet und "out of the box" sind die G.Skill, wie bereits im Hardware Unboxed video zu sehen, das "bessere" EXPO Kit. Beide haben M-Die verbaut. Unterschiede sind aber so gering, dass es fast egal ist. Das G.Skill ist aber defintiv vom Hersteller das bessere, getunte Kit.
Ich hätte noch eine Frage zu den GSkill Trident Z5. Den gibts ja von 5600mhz - 8000mhz. Welcher is da vom OC Potential empfehlenswert? Ist auf allen der ADie drauf und auch der 5600er läuft 8000mhz?
Vor kurzer Zeit hieß es noch ab 6600MHz wären sicher A-Die, falls man keine alten Lagerbestände erwischt.
Für AM5 7000er CPUen sind M-Die z.Z. völlig ausreichend. Falls sich das mit neueren Chip ändert, wäre man mit A-Die künftig besser aufgestellt.
Von einem 5600er Kit sollte man keine Rekorde erwarten. Darunter sind sicher auch welche die recht gut gehen.
Wer sich aber ein sehr teures 2 Dimm Board wie das Apex leistet, greift am besten bei einem 6600er Kit zu, um händisch auf 8000MHz zu übertakten.
Für ein 24/7 Setting ist da z.Z. eh kaum mehr zu erwarten. Es sein denn man selektiert CPU's nach IMC und Ram-Kits.
Kann man den Hersteller QVLs Vertrauen, was die Bestückung mit Hynx Chips angeht?
Konkret habe ich ein Asus 670e Gene. Der Unterschied beträgt zwischen 6000er und 5600er gerne mal 80€
Oder nimmt man das Beste in dem Fall g.skill 6000er neo mit 30er Timing? Weil die Wahrscheinlichkeit höher ist gute Chips zu bekommen?
Ich spreche hier von 2*32GB
G.Skill verbaut auf seinen Modulen natürlich unterschiedliche ICs.
Bedingt durch die Verfügbarkeit und das Erscheinungsdatum....
5600 und die ersten 6000er Kits sind immer noch Samsung (idR identifizierbar durch CL36-36-36 und C40-40-40)
SK Hynix M-Dies kamen dann in 2022 ab 6400, neue Chargen ab Ende 2022 sind aber bei 6400 nun auch (eig. immer) SK Hynix A-Dies. Die 6600er und darüber gibt es nur als SK Hynix A-Dies.
EDIT: 28.02.23
ACHTUNG:
2x16GB
bei den G.Skill 6400er Kits muss man aktuell wieder aufpassen, die scheinen wieder auf M-Dies umgestellt worden zu sein.... wie auch bei den 6000ern
entweder Glück haben oder direkt 6600er nehmen.
2x32GB
bei den 64GB Kit's mit CL32 und CL30 kann man noch Glück haben und A-Dies bekommen
Bei den preislich sehr attraktiven 6000ern muss man etwas genauer hinschauen, siehe erste Kategorie, Ausnahme immer SK Hynix M-Die bei CL32-38-38. Diese gab es kurz im Dez 22 mit SK Hynix A-Dies, sind aber jetzt wieder M-Dies. Keine Ahnung ob die z.B. ab Mitte 2023 nochmal oder komplett zu SK Hynix A-Die wechseln...
Dieses trifft auf alle Serien zu, egal ob XMP oder EXPO: S5, X5, TridentZ, REGB, Neo zu. Dort erhält man bei 6000 CL32 aktuell eher M-Dies (aktuelle Charge im Lager vorausgesetzt) und auch bei den C30-40.40 sollen M-Dies drauf sein.
Zum Übertakten (Intel) würde ich entweder immer mindestens ein 6600er G.Skill Kit nehmen (persönliches Glück/Erfahrung...) ein G.Skill 6400er Kit, wenn es sehr günstig ist und wirklich A-Dies drauf hat (Aufkleber 820A/821A) oder wenn man richtig sparen muss, Ausschau nach einem 6000er A-Die Kit halten wobei die Wahrscheinlichkeit gering ist....
Für AM5, im Grunde "Wurscht".... 6000er mit M-Die und gut ;)
Wie immer.... Ausnahmen bestätigen die Regel! Und es kann eine "Momentaufnahme" darstellen...
Bei 2x32GB Kits soll wohl bei 6000/64000 CL32-38-38 / 39-39 wie auch bei 6000 CL30-40-40 A-Die verbaut sein. Da 64GB Kits weniger verbreitet sind, fehlen hier aber 100%ige Erfahrungen.
