4 way HDD switcher
arg-ist
I know most of my friends are using 3-4 HDD s as storage. Working all of them creates problems;
Life of the HDDs ,heat problems and noise…
At a Project ı wanted to use an HDD switcher for 4 HDD s. but ı could find only for 2 HDD s.
I made an HDD switcher for 4 HDDs.
A box with 3mm plexi
Holes for switches and leds on the front cover and holes for molex at back with lazer cut. Letters laser engraving.
All wirings on a little pertinax
Before closing
Added 4 leds and 4 sleeved sata power cable.
Finished..
I can select 1. HDD
Or ONE OF 2nd -3 rd or 4 th HDD ..
I can make combinations.
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/community/f143/playdoh-silverstone-tj-07-acrylic-pipe-1012476.html
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-900-d-case-p1-1002736.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
