[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Dual rank, gute Idee für AMD CPUs :fresse:
Möchte gerne meine OC-Timings direkt im Ram als auswählbares Profil abspeichern. Wie genau mache ich das denn?
Im Bios vom Strix B650E-i habe ich keine Funktion dafür gefunden...
Diese Funktion muss auch vom Mainboard unterstützt werden und ist ggf (noch) nicht bei allen Modellen vorhanden.
Wenn ich mich recht erinnere haben Gigabyte und MSI bereits entsprechende Features im UEFI.
Hat schon jemand Erfahrungen mit echtem ecc ddr5 wie ksm48e40bd8km gemacht? läuft der mit einem amd 7950x3d?
Der Prozessor unterstützt ECC UDIMM ganz offiziell, es hängt also eher vom Mainboard ab.
Asus hat wieder ECC support. z.B. ASUS ROG Strix B650E-F Gaming WIFI. Andere wohl nicht.
Na wenn du das sagst....
Ich kann sagen, das es immer mal wieder korrigierte Fehler mit ECC gibt.
Warning 25/01/2023 17:06:09 WHEA-Logger 47 None
Warning 06/01/2023 03:12:48 WHEA-Logger 47 None
Warning 06/01/2023 02:49:39 WHEA-Logger 47 None
Warning 06/01/2023 02:26:42 WHEA-Logger 47 None
Warning 06/01/2023 02:03:45 WHEA-Logger 47 None
Warning 18/12/2022 02:19:09 WHEA-Logger 47 None
Warning 18/12/2022 02:07:19 WHEA-Logger 47 None
Warning 09/12/2022 17:12:03 WHEA-Logger 47 None
Warning 23/11/2022 00:54:47 WHEA-Logger 47 None
Warning 20/11/2022 17:34:27 WHEA-Logger 47 None
Warning 18/11/2022 22:17:57 WHEA-Logger 47 None
Warning 04/11/2022 20:40:45 WHEA-Logger 47 None
Warning 26/10/2022 00:15:57 WHEA-Logger 47 None
Warning 14/10/2022 10:37:24 WHEA-Logger 47 None
Warning 14/10/2022 10:16:30 WHEA-Logger 47 None
Warning 14/10/2022 09:57:49 WHEA-Logger 47 None
Warning 14/10/2022 09:10:00 WHEA-Logger 47 None
Warning 14/10/2022 08:22:05 WHEA-Logger 47 None
Warning 14/10/2022 07:58:02 WHEA-Logger 47 None
Warning 14/10/2022 06:45:54 WHEA-Logger 47 None
Warning 14/10/2022 06:21:48 WHEA-Logger 47 None
Warning 14/10/2022 05:57:39 WHEA-Logger 47 None
Warning 14/10/2022 05:33:29 WHEA-Logger 47 None
Warning 12/10/2022 00:10:08 WHEA-Logger 47 None
Gibt schon einen Grund, warum DDR5 build-in ECC hat. (Auch um den Produktionsausschuss und das Testen zu reduzieren)
Das externe DDR5 ECC stellt sicher, das die richtigen Daten überhaupt am DDR5 angekommen sind.
Solange die Programme nicht abbrechen oder games zurück ins Windows springen gut.
@emissary42
Hallo. Rein interessehalber, was ist aktuell das höchste Binning von Samsung DDR5 welches in freier Wildbahn vorkommen kann? Wären 6400 C40 möglich?
Es gab diverse 6400er (und bis 7000er) Spezifikationen, die teilweise auch noch immer in den Mainboard QVL bei ASUS und Gigabyte auftauchen. Die (meisten davon) habe ich jedoch nie in freier Wildbahn gesehen. ASRock und MSI haben ihre QVL offenbar irgendwann bereinigt und alle diese "Pseudo-Specs" auch ganz rausgeworfen.
Das könnte eventuell noch etwas dauern. Aktuell gibt es den entsprechenden Speed Bin (6400B) noch nicht mal in den Datenblättern oder im Decoder.
Morgen!
Kann ich hier erkennen welcher „Die“ das ist, bzw Chip?
Seh leider nicht mehr auf dem RAM
Versteh nicht was das Q1 / W2 / Q3 bedeuten soll von hier;
Danke
Updates:
1) Informationen zur IC-Identifizierung von Crucial & Micron Modulen/Kits im Startbeitrag hinzugefügt
2) einige OC-Guides ergänzt (die sind in Ressourcen im Web zu finden) --> Ihr dürft gern weitere vorschlagen!
hm, so langsam sollten doch mal 64gb kits schneller als 6400 kommen oder? Ich warte mir hier nen Wolf :(
Einfach ein 6000-6400er Kit mit A-Dies kaufen und dann OC, gibt aber kaum Boards die dann 7000 schaffen, deshalb wird vermutlich nix schnelles angeboten.