Alternativen wären günstige Kingston, dort werden wohl bei den 2x16GB 6000 bis 6400 auch M-Die verbaut, Leider hab ich dort keine "einfache" Regel für eventuelle A-Die Bestückung in petto.
Bei Kingston findest du SK Hynix M-Dies. die 5600er müssten auch bei 2x32GB 6000 packen
günstig:
wenn du dir das frimmeln sparen willst, vielleicht trotzdem gleich 6000er nehmen... (wobei ich immer Hand anlegen würde, auch bei den 6000ern)
Nein, die sind voller Fehler oder enthalten Kombinationen, die es so nie im Handel zu kaufen gab. Nicht nur aber insbesondere bei Gigabyte fällt mir das ständig auf.
günstig: kingston-fury-beast-dimm-kit-64gb-kf556c40bbk2
Im Prinzip schließe ich mich deinen Empfehlungen im Großen und Ganzen an, bis auf diesen Teil. Es wird zwar oft geschrieben, diese Modelle wären Hynix "exklusiv", auf den 5600ern kann man aber auch S16B finden. Generell gibt es bei einigen Herstellern auf Grund der sehr konservativen Spezifikationen zumindest bis DDR5-6000 (z.B. 36-38-38, 40-40-40) auf fast allen SKU Luft, um eben nicht nur H16M/H16A zu verbauen.
Aus einem Review im Startbeitrag:
musst aber auch schauen, das war Anfang 2022.
36-36-36 nehme ich nicht, quasi immer Samsung
Kingston 36-38-38 soll immer SK Hynix sein
also wer auf Nummer sicher gehen will, CL40-40-40 meiden da auch das mal Samungs waren. CL36-38-38 hingegen vermutlich 100% Sk Hynix*.
EDIT: sagen wir 99% und ohne Anspruch auf Vollständigkeit und Richtigkeit :)
Also ist es egal ob ich die GSkill Trident Z5 6600 CL34 (F5-6600J3440G16GX2-TZ5RS) für 200€ oder die 7800er CL36 für 360€ ( F5-7800J3646H16GX2-TZ5RS) kaufe? Die Chance mindestens die 8000 CL38 vom 8000er Kit zu erreichen ist gleich?
Es gab auch später noch entsprechende Fälle. Den Link aus dem Startbeitrag hatte ich nur am schnellsten zur Hand.
Kingston 36-38-38 soll immer SK Hynix sein... CL36-38-38 hingegen vermutlich 100% Sk Hynix.
Der zweite Video-Link funktioniert bei mir nicht. 100% und "immer" halte ich für fraglich. Darauf würde ich nicht meinen Arm verwetten. Wenn mir langweilig wäre, würde ich jetzt das Web nach Belegen abgrasen... aber leider hab ich heute noch einen langen Tag vor mir :cautious:
Die benötigte Spannung und bestimmte Timings können abweichen.
Außerdem brauchst du natürlich einen Prozessor, der den Speichertakt mit macht. Es ist nicht so, als ob es da gar keine Gurken gäbe.
@emissary42 du hast natürlich vollkommen recht, 100%ig ist immer schwer aber zumindest ein guter Punkt zum Starten. Es hilft schonmal Samsungs weitestgehend auszuschließen (nicht zu 100% aber Nahe dran).
Das Video ist das gleiche, sollten nur 2 direkte Zeitsprünge sein, 1x zu "flat" 36ern und einmal Kingston "non Samsung" Timings.
Im Prinzip schon. Hier wurden mit 6600er Kits auch schon mehr als 8000MHz gezeigt.
Im Grunde muss man sich mit Ram-OC auseinandersetzen, um ein gutes Preisleistungsverhältnis, sowie gute Performance zu erreichen.
Es sollte einem auch bewusst sein, dass viele gute Ergebisse hier von Enthusiasten, die ersten viel Erfahrung haben, alles was geht aus einem System quetschen wollen und dafür auch ordentlich Geld ausgeben.
Man kann sich auf jeden Fall am Markt nach entsprechenden Kits umsehen und die Kingston Modelle dabei trotz Ihrer vergleichsweise schwachen Spezifikationen auf dem Schirm haben. Das gilt ganz ähnlich auch für ADATA. Manchmal lassen sich dadurch ein paar Euro sparen. Wenn es jedoch für einen bestimmten Takt Angebote mit deutlich besseren Timings in der gleichen Preisklasse gibt, würde ich im Zweifel immer zu einem der CL30/CL32 Modelle greifen. Es sei denn hat man hat aus persönlichen Gründen eine Abneigung gegen oder eine Affinität zu bestimmten Herstellern.
