[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Interessante Infos!
Weiss jemand wie das bei Inno3D ausschaut?
Ob Tochter-, Bruder- oder Schwippschwager-Gesellschaft - ist mir egal. Hauptsache, die Karte ist günstig, schnell und hält lange :fresse:
ich hab mit meiner Inno3D 4070ti bisher absolut keine Probleme, dafür ist sie aber erheblich kompakter als die ASUS 4070ti
Gerade mal aufgefallen das es moment garkeine KFA2 RTX 4090 mehr gibt.
Waren glaube auch garnicht so schlecht.
Wie gut ein Hersteller ist zeigt sich dann halt meistens wenn ein Mangel in Erscheinung tritt, und Inno3D hat sich was das angeht nicht so sehr mit Ruhm bekleckert.
Wenn man als User Wärmeleitpads für 60€ bestellen und montieren muss um bei einer Wakükarte die üblichen Temps zu erreichen weil der Hersteller es auch bei einer Nachbesserung nicht geregelt bekommt, dann ist die Karte halt sehr wahrscheinlich von Inno3D.
Wobei da man jetzt die Frage stellen sollte ob ALC ne Teilschuld hat, weil wenn ich ne Lieferung
Wasserblöcke habe und dort steht, dass diese Pads drauf kommen wird das in der Produktion nunmal so umgesetzt.
Bei den Luftkühlern scheint es ja zu funktionieren und diese werden in der Regel auch nur bestellt vom Hersteller.
Ist alles natürlich letztendlich ne QS Geschichte, aber bis da ggf. was passiert ist sind wohl etliche Karten dann schon im Umlauf gekommen und wenn die Temps noch innerhalb der Spezifikationen bleiben, dann wird das Thema auch problematischer.
Wenn Endverbraucher das selbst NACH fehlgeschlagener Nachbesserung besser macht dann sollten sich die Inno3D Techniker wohl vom Endverbraucher schulen lassen ? :LOL:
Das ist halt ein kompletter Fail in Sachen QS und man könnte auf den Trichter kommen, dass entweder die Techniker einfach unfähig sind, nicht getestet wird und sowieso keine Pads von ALC genutzt werden.
Vermutlich nicht getestet. Dafür muss man erstmal einen Wakü Kreislauf zur verfügung haben und nimmt mehr Zeit in Anspruch.
Naja die 4090 Frostbite gibt es garnicht mehr zu kaufen und bei der 4080 sind sicher noch die Reste.
Vielleicht auch schon richtig montiert^^ Wird aber auch mit dem Wakü kram immer weniger.
Sonst gabs auch noch Gigabyte , Asus, MSI und natürlich EVGA mit Wasserblock.
Anscheinend ist die Nachfrage nicht mehr so groß.
Hab’s im Deckel verbaut, damit ich keine Luft mit ziehe, weil sonst der Punkt wo die Anschlüsse wären der höchste wäre und da sich die Luft dort sammelt und diese dann immer mitgezogen werden würde. Sorgt dafür, dass die Pumpe lauter wird oder im schlimmsten Fall schneller defekt geht. Man kann leider bei der AIO schlecht reinschauen wie gut diese befüllt ist. Daher so die Entscheidung. Bei mir zumindest sind die CPU Temps beim Gamen im grünen Bereich.
Heißt heißeste Kerne bei unter 70 Grad Celsius in der Regel.
@MS1988
Hab die rtx 4090 und i5 13600kf, 360 AIO im Deckel, 1x 120er Lüfter hinten, 2x 120er Lüfter vorne. Alle Lüfter laufen 1400umdrehungen.
Nach 1Stunde Zocken God of War in 4K ohne dlss habe ich in HWinfo folgende Maximal Temperaturen ausgelsen.
Graka: 71° Speicher 76° Hotspot 83,5° Max 444,820 Watt
CPU P-cores Heißester 79° Kühlster 69°
E-cores Heißester 71° Kühlster 66° max 120.829 Watt
Könntest du bei gelegenheit vergleichswerte aufschreiben?
Vermute, je teuerer die Karten sind, desto weniger werden das Risiko einer Umrüstung auf wakü eingehen wollen. Bzw. Eine eine custom wakü betreiben. Die aio Varianten sind zudem sehr gut geworden und daher eine Alternative.
Generell ist die Nachfrage nach der 4090 hoch, da die eben auch fürs ML genutzt werden kann.
Und die Verfügbarkeit dank des Embargos in China auch schlecht, irgendwann gehen halt selbst die vor dem Embargo gehorteten GPUs aus.
@MS1988
Wenn dir das was nutzt.
Hatte jetzt 10-15 Minuten Dying Light 2 laufen.
CPU hatte max. 150 Watt laut Overlay. AVG 120 Watt.
Die Caselüfter laufen mit 800 U/min ( 140mm)
Die Noctua Lüfter müssten zwischen 1000-1400 U/min gelegen haben beim Zocken.
So ist die Lüfterkurve eingestellt für den Tempbereich.
Wassertemp beim zocken 33°C. Raumtemp 20°C
Hier System und Screenshot.
Müssten halt kleinere Lukü von den Herstellern verbaut werden, dann steigt die Nachfrage nach Wakü wieder. :LOL:
nein, dann sinkt einfach die Verkaufszahl von "größeren" Gehäusen wieder 🤪
Das kamen sie davor auch schon, denn PNY ist einer der GPU Auftragsfertiger für EVGA, zumindest für das PCB.
