[Sammelthread] Abit NF-M2 nView (nForce 430 MCP) [1]
Keinen Support mehr was Bios oder Software angeht von Abit fürs Board da Discontinued!​
*Hoffe dieser Thread entspricht denn Regeln ein Ordentlicher Sammelthread zu sein*
Abit NF-M2 nView​
Inhalt:​
1.)Specification
2.)Unterstützte CPUs
3.)BIOS (OC-Einstellungen)
4.)"Besonderheiten/Problemlösung"
5.)Memory Compatibility
6.)Links&Downloads
**SammelThread**
Ein Paar Impressionen zum Board von MFloX
1.)
Specification :
CPU
* Designed for AMD® Socket AM2 Processors with 2000M T/s system bus using Hyper Transport Technology
* AMD® Cool 'n' Quiet Technology
Chipset
* NVIDIA® 6150/NF430 Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual Channel DDR2 800 un-buffered ECC / Non-ECC memory
Graphics
* Integrated GeForce®6150 Graphics
* Support DirectX 9.0, Shader Model 3.0, nView™
LAN
* NVIDIA Gigabit Ethernet
Audio
* On board 7.1 CH HD Audio CODEC
* Auto Jack Sensing and optical S/P DIF In/Out
Expansion Slots
* 1 x PCI-E X16, 1 x PCI-E X1, 2 x PCI
Internal I/O
* 1 x Floppy Port supports up to 2.88M B
* 2 x Ultra DMA 133/100/66/33 IDE Connector
* 2 x USB2.0 header (support 4 ports)
* 4 x SATA 3Gb/s connector
* 1 x IEEE1394 header
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 7.1 CH HD Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
* 4 x USB2.0, 1 x RJ-45 LAN Connector, 1 x 1394
* 1 x DVI, 1 x D-Sub, 1 x S/P DIF In, 1 x S/P DIF Out
Serial ATA
* 4 x SATA (RAID) 3G b/s
* Supports SATA RAID 0/1/0+1/5
Form Factor
* mATX form factor 245 x 245m m
* PCB Color: Blue
RoHS
* 100% lead-free process and RoHS compliant
abit Engineered
* abit SoftMenu™ Technology
* abit Silent OTES™ Technology (Patent No. M273189)
2.)
Unterstützte CPUs​
Wird der Phenom unterstützt?
Abit is working on BIOS updates at this point. I did ask for one for the NF-M2, no answer from Taiwan yet
3.)
BIOS (OC-Einstellungen):
- Vcore: 1,20V - 2,00V !! (per RMClock auch undervolten möglich --> 0,55V bis 1,25V)
- CPU-Multi in 0,5 Schritten: 4 - 11 (X2 4200+ EE)
- DDR-Voltage: 1,75V bis 2,5V !!
- DDR Reference Voltage: -2% / + 2% / -4% / + 0,0%
- Chipset Core (NB) Voltage: 1,20V - 1,60V
- SB Core AUX Voltage: 1,5V - 1,74V
- Hyper Transport Voltage: 1,2V - 1,4V
- Referenztakt (HT-FSB): 200 - 400 MHz
- K8 <-> NB HT Speed: Multi von 1 - 5
- NB <-> SB HT Speed: Multi von 1 - 5
- PCIE Clock: 100 - 145 MHz
- DDR Clock: 400 / 533 / 667 / 800 MHz
- RAM-Timings: alles wichtige inkl. CR 1T/2T
4.)
"Besonderheiten/Problemlösung" :
Vcore Schwankung:
Das Board Übervolted ein wenig so das man statt 1,35V im Bios 1,30V Einstellen muß um 1,325V-1,350V zu bekommen.
Wird NCQ Unterstützt :
Ja wird Unterstützt und ist Ein und Abschaltbar .Man benötigt die nVidia eigenen Treiber (nForce SATA/IDE-Treiber)
Werden die EE CPUs Unterstützt :
Ja alle EEs werden Ordnungs gemäß vom Bios erkannt.
