I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Die Operation ist nicht erlaubt
D: [pulseaudio] core-rtclock.c: Timer slack is set to 50 us.
D: [pulseaudio] core-util.c: RealtimeKit worked.
I: [pulseaudio] core-util.c: Successfully gained nice level -11.
I: [pulseaudio] main.c: This is PulseAudio 14.2
D: [pulseaudio] main.c: Compilation CFLAGS: Not yet supported on meson
D: [pulseaudio] main.c: Running on host: Linux x86_64 5.11.14-1-MANJARO #1 SMP PREEMPT Wed Apr 14 08:25:29 UTC 2021
D: [pulseaudio] main.c: Found 8 CPUs.
I: [pulseaudio] main.c: Page size is 4096 bytes
D: [pulseaudio] main.c: Compiled with Valgrind support: no
D: [pulseaudio] main.c: Running in valgrind mode: no
D: [pulseaudio] main.c: Running in VM: no
D: [pulseaudio] main.c: Running from build tree: no
D: [pulseaudio] main.c: Optimized build: yes
D: [pulseaudio] main.c: All asserts enabled.
I: [pulseaudio] main.c: Machine ID is 50a18b2cdee64e188d064239533b658d.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/ladmin/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-14.2/modules.
I: [pulseaudio] main.c: Running in system mode: no
I: [pulseaudio] main.c: System supports high resolution timers
D: [pulseaudio] memblock.c: Using shared memfd memory pool with 1024 slots of size 64,0 KiB each, total size is 64,0 MiB, maximum usable slot size is 65472
I: [pulseaudio] cpu-x86.c: CPU flags: CMOV MMX SSE SSE2 SSE3 SSSE3 SSE4_1 SSE4_2
I: [pulseaudio] svolume_mmx.c: Initialising MMX optimized volume functions.
I: [pulseaudio] remap_mmx.c: Initialising MMX optimized remappers.
I: [pulseaudio] svolume_sse.c: Initialising SSE2 optimized volume functions.
I: [pulseaudio] remap_sse.c: Initialising SSE2 optimized remappers.
I: [pulseaudio] sconv_sse.c: Initialising SSE2 optimized conversions.
I: [pulseaudio] svolume_orc.c: Initialising ORC optimized volume functions.
D: [pulseaudio] database-tdb.c: Opened TDB database '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-device-volumes.tdb'
I: [pulseaudio] database.c: Successfully opened 'device-volumes' database file '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-device-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-device-restore" (index: #0; argument: "").
D: [pulseaudio] database-tdb.c: Opened TDB database '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-stream-volumes.tdb'
I: [pulseaudio] database.c: Successfully opened 'stream-volumes' database file '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-stream-volumes.tdb'.
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1 added for object /org/pulseaudio/stream_restore1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry3
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry4
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry5
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry6
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry7
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry8
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry9
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry10
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry11
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry12
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry13
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry14
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry15
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry16
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry17
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry18
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry19
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry20
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry21
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry22
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry23
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry24
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry25
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry26
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry27
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry28
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry29
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry30
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry31
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry32
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry33
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry34
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry35
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry36
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry37
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry38
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry39
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry40
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry41
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry42
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry43
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry44
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry45
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry46
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry47
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry48
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry49
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry50
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry51
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry52
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry53
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry54
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry55
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry56
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry57
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry58
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry59
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry60
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry61
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry62
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry63
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry64
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry65
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry66
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry67
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry68
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry69
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry70
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry71
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry72
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry73
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry74
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry75
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry76
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry77
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry78
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry79
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry80
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry81
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry82
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry83
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry84
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry85
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry86
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry87
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry88
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry89
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry90
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry91
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry92
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry93
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry94
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry95
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry96
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry97
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry98
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry99
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry100
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry101
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry102
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry103
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry104
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry105
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry106
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry107
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry108
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry109
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry110
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry111
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry112
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry113
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry114
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry115
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry116
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry117
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry118
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry119
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Ext.StreamRestore1.RestoreEntry added for object /org/pulseaudio/stream_restore1/entry120
I: [pulseaudio] module.c: Loaded "module-stream-restore" (index: #1; argument: "restore_device=false").
D: [pulseaudio] database-tdb.c: Opened TDB database '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-card-database.tdb'
I: [pulseaudio] database.c: Successfully opened 'card-database' database file '/home/ladmin/.config/pulse/50a18b2cdee64e188d064239533b658d-card-database.tdb'.
