[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der Stecker ist irgendwie voll der Fluch .
Einmal was neues und echt viele Hersteller haben damit Probleme . Mit Corsair scheint man noch Glück gehabt zu haben . Zumindest nichts negatives gelesen . Wie soll das mal werden , wenn die ganzen Anschlüsse an den Mainboards dann geändert werden .
Kann das mit Corsair nur so bestätigen.
Hab mir durch die Instabilitätsprobleme die ich mit meiner 4090 hatte auch nen Kabel von Corsair bestellt (vorher Cablemod) und seit dem keinerlei Probleme mehr gehabt.
Finde es auch schwach, das auf die User abzuwälzen, weil es offensichtlich ja nicht so einfach zu sein scheint, das Kabel richtig zu produzieren.
Habe das 4x 8Pin auf 16 Pin Cablemod Kabel seit fast einem halben Jahr dran. Letztens beim Mainboardwechsel hatte ich gezwungenermaßen das Kabel nochmal gelöst und alles tutti. Bis zur 5090 wird es wohl nicht mehr abgemacht.
So, da ist das gute Stück, der Vergleich zur eh schon großen 3090 ist schon beeindruckend.
Es fehlt noch der GPU Ständer, der mitgelieferte konnte leider nicht verbaut werden, der wäre mit dem MoBo verschraubt worden, das ging aber nicht wegen meiner Soundblaster. Der Kabelbinder unten ist nicht besonders fest gezogen er soll nur dafür sorgen das der Adapter nicht groß nach links bzw. rechts rutschen kann. Verwendet hab ich den BeQuiet.
Dann gestern direkt Bammel bekommen, die Benchmarks aus dem 3d Mark liefen alle problemlos durch, Elden Ring ohne Probleme, gleiches bei RDR2. Dann Jedi Survivor gestartet und quasi innerhalb von 3 Minuten Crash, zwei mal. Dann mal versucht Spiel zu reparieren und DX Shader Cache gelöscht. So wie es aussieht hat das geholfen, die Cut-Scene auf Jedha wo man wieder auf Cere trifft lief dann durch.
ist hier jemand mit seiner 4090 schon durchs feuer gegangen :d?
jopjop, sieht stellenweise schon ganz fein aus und fordert die karte tatsächlich ziemlich heftig. mich haben da allerdings die nur minimalen einstell-optionen "ingame" und die teilweise extremen clipping-fehler genervt :d ineinander liegende bäume, texturen die ziemlich krass abgeschnitten sind oder stark erkennbare "übergänge" zeigen etc pp. einfach mal selber gucken, lohnt sich nat. trotzdem, bin halt einfach zu pingelig bei sowas *g* 🫣 aber für das geld, das er für dieses preset von entwicklern haben möchte, muss er sich meiner meinung nach noch bissl reinhängen :)
einen teil der optionen kann man aber auch in den .inis im Users\<username>\AppData\Local\MWBurnedDeadForestBiome\Saved\Config\Windows-verzeichnis anpassen, zB die auflösung.
ich schau mir jetzt mal mein bequiet kabel und die steckverbindung der karte an...
Na endlich!! Wer holt sich auch eins?? 😆👋
Ich hole, ich riskiere, was soll da schon schief gehen...
No risk, no fun
War eh nur ne Frage der Zeit, bis die ganzen No names daherkommen!))
iHaospace 16 Pin 12VHPWR GPU Power Adapter 180 Degree Turn Connector, 12+4Pin PCIe5.0 ATX3.0 Grafikkarte Powe Kabel umgekehrter gewinkelter Adapter für RTX 4080 4090 (Type B) https://amzn.eu/d/8gMKapE
Naja, irgendwie liest sich das alles etwas schmierig und nachdem ich nun das ganze Video gesehen habe, sehe ich hier keine Probleme für den NVidia Adapter. Auch mit meinem Seasonic Kabel mache ich mir keine Sorgen. Habe ja auch ein Fasgear hier, allerdings nur kurz im Einsatz gehabt. Aber mit "Langzeittests" braucht mir keiner kommen, länger als 7 Monate kann ja noch keiner seine Karte haben, mit den Cablemod Dingern ist die mögliche Zeit ja noch kürzer. Also wenn da schon so viel schmilzt, sehe ich das Problem eben nicht bei NVidia, sondern bei Cablemod. Könnt ja sein dass sie gemerkt haben, dass sie ein scheiss Produkt entworfen und verkauft haben und nun nach dem Motto "Angriff ist die beste Verteidigung" proaktiv in die Offensive gehen.