Lösung für die CPU Lüftersteuerung wenn ein 3Pin Lüfter vorhanden ist :
Der 4pin CPU-Lüfteranschluss kann nur mit 4pin Lüfter korrekt umgehen bzw. diese Regeln. Deshalb muss man den CPU-Lüfter an den 3pin "System"-Lüfteranschluss anschließen und im BIOS (oder unter Windows mit dem Tool von Abit) unter "PC Health Status" bei "Reference Temp" von SYSTEM auf CPU wechseln, dann erkennt das Board auch korrekt, dass es sich nun um den CPU-Lüfter und nicht um einen System-Lüfter handelt. Dann noch die Zieltemperaturen (z.B. 42°C), die Toleranz (z.B. 5°C) und Start- und Stop-Kontrolle (z.B. 60%/40%) nach belieben festlegen. Nun sollte der Lüfter spätesten wenn Windows geladen ist deutlich herunterregeln.
Einschalt Problem:
Bei einigen Amis wollte das Board nicht Starten nachdem Einschalten.Hierzu Rät Abit Grundsätzlich vor dem Einschalten einen CMOS Reset durchzuführen.
Der CMOS-Reset Jumper kann locker sitzen, so dass der Jumper nicht richtig sitzt und keinen Kontakt zu den Füßchen hat.Ein Austausch wäre hier zu bevorzugen.
PC Bootet nicht:
Da bei vielen Probleme waren in bezug auf : Kein Booten nach dem Bios verlassen.
Soll heißen man kommt in Bios kann auch alles Einstellen doch nachdem verlassen des Bios Bootet das Sys dennoch nicht.
Einfach die Ram Spannung mal von Auto bzw Standard auf 1,9V - 1,95V stellen.
Da grade der Ram viele Probleme macht auch wenn er für 1,8V betrieb vorgesehen ist.
5.)
Memory Compatibility :
Ram User Tests
ROT = Schlecht Grün = Alles OK
Mit dem original BIOS 9/1/06, mag das Board nicht jeden Ram.
OCZ 2x512Meg 240-Pin DDR2 OCZ2P6671GK möchte manchmal nich Windows Booten oder es gibt auch kein Post von sich
-Corsair XMS2-8500 DDR2 1066 C5 einwandfrei.
-Crucial Ballistix 1GB (2 x 512MB) DDR2 667 (PC2 5300) einwandfrei.
-GEIL 2GB Kit PC2-6400U CL4-4-4-12 (DDR2-800) (GX22GB6400UDC) einwandfrei.
-Corsair XMS2 1GB Kit PC2-5400U CL4-4-4-12 (DDR2-675) (TWIN2X1024-5400C4) einwandfrei.
-TwinMos Twister 2x256MB CL4 einwandfrei.
-Aeneon, DDR2 667 CL5 (AET760UD00-30DA98Z) einwandfrei.
-MDT 2x512MB DDR2 667 CL4 einwandfrei.
-Cellshock DIMM Kit 2048MB PC2-6400U CL4-4-4-12 einwandfrei
-G.Skill F2-6400CL5D-2GBNQ DDR2 800er CL5-5-5-15 einwandfrei
4x 1GB Crucial Value DDR2-533 CL4 mit Micron D9GMH einwandfrei
6.)
Links&Downloads :
Hersteller Link :
Klick mich bin ein Link
Bios :
