[Sammelthread] Aktuelle Nvidia Forceware Treiber (Vista) und Probleme *Sammelthread*Update 19.09.07
Aeolus
Semiprofi
Nvidia Forceware und Probleme Stand 19.09.2007
Hier in dem **Sammelthread** wird über Nvidias ForceWare und dazugehörige Probleme diskutiert!
Aktuelle Forceware Treiber: Geforce 6,7,8
Achtung *beta* Forceware
Forceware Vista 101.41 (x64/x86)
http://www.forumdeluxx.de/forum/show...&postcount=135
Forceware Vista 101.70 (32-bit)
http://www.station-drivers.com/page/nvidia forceware.htm
Forceware Vista 101.70 (64-bit)
Forceware Vista 158.24 (64bit)
http://www.nvidia.com/object/winvista_x64_158.24.html
ForceWare Vista 158.24 (32bit)
http://www.nvidia.com/object/winvista_x86_158.24.html
ForceWare Vista 158.42 (32bit)
http://de.download.nvidia.com/Window...ernational.exe
ForceWare Vista 158.42 (64bit)
ForceWare Vista 158.43 (32bit)
http://www.nvidia.com/object/winvista_x86_158.43.html
ForceWare Vista 158.43 (64bit)
http://www.nvidia.com/object/winvista_x64_158.43.html
ForceWare Vista 163.11 (32bit)
http://www.nvidia.com/object/winvista_x86_163.11.html
ForceWare Vista 163.11 (64bit)
http://www.nvidia.com/object/winvista_x64_163.11.html
ForceWare Vista 163.16 (32bit)
http://www.electronicpunk.com/forceware/163.16_WinVista_32bit_english_beta.zip
ForceWare Vista 163.16 (64bit)
http://www.electronicpunk.com/forceware/163.16_WinVista_64bit_english_beta.zip
ForceWare Vista 163.44 (32bit)
http://www.nvidia.com/object/winvista_x86_163.44.html
ForceWare Vista 163.44 (64bit)
http://www.nvidia.com/object/winvista_x64_163.44.html
ForceWare Vista 163.67 (32bit)
http://www.nvidia.com/object/winvista_x86_163.67.html
ForceWare Vista 163.67 (64bit)
http://www.nvidia.com/object/winvista_x64_163.67.html
WHQL Forceware
Forceware Vista 100.65 (32-bit)
http://www.nvidia.com/object/winvista_x86_100.65.html
Forceware Vista 100.65 (64-bit)
http://www.nvidia.com/object/winvista_x64_100.65.html
Forceware Vista 158.16 (64bit)
Forceware Vista 158.16 (32bit)
Forceware Vista 158.18 (64bit)
http://www.nvidia.de/object/winvista_x64_158.18_de.html
ForceWare Vista 158.18 (32bit)
http://www.nvidia.de/object/winvista_x86_158.18_de.html
ForceWare Vista 160.04 (32bit)
http://downloads.guru3d.com/download.php?det=1660
ForceWare Vista 160.04 (64bit)
http://downloads.guru3d.com/download.php?det=1659
ForceWare Vista 162.18 (32bit)
ForceWare Vista 162.18 64bit)
ForceWare Vista 162.22 (32bit)
http://www.nvidia.com/object/winvista_x86_162.22.html
ForceWare Vista 162.22 (64bit)
http://www.nvidia.com/object/winvista_x64_162.22.html
ForceWare Vista 162.50 (32bit)
http://www.nvidia.com/object/winvista_x86_162.50.html
ForceWare Vista 162.50 (64bit)
http://www.nvidia.com/object/winvista_x64_162.50.html
http://www.station-drivers.com/tele....11-whql-vista32(www.station-drivers.com).exe
http://www.station-drivers.com/tele....11-whql-vista64(www.station-drivers.com).exe
ForceWare Vista 163.69 (32bit)
http://www.nvidia.de/object/winvista_x86_163.69_de.html
ForceWare Vista 163.69 (64bit)
http://www.nvidia.de/object/winvista_x64_163.69_de.html
Aktuelle NTune Version
http://www.nvidia.de/object/ntune_5.05.38.00_de.html
Was ist Ntune?