PNY baut doch auch die Founder Edition und die Quadro etc.
Jo PNY ist einer der größten Vertragspartner, immer wenn Leute in Foren schreiben sie wollen keine „billige noname“ PNY Karte, sondern lieber ne tolle Asus muss ich lachen. Da man direkt merkt wieviel Ahnung sie haben. :d
PNY und Auftragsfertiger?
Die nutzen doch überwiegend nur Referenzplatinen und umgelabelte Karten von den großen Fertigern!
Für die Profi Quadro etc. Karten sind sie auch nur einer der Vertriebspartner für NVIDIA.
Erst mit den XLR8 Karten der letzten beiden Generationen hat man auch angefangen eigene Karten zu entwickeln.
Meine alte XLR8 GTX 1660 war 1:1 eine Palit und die aktuelle RTX 3070 Uprising ist 1:1 von Manli, mit nur anderen Stickern drauf. :bigok:
Hab den i5 13600kf mit rtx 4090 mit 32Gb Ram
Beim zocken zeigt mir der Afterburner schwankende Taktraten bei P cores und E cores.
Also überhauptnicht so wie bei diesem Kollegen hier mit seinem i9 14900ks
Darf ich fragen wie das bei euch ist?
Das hängt vom Spiel ab und ob man ein FPS-Limit eingestellt hat. Ich spiele immer mit 117fps Limit (120Hz Monitor). Bei Dead Space lief mein 14900K auch immer mit 5,7GHz, obwohl die Kerne meistens vielleicht 25% ausgelastet waren. Deshalb habe ich mir auch mal ein Profil im Bios erstellt, wo die CPU max. 5,2/4,0GHz für die P/E-Cores macht. Damit waren die FPS immer noch ausreichend. Bei Terminator Resistance, was ich gerade spiele, habe ich eine CPU-Auslastung um die 3-5% und da taktet die CPU nie auf das Maximum. Hängt also davon ab, wie die CPU gefordert wird.
Hab mal ne Frage, da ich aktuell Probleme mit meiner Karte habe.
Nehmen wir an ich mache einen 3d Mark Stresstest mit einer Full HD Auflösung. Ich gehe davon aus, dass hierbei weniger Vram verbraucht wird als wenn ich das mit 4k z.B. mache.
Sehe ich das richtig?
Die GPU wird aber gleich belastet nu mehr FPS produziert?
ChatGPT sagt:
Ja, du hast das grundsätzlich richtig verstanden. Hier sind die Details:
1. **VRAM-Verbrauch**: Die Auflösung eines Tests oder Spiels hat einen direkten Einfluss auf den VRAM-Verbrauch. Bei einer niedrigeren Auflösung wie Full HD (1920x1080) wird weniger VRAM benötigt als bei einer höheren Auflösung wie 4K (3840x2160). Der Grund dafür ist, dass mehr Pixel mehr Speicher für die Verarbeitung und Speicherung von Daten benötigen.
2. **GPU-Belastung und FPS**: Bei einer niedrigeren Auflösung wie Full HD wird die GPU zwar auch belastet, aber da sie weniger Pixel verarbeiten muss, kann sie mehr Frames pro Sekunde (FPS) liefern. Bei höheren Auflösungen wie 4K muss die GPU mehr Pixel verarbeiten, was zu einer höheren Auslastung führt und normalerweise die FPS reduziert.
**Zusammengefasst:**
- **VRAM-Verbrauch**: Full HD < 4K
- **GPU-Belastung**: Bei Full HD wird die GPU weniger beansprucht und kann mehr FPS liefern, während sie bei 4K mehr belastet wird und weniger FPS produziert.
Es ist wichtig zu beachten, dass auch andere Faktoren wie die Einstellungen für Texturen, Schatten und Post-Processing-Effekte den VRAM-Verbrauch und die GPU-Belastung beeinflussen können.
Falls du Probleme mit deiner RTX 4090 hast, könnten diese auch durch andere Faktoren wie Treiberprobleme, thermische Drosselung oder Netzteilprobleme verursacht werden. Es könnte hilfreich sein, diese Aspekte ebenfalls zu überprüfen.
So habe endlich die 4090 TUF mit der Watercool Ultra Bodenplatte in Betrieb genommen. Der Unterschied kann sich sehen lassen. Bei gleicher Pumpenleistung geht die Drehzahl und auch der Durchfluss doch ein wenig in die Knie. Die Temparatur scheint es jedoch nicht gross zu jucken. Zum Glück konnte ich die Stimme in mir unterdrücken und bin weiter ohne Liquid Metal gefahren, ansonsten hätte ich wohl noch leicht bessere Werte.
Vorher:
Delta GPU = 21.4K
Delta GPU Hotspot = 34.8K
Pumpe ~85%
Nachher:
Delta GPU = 14K
Delta GPU Hotspot = 22K
Pumpe 100%
Nachher2:
Delta GPU = 14.1K
Delta GPU Hotspot = 22.2K
Pumpe ~85%
P.S. der Stromstecker ist weiterhin in Takt. :d
hat schon jemand gebencht :)?
Ähnliche Themen