Aber kann sich natürlich jeder so verrückt machen lassen wie er will, vielleicht ist was dran. Who knows.
Es wird höchste Zeit, für die 4090ti
Wäre eigentlich Zeit für die Ankündigung einer 4080 TI . Meine da ist schon gut Luft zwischen 4080 und 4090.
Aber scheinbar braucht es nicht diesen Schritt. Den meisten hier sollte dies natürlich egal sein .
Ne 4090TI juckt mich irgendwie null. Die 10% Mehrleistung brauche ich nicht zwangsläufig.
So, nachdem ich heute mal Afterburner ausgeschaltet habe und die Karte hab Stock laufen lassen gings ab.
Hab ein Spiel gestartet und die Karte hat etwa 400W gezogen, innerhalb von paar Sekunden fing der 12VHPWR Port an wie verrückt zu qualmen.
Hab natürlich sofort den PC ausgeschaltet. Eine schöne Plastikblase hatte sich am Port gebildet. Der Cablemod-Adapter war kochend-heiß, konnte ihn nicht mehr anfassen. Hab dann versucht den PC neu zu starten, kein Bild mehr. Konnte dann per Remote-Desktop auf den PC zugreifen, keine 4090 mehr erkannt, egal welches Bios, es wurde mir die iGpu der CPU angezeigt obwohl HDMI an der Karte hing. Könnte an einer nicht ausreichenden Stromversorgung liegen, Port und Adapter waren ja anscheinend ordentlich von innen verschmort, da auch aus dem Adapter Qualm aufgestiegen ist.
Also Karte rückgebaut, eingepackt und zum Händler, Geld erstattet. So neue Suche beginnt. Ich bin definitiv durch mit dem Cablemod-Adapter, der kommt mir nicht mehr ins Haus. Ohne den Adapter lief die Karte einwandfrei über mehrere Monate.
Ob es der Adapter war oder doch die Karte selbst, keine Ahnung. Aber nochmal teste ich das nicht.
...Also Karte rückgebaut, eingepackt und zum Händler, Geld erstattet. So neue Suche beginnt. Ich bin definitiv durch mit dem Cablemod-Adapter, der kommt mir nicht mehr ins Haus. Ohne den Adapter lief die Karte einwandfrei über mehrere Monate...
Ergibt für mich gerade keinen Sinn.
Ich hatte ein Kabel direkt an der Karte, nur mit derbem Biegeradius dank meines Gehäuses. Kabel bestimmt 5X abgeklemmt und angeklemmt. Dann bin ich auf den Adapter umgestiegen, den ich dann nicht mehr entfernen konnte und dann bei 400W und nicht wie vorher 330 bis 350W wurden rauchzeichen abgegeben.
Ganz klar User Problem.
/s
:fresse2:
Würde Nvidia auch sagen :ROFLMAO:
Wenn die Karte doch vorher lief kann es doch nur an dem Cablemod Adapter gelegen haben.
Und der Händler hat die Karte einfach so zurückgenommen?
Jo. Wenn die Story stimmt, ist das ja nun eindeutig n Cablemod Problem.
Keine Ahnung was da der Fehler war. Stecker saß komplett eingesteckt im Port. Diese Adapter sollen ja eh ziemlich warm werden. Igor hat dazu nen Artikel geschrieben, bis zu 65°C meine ich gelesen zu haben. Denke der Port bzw. die Verbindung der Pins waren es der die Temperatur einfach nur weitergeleitet hat ans Gehäuse des Adapters, weil gekokelt hat es zuerst im Port inkl. Blase.
Wenn da drinnen an den Pins Temperaturen von 300 °C - 400 °C entstanden sind, dann sind die natürlich schnurstracks über die Leiterbahnen am Gehäuse dran.
Ja der Händler hat die Karte zurück genommen und Geld direkt wieder auf mein Paypal Konto erstattet.
Was soll daran nicht stimmen?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
