3D Mark 2006 Benchmark-Thread + Liste
Amd 3200+ @ 3500+ = 2250mhz
geforce 6100 onboard
2x512 MB ram dual chanel 3,4,3,8 1t
habe leider kein link gefunden
System and CPU Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer
Mobo Model 939NF4G-SATA2
AGP Rates (Current/Available) N/A / N/A
CPU AMD Athlon(tm) 64 2251 MHz
Physical / Logical CPUs 1 / 1
MultiCore 1 Processor Core
HyperThreading Not Available
FSB 200 MHz
Memory 960 MB
Display Information
Graphics Chipset NVIDIA GeForce 6100
Driver Name NVIDIA GeForce 6100
Driver Version 9.1.2.8
Driver Status Non WHQL - Not FM Approved
Co-operative adapters No
Video Memory 256 MB
Core Clock N/A
Memory Clock N/A
Benchmark Settings
Default Settings Yes
Program Version 3DMark06 Revision 0 Build 2
Resolution 1280x1024
Anti-Aliasing None
Texture Filtering Optimal
Vertex Shader Profile 3_0
Pixel Shader Profile 3_0
Force Full Precision No
Disable Post-processing No
Force Software Vertex Shaders No
Force Software FP Filtering No
Disable HW Shadow Mapping No
Color Mipmaps No
Repeat Count Off
Fixed Framerate Off
Main Test Results
3DMark Score 165 3DMarks
SM 2.0 Score 76 Marks
SM 3.0 Score N/A
CPU Score 845 Marks
Detailed Test Results
Graphics Tests
1 - Return to Proxycon 0.499 FPS
2 - Firefly Forest 0.764 FPS
CPU Tests
CPU1 - Red Valley 0.267 FPS
CPU2 - Red Valley 0.428 FPS
HDR Tests
1 - Canyon Flight (SM 3.0) Not Supported
2 - Deep Freeze (SM 3.0) Not Supported
Feature Tests
Fill Rate - Single Texturing N/A
Fill Rate - Multi Texturing N/A
Pixel Shader N/A
Vertex Shader - Simple N/A
Vertex Shader - Complex N/A
Shader Particles (SM 3.0) N/A
Perlin Noise (SM 3.0) N/A
Batch Size Tests
8 Triangles N/A
32 Triangles N/A
128 Triangles N/A
512 Triangles N/A
2048 Triangles N/A
32768 Triangles N/A
Intel Pentium D 805 2,6GHz OC @ 3,81GHz
2x 512 MB Corsair 4.0-4-4-12
GeForce 6800 GS @ Core-Takt: 531 MHz
RAM-Takt: 1,21 GHz​
DUALCORE no SLI
Vr6freunde 6900 AMD x2 3800+ @ 2800mhz 2*1024 Tracer 3.3.3.8 Asus 7900GTX Extrem 720/1800
Treiber 91.28
So nun besser @ Resident1985 :lol:
*Update!*
Stegan - 5238 Punkte - AMD Athlon X2 3800+ @ 2900mhz - 2x 1GB Corsair 241Mhz 3.0-4-4-8 - X1800XT @ 700/800 mhz Cat. 6.5
Hio,
ein update mit CF ! ! !
mikaTech - 9191 - Intel Pentium D 950@4,42GHz - 2x512MB OCZ PC-533 @ 800 4-2-3-8 - Crossfire X1900 + X1900XT ! Orig. Takt ! Cat 6.4
gruss
mika
AMD Opteron 146 2,0 GHz @ 2,90 GHz
1GB Infineon DDR333 @ 193 MHz @ 2,5-3-3-6
XFX GeForce 6800GS 485/1100 Mhz @ 520/1200 MHz
(habe leider kein i-net an meinem rechner -> somit kein link...)