BIOS ID:11 Klick mich bin ein Link
BIOS ID: 12 Klick mich bin ein Link
1. Fixing RAID Hard Disk Boot Priority function issue
2. Fixing ABITEQ,Beep when S3 Resume issue
3. Fixing BIOS,CPU Warning Temperature issue
4. Fixing BIOS,PC Health not match Design Guide issue
5. Fixing "POST screen broken after ACPI,S1 Wake Up when USB Mouse was inserted" issue
6. Fixing BIOS,USB Keyboard Support-BIOS Function issue
7. Fixing BIOS "Restore On AC Power Loss" / "Last State Function" fail issue
8. Fixing BIOS,String abnormal when use DOMEX DMX3194 SCSICard
9. Fixing dPCIe,ARECA ARC1210 no boot ROM Abnormal On PCIEXP
10. Moving IRQ7 option
11. Moving Current DRAM Status "MHz" string.
12. Fixing USB KB Support-BIOS function fail on RAID ROM
13. Fixing BIOS,1394 disabled function fail issue
14. Fixing BIOS,Boot priority USB-ZIP string
15. Fixing BIOS User define FID change to default when S3 resume.
16. Update Agesa 2.06.11 version support Rev G cpu.
BiosID: 13 Klick mich bin ein Link
1. Fixing WHQL,DTM pre-test failed for Windows Vista Logo.
2. Update code to AMD AGESA Version 2.08.00.
Bios ID: 14 Klick mich bin ein Link
Beta bios 14 b01
1. Fixing BIOS, the SATA string & date.
2. Fixing BIOS, the "HyperTransport" string.
3. Fixing BIOS, can't adjust 1/2 multiplier for AMD Rev F CPU.
4. Update code to AMD AGESA Version 2.08.03
Bios ID: 15 Klick mich bin ein Link
1. Support Sempron LE series CPU.
2. BIOS compiled date: 09/03/2007.
Bios ID: 16 Klick mich bin ein Link
  1. Update CPU Micro code to support Athlon 4X50 series and Sempron X2 CPU.
  2. BIOS compiled date: 07/14/2008.
Treiber :
FTP von Abit :
Deutsches Handbuch als PDF :
Deutsches Faq auf der Abit Seite :
Review :
Bilder vom Board :
Mod-Bios Sammlung :
Verbrauchs Werte Beispiel von che new :
Erste Benches von che new und Eindruck :
AM2 Threads :
AM2 X2 OC Thread von Mondrial :
OC Thread von checkpot :
AM2 Sammelthread von [TLR]Snoopy :
Übersicht aktueller AM2 Mainboards von FischOderAal :
Board bei Geizhals :
che new : für seinen Test und ersten Eindrücken vom Board.
So das wars erstmal alles weitere was fehlen sollte wird Hinzugefügt.Da mein Board+CPU noch nicht da sind kann ich auch noch nichts dazu sagen.
Doch oben im Review wurde sich sehr Positive geäußert über das Board.
Olli
Hast du mal deinen Verbrauch gemessen? Habe ähnliche Konfig und iwie is mir das im IDLE für nen HTPC viel zu viel :/
Nutzt du die onboardgraka oder ne dedizierte? Bei 1080p mkvs stößt das System bei mir an seine Grenzen (klar, ich könnte auf 3 GHZ hochtakten lassen, aber der Strom und die Hitze :fresse:), 720p funktionieren hingegen einwandfrei.
Also meiner braucht etwa 55-60W im Idle mit zusätzlicher XFX HD5450 Graka. Mit undervolting sinds knapp 50W gewesen... aber leider nicht stabil :(
Mit der onboard Graka war bei mir keine ruckelfreie 1080p Wiedergabe möglich. Jetzt mit der HD5450 und DXVA hab ich ne CPU Last von < 10 % beim 1080p gucken :d
Also ganz so schlimm ist es bei mir nicht. Ich habe einen 5050e, welcher per RMClock konstant auf 2,6 Ghz (standard) mit 1,0V läuft. Bin damit soweit zufrieden, aber mein System braucht nicht dauerhaft mit 2,6 GHz arbeiten, wenn ich dann per RMClock runtertakten und entsprechend die Spannung anpassen möchte, geht das nach nur wenigen Minuten in die Hose.
Da ich den HTPC nur für Multimedia benutze, würde mir eigentlich die Onboard-Graka ausreichen, aber bei mir hat sie eine Macke. Vielleicht kennt ihr das Problem. Bei Wiedergabe von allen Videos, egal welcher Auflösung, zusammen mit der hohen LCD-TV Auflösung, schmiert der HTPC nach unregelmäßiger Zeit mit einem Bluescreen (nv Treiber) ab. Ich habe den geringen RAM dafür verantwortlich gemacht und mir eine 9500 GT geholt. Die verbraucht auch nur 5W mehr als die Onboard-Lösung.
Mit der jetzigen Konfiguration schaffe ich es im Idle auf 70W. Bei Wiedergabe von 1080p nicht über 80W. Mit SSD könnte ich das ganze nochmal senken.
