[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wo kann man denn da Taktraten und Temps sehen usw.? Ohne ist doch witzlos. Komme jedenfalls stock und @ 2.910MHz auf jeweils ca 5.750 Punkte (DX12). Ist aber auch schön warm bei mir im Büro und Karte läuft im Quiet BIOS.
Hat jemand zufälligerweise einen OCCT Screen als Vergleich?
RTX 4090 max. 450W auf Luft mit OCCT 3D Adaptive Steady Extreme
Bin zur Zeit mit einem PhaseChangePad am Rumexperimentieren und zweifle, ob der HotSpot nicht doch zu hoch sein könnte.
Montagefehler kann ich inzwischen ausschliessen.
Schlecht ist mein Ergebnis jedenfalls nicht, wenn man sich den internationalen Vergleich bei CB anschaut:
Dann reich doch da dein Ergebnis ein, 1. Platz ist dir dann sicher. Was hält dich auf?
Aber Lieferung im September mittlerweile, ansonsten netter Preis.
Hallo zusammen, habe eine kurze Frage und im Netz dazu nicht wirklich was gefunden.
Meine Frau macht oft Homeoffice und nutzt dazu meine Monitore, die an meinem System angeschlossen sind.
Also unter den Schreibtisch krabbeln und Kabel vom PC in den Laptop. Nervt mich mittlerweile.
Wenn ich mein komplettes System jetzt dauerhaft an eine Dockingstation anschließen würde und immer nur das USB-C Kabel wechseln müsste, wäre das bedeutend angenehmer.
Frage ist, gibt´s da bei meiner 4090 Verluste beim zocken, wenn ich dann Quasi vom PC zu meinen Monitoren eine Dockingstation dazwischen schalte?
@gachan1712
Monitore haben ja meist mehr als einen Eingang. Hab selbst z.B. den Monitor über Displayport am Rechner und über HDMI an der Dockingstation vom Notebook.
Ich hab auch schon beim Benchen den Monitor onboard auf dem Mainboard gehabt und es kamen manchmal sogar mehr Punkte bei raus als direkt an der 4090 angesteckt. :d
Den Rechner über USB-C mit der Dockingstation verbunden hab ich aber noch nie.
@Dampfkanes
Da bin ich überhaupt nicht drauf gekommen, natürlich haben die mehr als einen Anschluss.
Thema erledigt (y):LOL:
Manchmal kann´s so einfach sein :sneaky:
@gachan1712
Also über die 4090 rechnen (benchen) lassen und den Onboard-Ausgang genutzt?
Nachdem es hier jetzt um höhenverstellbare Schreibtische geht ;-)
Wer einen wirklich solide höhenverstellung sucht … hatte wirklich einige durchgetestet
Der hier ist auch ausgefahren deutlich stabiler als die üblichen bekannten.
Sorry für OT... ;)
Trifft dieses massive Wackeln nur auf die flexispot´s mit 2 statt 4 Beinen (beide haben Vor- und Nachteile) zu?
Bis Ende des Jahres ziehe ich um, da brauche ich was Neues. Muss keine "500kg" können, aber ausgefahren stabil, als "wackelfrei" sein
Ideal wäre ein Ladengeschäft, das evtl. versch. Hersteller führt. Aber ist wohl kaum zu finden. Oder doch?
Finde es ja interessant, dass die 4090 noch immer nicht auf dem Preisniveau von vor einem Jahr runter gefallen ist. Da gabs die 4090 für so ab 1600 Euro. Günstigste ist aktuell auf 1745 Euro laut Geizhals. Ich hab meine vor ca. nem Jahr für 1700 gekauft, kostet aktuell 1874 Euro. Soll mir recht, hebt den Wiederverkaufswert. Mal sehen wo die Preise sind wenn die 5090 erscheint, vermutlich nicht besser, weil so wie ich NVidia kenne wird die 4090 dann schon nicht mehr hergestellt und nur noch Restposten verkauft.
Da ich den Verkaufspreis alter Hardware direkt mit in den Kauf neuer einkalkuliere, ist der Wert der 4090 zu dem Zeitpunkt daher nicht unwichtig. Mal gespannt was ich laut NVidias Meinung nach für das Upgrade draufzahlen soll.
1000€ vermutlich.
irgendwo hatte ich gelesen vor kurzem, dass die Produktion jetzt schon halbiert wurde, oder halbiert wird; wie auch immer, die Neupreise denke ich jetzt mal werden wohl nicht mehr allviel besser, eher wieder schlechter :( was ja dann gut ist für den Wiederverkauf:)
Sie haben aus dem Fehler gelernt mit der 3090 und Co wo zum Release der RTX 4000 die Lager voll waren das war ja auch der Genickbruch für EVGA
Gestern Abend noch Calisto Protocol (ist inzwischen im Game Pass) zu Ende gezockt, nach zig Patches läuft es inzwischen echt gut.
Und ich muss sagen:
Ich hatte mit dem Game mehr Spaß als mit dem Dead Space Remake. Kann nicht verstehen woher das Spiel (außer auf technischer Ebene) seinen dermaßen schlechten Ruf herhat…
Und ich muss sagen:
Mir geht's genau auch abdersrum. Fand dead space um einiges besser aber hatte das Ursprung game nicht gezockt.
Und ich muss sagen:
Im direkten Vergleich mit Deadspace fand ich Deadspace besser, aber als eigenständiges Spiel ganz inordnung. Dieses überall durchschlingen fand ich bisschen nervig und dass der Gegner mit 2 Köpfen viermal kamen fand ich bisschen übertrieben und was mir auf die Nüsse ging waren diese Viecher die so sind wie die Klicker von Last of Us bzw. einfach viel zu viel davon. Das Spiel soll ja eigentlich Stress erzeugen, aber war eher an manchen Stellen nervig als fordernd, aber für 6,90€ war es vollkommen ok .
Würde es nicht NG+ mehr spielen . Bei Deadspace werde ich irgendwann ein NG+ starten. Das war für mich ein rundes Game.
Und ich muss sagen:
Äh, ich will ja keine Spaßbremse sein, aber bist du im Thread verruscht? Hier gehts nicht um Videospiele. :d