Das ist schon klar. Am Ende geht es mir nicht um den letzten Euro. Ich möchte nur nicht ein 6600er Kit kaufen um dann festzustellen das damit die Chance auf 8000 nur 80% ist, während mit einem 7800er Kit die Chance 100% wäre. Ich würde die 150€ vom 6600er zum 7800er natürlich gern sparen, aber eben nur wenns keine Nachteile gibt :) Ich hoffe man versteht wie ich das meine.
Mein innerer Zahlenmonk fühlt sich bei 7800 einfach nicht wohl XD Das sieht im OSD doof aus. Deswegen hätte ich gern 8000. Ich weiß, ist bescheuert :fresse:
Verstehe 100% kann ich als Mitleser nicht bestätigen. Dazu weiß eventuell jemand anderer genaueres zu sagen, der schon ein paar 6600er Kits auf seinem Apex oder anderen 2 Dimm Boards testen konnte.
Prozentuale Angaben sind immer schwierig, da diese eine nicht gerade geringe Menge getesteter Kits benötigen und trotzdem nur für ein bestimmtes Modell zutreffen könnten. Die DRAM ICs selbst skalieren selbst unselektiert auf dem OEM PCB von Hynix bis zu diesem Takt, solange das Mainboard und der PMIC die benötigten Spannungen zulassen. Trotzdem kann es natürlich einzelne Module und Kits geben, welche früher zu Zicken anfangen. Denn es ist eben eine Übertaktung und damit gibt es auch hier die übliche Silicon Lottery / Sample Variation.
I ended up buying this https://www.ebuyer.com/1543036-g-sk...34-ddr5-memory-black-f5-6800j3445g16gx2-tz5rk
What do you think the overclocking prospects would be on an asus z790 hero and 13900ks?
I Iooked at the cheaper kits and this was only £40 more on sale so got it for £240
Edit, would my money have been better spent on a different kit? I can still return this as my other parts haven't turned up yet.
Ich endete mit dem Kauf dieses https://www.ebuyer.com/1543036-g-sk...34-ddr5-memory-black-f5-6800j3445g16gx2-tz5rk
Was denkst du, wie die Übertaktungsmöglichkeiten mit einem asus z790 hero und 13900ks sind?
Ich habe mir die billigeren Kits angesehen und dieses war nur £40 teurer im Angebot, also habe ich es für £240 gekauft.
Edit, wäre mein Geld besser für ein anderes Kit ausgegeben worden? Ich kann es immer noch zurückgeben, da meine anderen Teile noch nicht aufgetaucht sind.
Übersetzt mit www.DeepL.com/Translator (kostenlose Version)
In welchen Kit könnten den die besseren Chips verbaut sein?
Die werden sich aktuell nicht viel nehmen.
Vermutlich gibt es die beiden Spezifikationen ohnehin bloß deshalb parallel, damit wenigstens eine davon zukünftig auch mit anderen ICs bedient werden kann.
Als Alternative kämen noch non Expo f5-6400j3239g32gx2-tz5rk
Wenn du auf jeden Fall manuell übertakten willst und nicht unbedingt ein funktionales Werks-OC-Profil benötigst, dann kannst du auch zu solchen Modellen greifen. Geh aber nicht davon aus, dass du das XMP auf AM5 nutzen kannst.
Idee ist, möglichst guten RAM zu nehmen, der auch mit zukünftigen AM5 Ryzens, welche den Sweetspot bei höheren Taktraten haben zurecht kommt
Da wir potenzielle zukünftige Sweet Spots nicht kennen, ist es müßig über passenden RAM zu spekulieren. Generell sind H16A bisher der IC, welcher die höchsten Taktraten erreichen kann. Ob der Unterschied zwischen H16M (~ 7000+) und H16A (~ 8000+) bei der nächsten oder übernächsten AM5 Architektur relevant sein wird, bleibt abzuwarten.
I ended up buying this f5-6800j3445g16gx2-tz5rk
Based upon results from other users probably between DDR5-7200 and DDR5-7600, depending upon hoch much work you are going to put into it.
Edit: From the old speed demos that G.SKILL published the theoretical limit should be around DDR5-7800.
Ich schwanke zwischen folgenden Expo
G.Skill 2*32GB 6000 30-40-40 und den 32-38-38
G.Skill 6400 32-39-39-102
Bzw. Als Low Budget Lösung die
Kingston Fury Renegade 6000 32-38-38
schwierig, beim aktuellen Ryzen fährst du eig. mit M-Die minimal besser, eh dort mal bei 2x32GB über 6400 laufen wird noch etwas Zeit ins Land gehen, was und ob die nächste Gen. kann weiß keiner, vielleicht braucht es sogar 2 Generationen um auf 6400-7000 mit 64GB zu kommen.