Das NVIDIA® nTune ist das ultimative nForce-Utility zum Überwachen kritischer Systemwerte wie Temperatur oder Betriebsspannungen. Zudem lassen sich vielfältige Systemparameter über leicht verständliche Bedienfelder komfortabel anpassen. So können Sie beispielsweise Ihr System für optimale Performance übertakten – oder genauso gut auch untertakten, um dank der niedrigeren Temperaturen die Lüftergeräusche zu reduzieren. Alle Änderungen lassen sich dabei über eine Microsoft® Windows®-Oberfläche im laufenden Betrieb vornehmen, und zwar ganz ohne mühsame BIOS-Arbeit!
Aktuelle Forceware Treiber: Geforce GO 2/4/5/6/7 (mobile)
Forceware Vista 97.59 Beta (32bit)
http://www.station-drivers.com/page/nvidia geforce go.htm
Forceware Vista 97.59 Beta (64bit)
Forceware Vista 100.85 (64bit)
http://www.laptopvideo2go.com/forum/...howtopic=14126
Forceware Vista 101.38 (32bit)
Forceware Vista 100.85 (64bit/32bit)
Forceware Vista 156.07 (64bit/32bit)
Forceware Vista 156.13 (32bit)
WHQL Forceware
Forceware Vista 97.59 WHQL (64bit/32bit)
Forceware Vista 98.08 WHQL (32bit)
Forceware Vista 156.10 WHQL (32bit)
http://www.laptopvideo2go.com/forum/index.php?showtopic=14680
Forceware Vista 156.10 WHQL (64bit)
http://www.laptopvideo2go.com/forum/index.php?showtopic=14681&pid=55142&st=0&#entry55142
Forceware Vista 156.55 WHQL (32bit)
http://www.laptopvideo2go.com/forum/index.php?showtopic=14837
Forceware Vista 156.55 WHQL (64bit)
http://www.laptopvideo2go.com/forum/index.php?showtopic=14836
°MOD Treiber für Notebooks z.B. bekommt Ihr hier
°Wie mache ich das mit der Mod INF von der laptopvideo Homepage?
1. Ich lade mir den gewünschten Forcewaretreiber runter.
2. Ich lade mir die dazugehörige MOD INF runter (direkt neben den Dowloadlink)
3. Ich entpacke den runtergeladenen Forcewaretreiber in einen von mir erstellten Ordner.
4. Ich kopiere die MOD INF in den von mir erstellten Ordner, in der sich der entpackte
Forcewaretreiber befindet! Bestätige nur noch das überschreiben der vorhandenen Inf - fertig.
5. Nun den Treiber Installieren und Spaß haben :)
°Nvidia empfiehlt diesen Microsoft Windows Vista Hotfix!
http://www.nvidia.de/object/windows_vista_hotfixes_de.html
°Wichtig, bei De/ -Installationsproblemen:
1) Deinstallieren der Nvidia Treiber im ABGESICHERTEN Modus
2) Reboot
3) Falls Grafikkarte vom Hardwaremanager gefunden wird diesen abbrechen wenn möglich und/oder zumindest nicht neustarten
4) Gewünschten Treiber installieren
5) Reboot
Danke an KOKOtm
Symptome:
Der Bildschirm wird während dem deinstallieren schwarz und nach ner Weile fängt das Mainboard zu piepsen an. Rechner reagiert nicht mehr.
Fehlerbeseitung ab Forceware 16x.xx
- "4xAF" Bug bei einigen Spielen beseitigt.
- Höhere Performance bei 3D Mark06
erstmal danke, kurze frage, ist der tv out bug behoben? *hoffe*
^^ der hat mich total angekotzt :( ^^
selber testen kann ich erst morgen, heute keine zeit/lust :d zu müde
ich verzweifle bald... auch mit diesem nvidia treiber kann ich einfach nicht di eauflösung einstellen die ich gerne hätte und die ich schon immer einstelle ! die möglichkeit der auswahl an auflösungen ist dermaßen von beschränkt auf eine handvoll (7900GT) und hört bei der auswahl sogar bei 1600x1200 auf ! ist das absicht von vista diese bevormundung ?
Lüppt perfekt bei 1680x1050 (7950GX2 und Ultimate 64bit)
^^ dito, hab auch 1680x1050 auf ultimate 64...
also folgendes, hab gerade den ForceWare 100.64 installiert, leider hatte ich bei den setup derbe probs, black screen und rum gepipse die ganze zeit, musste ein hardreset machen... nach dem hochfahren erst mal gefreut der ForceWare 100.64 wurde richtig installiert und jetzt kommts :d
DER TV OUT BUG IST NICHT MEHR VORHANDEN!!! "ENDLICH"
Hey das ist ja eine gute Nachricht am frühen Morgen ^^. Da kann ich ja noch Hoffnung haben das damit Gothic 3 und Scarface gescheit laufen. Mal schauen heute Nachmittag wird getestet...