I: [pulseaudio] module.c: Loaded "module-card-restore" (index: #2; argument: "").
I: [pulseaudio] module.c: Loaded "module-augment-properties" (index: #3; argument: "").
I: [pulseaudio] module.c: Loaded "module-switch-on-port-available" (index: #4; argument: "").
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-udev-detect.so': success
D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC1 is accessible: yes
D: [pulseaudio] module-udev-detect.c: /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2.3/3-1.2.3:1.0/sound/card1 is busy: no
D: [pulseaudio] module-udev-detect.c: Loading module-alsa-card with arguments 'device_id="1" name="usb-0d8c_USB_Sound_Device-00" card_name="alsa_card.usb-0d8c_USB_Sound_Device-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=no use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"'
D: [pulseaudio] dbus-util.c: Successfully connected to D-Bus session bus b112fa858a0194a45c64bf2460806b2a as :1.14
D: [pulseaudio] reserve-wrap.c: Successfully acquired reservation lock on device 'Audio1'
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:1 use case configuration -2
I: [pulseaudio] (alsa-lib)main.c: error: failed to import ICUSBAUDIO7D use case configuration -2
I: [pulseaudio] alsa-ucm.c: UCM not available for card ICUSBAUDIO7D
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf'
D: [pulseaudio] alsa-mixer.c: Looking at profile input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Checking for recording on Analog Stereo (analog-stereo)
D: [pulseaudio] alsa-util.c: Trying front:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open front:1
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 5461 ms
D: [pulseaudio] alsa-util.c: Set buffer size first (to 4800 samples), period size second (to 1200 samples).
D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf'
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:1'
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-front-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Capture' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Input Source' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Capture Source' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic' succeeded (volume=2, switch=2, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Internal Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Dock Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Dock Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Internal Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line' succeeded (volume=2, switch=2, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Aux' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Video' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic/Line' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'TV Tuner' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'FM' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Inverted Internal Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Jack Mode' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-front-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-rear-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-rear-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-internal-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Internal Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Int Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Int Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-internal-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-dock-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-dock-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic - Input Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM Capture Source' succeeded (volume=0, switch=0, enumeration=1, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Select' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost (+20dB)' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-linein'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line - Input Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-aux'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Aux' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-video'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Video' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-tvtuner'
D: [pulseaudio] alsa-mixer.c: Probe of element 'TV Tuner' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-fm'
D: [pulseaudio] alsa-mixer.c: Probe of element 'FM' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-mic-line'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic/Line' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-headphone-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Auto-Mute Mode' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-headphone-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-headset-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headset Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headset Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-headset-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Available mixer paths (after tidying):
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6bdab30, direction=2
D: [pulseaudio] alsa-mixer.c: Path analog-input-mic (Microphone), direction=2, priority=87, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=6928, min_dB=-16, max_dB=11,06
D: [pulseaudio] alsa-mixer.c: Element 'Mic', direction=2, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'PCM Capture Source', direction=2, switch=0, volume=0, volume_limit=-1, enumeration=1, required=0, required_any=0, required_absent=0, mask=0x0, n_channels=0, override_map=00
D: [pulseaudio] alsa-mixer.c: Option Mic (analog-input-microphone/analog-input-microphone) index=0, priority=0
D: [pulseaudio] alsa-mixer.c: Element 'Line', direction=2, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Jack Mic, alsa_name='Mic Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Mic Phantom, alsa_name='Mic Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Mic - Input, alsa_name='Mic - Input Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Setting analog-input-microphone (analog-input-microphone) priority=0
D: [pulseaudio] alsa-mixer.c: Path analog-input-linein (Line In), direction=2, priority=81, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=6928, min_dB=-16, max_dB=11,06
D: [pulseaudio] alsa-mixer.c: Element 'Line', direction=2, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Option Line (analog-input-linein/analog-input-linein) index=1, priority=0
D: [pulseaudio] alsa-mixer.c: Element 'Mic', direction=2, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Jack Line, alsa_name='Line Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Phantom, alsa_name='Line Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line - Input, alsa_name='Line - Input Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Setting analog-input-linein (analog-input-linein) priority=0
D: [pulseaudio] alsa-mixer.c: Looking at profile input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Checking for recording on Digital Stereo (IEC958) (iec958-stereo)
D: [pulseaudio] alsa-util.c: Trying iec958:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open iec958:1
D: [pulseaudio] alsa-mixer.c: Profile input:iec958-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-input.conf'
D: [pulseaudio] alsa-mixer.c: Probing path 'iec958-stereo-input'
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6cb5590, direction=2
D: [pulseaudio] alsa-mixer.c: Path iec958-stereo-input (Digital Input (S/PDIF)), direction=2, priority=0, probed=yes, supported=yes, has_mute=no, has_volume=no, has_dB=no, min_volume=0, max_volume=0, min_dB=-inf, max_dB=0
D: [pulseaudio] alsa-mixer.c: Option IEC958 In (iec958-input/iec958-input) index=2, priority=0
D: [pulseaudio] alsa-mixer.c: Setting iec958-input (iec958-input) priority=0
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Stereo (analog-stereo)
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf'