ATI PS 3.0 Singlecore + non-Crossfire -
webwilli - 6300 Punkte - Intel 650 @ 4427 MHz - 2 x 1024 MB G.SKILL DDR2 F2-6400PHU2-2GBHZ 434 MHz 4-4-4-12 - HIS X1900XTX@765/900 - Catalyst 6.5
so, ich auch mal wieder :)
nVidia PS 3.0 Dualcore + SLI
TM30 - 9354 - X2 3800+ @ 2800Mhz - 2x256MB TCCD 280Mhz 2,5-4-4-8 1T - 7900GTX SLI @680/1760Mhz - Forceware 91.28
Singlecore - No SLI - PCIe
Beschleunigen - 5.203 - AMD A64 Newcastle @ 2,60GHz - 2048MB Samsung UCCC @ 260MHz 3-4-4-8-1T - 7900 GTX @ 650/800MHz - Forceware 91.28
compare-link
tobi
*Update*
So hab jetzt einen dual Core im System dann steh ich jetzt auch nehme ganz so alleine in der Liste
ATI PS 3.0 DualCore + Crossfire
Taucher - 8332 - X2 3800+ @ 3000MHZ - 2 gb S.kill 3-4-3-8 - X1800 gto @ 789/769 MHz - Catalyst 6.5 beta
Hab den Mark 06 auch mal laufen lassen. :d
Der FX @ 3.0 Ghz - Die Mushkin @ 250 Mhz - Die zwei GTX @ 1820 Mhz
Hier das Ergebnis :3 D Mark 06.png
ATI PS3.0 DUalcore + non-Crossfire
peld - 4553 - Intel Core Duo T2500 @ 2188 MHz - 2x 1 GB MDT 364 MHz CL4-4-3-8 - Sapphire X1800XT 512 MB + Catalyst 6.5
Graka ist auf Standarttakt! CPU-Takt lässt sich leider Gottes nicht weiter erhöhen, da das Asus N4L-VM DH keine Option für die Vcore im BIOS hat...
Dual Core / Non-Crossfire 1280x1024
Staucher - 7113 - Core Duo @ 3080MHZ - 2x1GB Kingston PC2-900 4-4-4-8 - X1900XTX @ 750/850MHz - Omega 3.8.231
Platz 3 :angel:
denke singel core :) und SLI
Maleboglia - 964 - AMD Athlon 64 3000 @ 1815MHz - 2x 512MB MDT @ 400MHz und 2x 512MB CORSAIR @ 400MHz - Sapphire RADEON X700 PRO Core425.3/ Mem 432MHz - Catalyst 6.5
Kleine Frage wo bekomme ich die Detailierten Info´s über die Rambausteine her :eek:
gruß Male :teufel:
Juhuuuuu, Ziel endlich erreicht :banana:
TM30 - 10021 - Opteron 165 @ 2950Mhz - 2x256MB TCCD 268Mhz 2,5-3-3-7 1T - 7900GTX SLI @685/1780Mhz - Forceware 91.31
nVidia PS 3.0 Singlecore + non-SLI -
Mx-Gt - 4501 - 3500+@stock - 2*512 SuperTalent@ 200mhz@ 2-3-2-5 - 7800gt @ 515/1110 - ForceWare 84.24 Beta
eigentlich hätt ich auch mal mit oc'ed cpu gebencht nur keinen screen gemacht :wall:
nVidia PS 3.0 Singelcore + SLI
maddog256 - 6522 - Athlon 64 3700+ @ 2698 Mhz - 2x 1GB OCZ DDR-500 3-4-3-7 - 7800GTX SLI @ 486/1336 - Forceware 84.26
Matthias1981 - 8709 - AMD X2 4400+ @ 2,7Ghz - 2x1GB Samsung @ 230 @ 3-4-4-10 - 7950GX2 @ 570/1500 - Forceware 91.31
Oder zählt meine Graka nun zu non SLI??
hab heute bissl an meiner graka rumgeclockt...
aber ich bekomm die scheiss comparison links immer nicht :hmm: :wall:
Max0505 - 3607 - AMD Opteron 144 @ 2,5GHz - 2x1GB UCCC @ 250MHz 3-4-4-8 - XFX 7800GT @ stock - Forceware 81.98
Max0505 - 3878 - AMD Opteron 144 @ 2,5GHz - 2x1GB UCCC @ 250MHz 3-4-4-8 - XFX 7800GT @ 489/1220 - Forceware 81.98
KHSJ10 - 5439 - AMD A64 3700+ @ 3,1Ghz - 2x512MB Corsair PC3500C2 "Old BH-5" @ 258MHz @ 2-2-2-5 - XFX GeForce 7800 GTX XXX Edition @ 625/900 - ForceWare 91.31
NoiseKiLLeR - 5124 - AMD Venice E6 3500+ @ 2.8 Ghz - 2x 512MB @ 256Mhz 3-3-3-8 - Gigabyte 7900GT @ 650 / 800 - Forceware 91.31
Dualcore non SLI
VR6freunde - 6900- AMD Atlhon X2 3800+ @ 2.8 Ghz - 2x 1024MB @ 280Mhz 3-3-3-8 - Asus 7900GTX Extrem Forceware 91.31