Danke für die news DjFlussmittel :d
Der Vollbildmodus geht immer noch nicht, zumindest finde ich den Menüpunkt nicht. Ich habe meinen TV über den 2. DVI angschlossen (7900GTO)
Muss ich irgendetwas einstellen dass mir alle Menüpunkte angezeigt werden?
Weis einer Rat?
DirectX 9 and OpenGL NVIDIA SLI support for GeForce 6 and 7 series GPUs and DirectX 10 NVIDIA SLI support for GeForce 8800 GPUs will be available in a future driver
immer noch warten bis meine karte richtig geht... :(
Laut anderen Leuten geht TV out immer noch nicht, geschweige denn SLI.
Habe erfahren das SLI frühestens im März kommen soll für 6/7 reihe.
Finde das nvidia sich langsam lächerlich macht, sorry.
Stimmt, TV-Out geht immer noch nicht. Bekomm' einfach kein Bild auf den Fernseher. Zum K****** ist das...
öhm also das kann ich nicht bestätigen meiner seits, hab wie oben schon besprochen keinerlei probs mehr mit dem tv out :d
ich muss dazu sagen ich hatte nur das problem das ich alles schwarz/weiss gesehen hab, sonst ging ja alles...
Bei mir ist der TV-Out Bug auch nach wie vor da...im abgesicherten Modus funktioniert's komischerweise...
klasse das gothic 3 jetzt läuft, ich muss es bei mir nachher auch mal testen, denke aber (bzw. hoffe) das es bei mir nun auch geht ^^ :d
übrigens, ich hab ne 8800 gts auf vista 64 und benutzt ein s-video kabel zum tv... weil ja oben geschrieben worden ist das der bug mit nem dvi kabel noch vorhanden sein, evlt liegts daran das es bei mir geht...
bei mir geht es auch mit tv out über s-video kabel. über dvi kann ich nicht testen weil der fernseher zu weit weg steht...
Funktioniert das Flatpanel-Scaling in dieser Treiberversion?
So habe nun den neuen Treiber installiert.
Danach sofort Gothic 3 angetestet, doch Schock, immer noch Grafikfehler ohne Ende.
Dann habe ich im Treiber Menü folgendes geändert:
Antialiasing Mode : auf Application controlled gestellt
Multi-Display/mixed GPU acceleration: auf single display performance gestellt
Dann wieder Gothic 3 gestartet, und siehe da, es läuft ! :banana:
Endlich :bigok:
Scarface läuft übrigens immer noch nur mit Grafik-Fehlern- also unspielbar im mom. bei mir...
Also ich hab schon nen Bild aufm TV aber eben nur das Desktop Hintergrundbild. (Dual View)
Ich brauch die option "Vollbildmodus" um das Video am TV sehen zu können wenn ich es am TFT starte.
Beim alten CP war alles besser. :(
Pfui nVidia
@Elmar: Irgendwas mußt du falsch machen...
Ich habe 1920x1200 eingestellt, das funktionierte problemlos mit den 97.46 oder den 100.54 Treibern. Vielleicht liegt es einfach an deinem CRT oder TFT, mal nen passenden Treiber installiert ?
Frage @all:
Warum sind die 100.59 Treiber denn ca 20mb kleiner als die 100.54?
Immer wenn die Treiber so klein sind habe ich kein gutes Gefühl dabei, irgendwas müssen die doch weggelassen haben.
also bei mir läuft gothic 3 immer noch nicht vernünftig. immer wieder grafikfehler :(
Habe mir diese Version auch mal mit ner Mod Inf. auf dem Lappi gezimmert!
läuft bisher ganz gut!
also keine chance mit dem treiber und der auflösung... ich musste jetzt mit powerstrip nachhelfen, aber das ist eigentlich nicht der sinn der sache...
@brethart:
haste mal versucht im treiber die einstellungen zu ändern, so wie ich es oben beschrieben habe? bei meiner 8800 gts hat es geholfen...
ich teste morgen mal wie lange es stable läuft, ich hatte es gestern ca 15 min laufen hab dann aber beendet weil ich keine zeit hatte. Heute schaffe ich es leider auch nicht mehr...
Aber ich habe eine 8800 gts, ob das einen unterschied macht ... :hmm:
der gelbstich beim Windowsbilderviewer ist auch noch da. Scheint wohl an Vista zu liegen.
G P