Ich finde die Werte ganz ordentlich, aber das ist wohl nix gegen die kommenden Sandy Bridge Zwei-Kerner.
EDIT:
Ich habe gerade nochmal mit RMClock getestet und was interessantes festgestellt. Ich habe habe dem ersten P-State, also Multi 5 0,8V zugewiesen. Läuft soweit stabil auf 1GHz. Leider ist die Veränderung zu 1,0V im Bereich von 1-2W. Natürlich könnte der Unterschied bei Belastung größer ausfallen, aber das will ja keiner... bei gewisser Belastung soll er ja hochtakten. Also bei mir ist auch TV bei 1Ghz leicht ruckelig, kommt also nicht in Frage. Und unter 1,0V bei 2,6 GHz bekomme ich die Kiste nicht wirklich stabil. Somit scheint die CPU stromspartechnisch auf diesem Board ausgereizt.
Also hab bei meinen eben nochmal mit dem Messgerät nachgeprüft.
Konfig:
nf-m2 nview
X2 3800+ @ stock CnQ (1,12V - 1,254V)
XFX HD5450
Samsung F4 EcoGreen 2TB
2 * 1GB DDR2 667 Ram
Realtek 54Mbit PCI WLAN Karte
Idle: ~51W
1080p H.264/VC1: ~60W
DivX: ~61W
Damit kann ich eigentlich leben :)
Aber etwas undervolting wäre trotzdem nicht schlecht...
@woelki: wundert mich, dass deiner im Idle schon fast 20W mehr verbraucht...
Das wundert mich allerdings auch.
Vor allem sollte meine CPU etwas weniger verbrauchen.
nf-m2 nview
Athlon x2 5050e (im Moment auch @ stock mit CnQ)
9500 GT Passiv
Samsung F4 EcoGreen 1TB
2*1GB Ram Crucial BallistiX DDR2 533
Das ist mir irgendwie ein Rätsel.
Sonstige Komponenten sind ein VFD LCD und ein LG DVD Laufwerk.
NT ist noch das Standard vom Antec Fusion, also ein Antec 380 Watt. So unglaublich schlecht kann das ja nicht bei der Effizienz sein.
Die Graka kann es auch nicht wirklich sein, da sie kaum mehr verbraucht als die Onboard Lösung.
Hast du sonst irgendwelche Werte im Bios gesenkt?
Hmm merkwürdig. Also ich hab kein optisches Laufwerk drin, aber das sollte wohl kaum bis nix ausmachen. Als NT hab ich ein 120W Ding oder so welches bei meinem HTPC Gehäuse dabei war. Das wird auch nicht das beste sein...
Deine 9500GT braucht wohl im Idle knapp 6W mehr als ne HD5450:
Test: Sapphire Radeon HD 5450 (Seite 15) - 04.02.2010 - ComputerBase
Dann sinds aber immer noch 13W mehr. Welches OS nutzt du? Ich hab Win7 x64 drauf.
Beim booten kommt meiner auch auf 80W. Aber in Windows wirds dann schnell weniger.
Im Bios hab ich eigentlich nix weiter eingestellt. Nur Onboard Sound/LAN/Grafk deaktiviert. Aber glaube das ändert nix am Verbrauch.
Win 7 32 Bit
Naja vielleicht alles in der Summe. Meiner geht beim Boot aber auch mal über 100 Watt. Ich muss mich damit heute nochmal auseinandersetzen.
Ansonsten werde ich mal schauen, dass ich ein neueres AM2+ Board schiesse, welches meinen 5050e anständig unterstützt.
Was hältst du von dem GIGABYTE GA-MA78LM-S2H?
Scheint ganz gut zu sein... ich bin auch schon am überlegen ob ich mir nen anderes gebrauchtes Board holen soll. Dieses Undervolting Problem nervt mich...
Gibt ja einige microATX Boards mit AMD 7XX Chipsatz. Leider nur bis maximal HD4200 integrierter Grafik. Damit funzt glaube ich noch kein Dolby TrueHD bzw. DTS-MA Bitstreaming :(