Wie viel Nachteil oder Vorteil du aus A-Dies ziehst kann ich dir nich sagen. Bei Intel würde ich schon versuchen an A-Die zu kommen da dort die 7000 eher fallen oder schon laufen.
Bei G.Skill würde ich laut Glaskugel fast auf A-Dies tippen... also bei den 3 Kits die du listest.
Bei Kingston würde ich konservativ auf M-Dies tippen... Man könnte aber auch noch mehr Budget gehen:
vermutlich M-Dies:
Leider kein RGB. Deswegen fallen die weg.
Wobei ich den 5600er bei nem Freund eingebaut habe. Leider ist er der DAU vorm Herren( schließt den Monitor ans Mainboard an und wundert sich warum alles so langsam ist. Die Anschlüsse seiner 7900XT 10cm weiter unten hat er nicht beachtet 🤣)
Ich denke ich werde beim 6000er mit Expo bleiben, so wie ich mich kenne wird es am Ende aus Zeit und Lust nur Profilauswahl und gut.
Oder kann man alle Daten bequem auslesen und dann Copy&Paste eintragen?
Bzgl. Sweetspot schiele ich da eh auf die letzte Generation, die auf AM5 lauffähig sein wird.
Die Differenz zwischen 6000er und 6400er ist aktuell nicht sonderlich hoch und beträgt ~10%.
Ziel ist es diesmal nur teilweiße aufzurüsten und nicht alles. (hat bisher noch nie geklappt)
Das XMP kannst du durchaus anwenden, wenn dein Mainboard dies unterstützt, es wird nur nicht laufen.
Manuelles OC bleibt manuelles OC und lässt sich nicht 1:1 zwischen Systemen übertragen. Zwar kann man pseudo-universelle Profile wie die Community Presets oder den unsäglichen "Calculator" für DDR4 heranziehen, dennoch musst du ggf. einzelne Timings und die Spannungen für deine eigene Hardware anpassen. Je höher der Takt, desto größer ist die Wahrscheinlichkeit, dass größere Anpassungen notwendig sind.
Hab ja jetzt doch ein wenig Blut geleckt und mir noch die 6600er geordert. Bin ja mal gespannt, ob die dann die 7200 packen :)
Ich habe das ASUS ROG Strix Z690-I Gaming zusammen mit einem 2600K und DDR5-6400 G.Skill Trident Z5.
Problem ist, dass der DDR5-6400 jedes Mal beim Start länger trainiert, denke mal so zwei Durchgänge, kann ich das Trainieren im Bios irgendwie unterbinden? Oder sollte man das auf jeden Fall immer durchlaufen lassen.
Mit dem ollen 2600K wird das nichts, fürchte ich :)
Wenn es ein Debug Display gäbe, könntest du sehen ob das board tatsächlich eine Bonusrunde dreht. Die Einstellungen um das DRAM Training bei jedem Start zu unterbinden, findest du unterhalb der Timings und nennt sich MRC Fast Boot. Bevor du es aktivierst, solltest du aber sicher sein, dass deine Einstellungen stabil sind und das Training der Timings konsistent. Sonst wist du beim Start früher oder später von einer Overclocking Failed Meldung begrüßt.
MRC Fastboot mal auf enable setzen
Ok ich danke euch, werde es mal versuchen, generell ist nur das XMP geladen, sonnst weiter kein OC vorhanden, das ganze läuft auch schon länger so ohne Probleme, denke sollte dann auch stabil sein, das Z690 ist zwar nur bis DDR5 6400 freigegeben, aber beim 2600K könntest du schon recht haben, werde berichten, ob es geholfen hat.:-)
Edit:
MRC Fast Boot war schon enable, hatte noch die Einstellung Mrc Training Loop Count mal auf 1 gestellt, hatte sich aber auch nichts geändert, Denke wie du schon geschrieben hast, an dem 2600K liegen.:(
12600K!
2600K war Sandy Bridge, da waren manche noch im Sandkasten...
Bios mal updaten oder schauen ob man mit angepassten Spannungen (SA, VDD/VDDQ) etwas verbessern kann oder ob er sich auch genau so verhält wenn man das XMP ladt, den Takt aber auf z.b. 6000 senkt.
Da waren manche noch nicht mal auf der Welt
Lg