Mit etwas Glück laufen die dann bei optimiertem Bios auf Apex oder Kingpin bei 6800-7200 (ganz vereinzelt schon gesehen)
Oh, hängt DR noch so hinterher? Hatte gehofft es kostet nur so 200-300 Mhz ausgehend von einem SR Kit mit gleichen ICs... :-/
Nächste Runde?
Samsung 16 GBit D-Die detected, 5600B Bin. Quelle_ OCN
Bloß nicht zu viel erwarten :sneaky:
Hallo Leute
Sorry vorweg falls einer meiner Fragen schon zig mal durchgekaut wurde
Kann mir einer die Unterschiede zwischen den Corsair Vengeance RGB und den corsair Dominator C30 erklären? Ich werde nicht ganz schlau daraus warum es von denselben hersteller exakt dieselben Kits geben sollte. Vengeance ist ja eher die "Budget" Serie, korrekt?
Auch wollte ich mal fragen was aktuell das beste Zen4 kit ist, wenn man erstmal bloß xmp bzw Expo laden will und fertig, aber sich gerne noch die Möglichkeit offen halten möchte vielleicht in Zukunft doch mal hand anzulegen.
Mein bisheriger Eindruck scheint es das Gskill Z5 neo C30-38-38 zu sein oder doch eines der beiden Corsair C30?
Ich lese schon einen Moment mit, aber mir ist noch nicht ganz klar geworden was das Beste ist was man sich Stand heute für AMD an DDR5 kaufen kann.
Wenn ich auf Geizhals suche sehe ich als Alternativen für zwei 32GiB Module entweder 6400 MHz oder etwas bessere Timings:
DDR5-6000, CL30-40-40-96 - F5-6000J3040G32GX2-TZ5K
DDR5-6400, CL32-39-39-102 - F5-6400J3239G32GX2-TZ5RK
(https://geizhals.de/?cat=ramddr3&xf=1454_32768~15552_10.0~15903_DDR5~254_6000~256_2x)
DDR5-6000 scheint in der Regel out-of-the-box zu laufen und ist daher die Standardempfehlung.
Aber was ist nun schneller wenn man sich die Zeit nimmt und durch Overclocking die 6400 zum Laufen bekommt?
Normalerweise sagt man ja Takt vor Timings. Aber >6000 MHz soll es ja auch Probleme mit dem Verhältnis der drei Taktraten geben. Daher meine Verwirrung.
(BTW: Ich plane gerade mir 7950X3D und B650E Aorus Master zu kaufen und hätte gerne für meine Virtualisierungs-Geschichten 64GiB RAM)
Bei AMD ist aber Timing > Takt!
Welches Board bis ~700€ ist für hohen Ramtakt bei DDR5 eigentlich am besten geeignet? Kann jemand da mal das eine odere andere Board nennen, das wär nice, danke!
@Viper8
Wenn du Intel meinst, dann ist eigentlich das Asus Z790 Apex die erste Empfehlung. ;)
Ich habe hier das Gigabyte X670E Aorus Xtreme und in der QVL waren bisher die F5-6000J3040G32GX2-TZ5N ( GSkill Trident Z5 Neo 64GB-Kit) mit drin. Jetzt gibt es eine aktualisierte QVL und das sind die Neo-Kits (64GB) komplett rausgeflogen! Da sind nur noch die Kits mit XMP drin! Wahrscheinlich liegt es daran, dass die aktuell lieferbaren Neo-Kits jetzt A-Dies sind (waren bisher M-Die) - und die sind wahrscheinlich nicht getestet. Finde ich irgendwie verrückt, für ein X670E-Board die dafür gemachten Riegel nicht zu nehmen, aber dafür die eigentlich für Intel-Boards gemachten. Die sind laut QVL mit Samsung-Chips bestückt. Wahrscheinlich sind die auch schon auf A-Die umgestellt und fliegen auch bald raus, keine Ahnung…
Was würdet Ihr machen? Neos zurück und die „normalen“ Trident Z5 mit XMP holen?
Berni
Einfach die Neos behalten drauf stecken und testen. Wenn ich es lese, hast du doch schon die Neos mit 6000 und A-dies zuhause, was "besseres" wird du nicht bekommen ;)
Warum solltest du, nur weil Gigabyte seine QVL aktualisiert hat, den RAM wechseln?