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Side' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Center' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'CLFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'External Amplifier' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958 Optical Raw' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Analog Output' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-lineout'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Front Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Front Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out CLFE Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out CLFE Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Surround Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Surround Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Side Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Side Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker+LO' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone+LO' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line HP Swap' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone',1 succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=2, switch=2, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Desktop Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Front' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Surround' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Side' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker CLFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-lineout', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-speaker'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Headphone Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Front Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker - Output Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Center Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Front Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone - Output Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-headphones', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones-2'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack',1 succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Surround Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-headphones-2', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Removing path 'analog-output' as it is a subset of 'analog-output-speaker'.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6cb5770, direction=1
D: [pulseaudio] alsa-mixer.c: Path analog-output-speaker (Speakers), direction=1, priority=100, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=197, min_dB=-36,93, max_dB=0
D: [pulseaudio] alsa-mixer.c: Element 'Speaker', direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0xcee, n_channels=8, override_map=03
D: [pulseaudio] alsa-mixer.c: Jack Headphone, alsa_name='Headphone Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Dock Headphone, alsa_name='Dock Headphone Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Headphone, alsa_name='Front Headphone Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out, alsa_name='Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Front, alsa_name='Line Out Front Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Line Out, alsa_name='Front Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Rear Line Out, alsa_name='Rear Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Dock Line Out, alsa_name='Dock Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker, alsa_name='Speaker Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker Phantom, alsa_name='Speaker Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker Front Phantom, alsa_name='Speaker Front Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker - Output, alsa_name='Speaker - Output Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-21
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 2.1 (analog-surround-21)
D: [pulseaudio] alsa-util.c: Trying surround21:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround21:1
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 1820 ms
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c3aef0, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-21+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-21+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-40
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 4.0 (analog-surround-40)
D: [pulseaudio] alsa-util.c: Trying surround40:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround40:1
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 2730 ms
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c3af30, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-40+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-40+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-41
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 4.1 (analog-surround-41)
D: [pulseaudio] alsa-util.c: Trying surround41:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround41:1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c43950, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-41+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-41+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-50
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 5.0 (analog-surround-50)
D: [pulseaudio] alsa-util.c: Trying surround50:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround50:1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c33440, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-50+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-50+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 5.1 (analog-surround-51)
D: [pulseaudio] alsa-util.c: Trying surround51:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround51:1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6bb5010, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-51+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-51+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-71
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 7.1 (analog-surround-71)
D: [pulseaudio] alsa-util.c: Trying surround71:1 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround71:1
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 1365 ms
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71 supported.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c4a4f0, direction=1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-71+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-71+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (IEC958) (iec958-stereo)
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-output.conf'
D: [pulseaudio] alsa-mixer.c: Probing path 'iec958-stereo-output'
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6c3ab80, direction=1
D: [pulseaudio] alsa-mixer.c: Path iec958-stereo-output (Digital Output (S/PDIF)), direction=1, priority=0, probed=yes, supported=yes, has_mute=no, has_volume=no, has_dB=no, min_volume=0, max_volume=0, min_dB=-inf, max_dB=0
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo+input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:iec958-stereo supported.
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 4.0 (IEC958/AC3) (iec958-ac3-surround-40)
D: [pulseaudio] alsa-util.c: Trying a52:1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:1
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:analog-stereo - will not be able to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (IEC958/AC3) (iec958-ac3-surround-51)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:analog-stereo - will not be able to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (IEC958/DTS) (iec958-dts-surround-51)
D: [pulseaudio] alsa-util.c: Trying dca:1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:analog-stereo - will not be able to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:iec958-stereo - will not be able to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo)
D: [pulseaudio] alsa-util.c: Trying hdmi:1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.0:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)conf.c: function snd_func_refer returned error: Datei oder Verzeichnis nicht gefunden
I: [pulseaudio] (alsa-lib)conf.c: Evaluate error: Datei oder Verzeichnis nicht gefunden
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:analog-stereo - will not be able to open output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:iec958-stereo - will not be able to open output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:analog-stereo - will not be able to open output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:iec958-stereo - will not be able to open output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI) (hdmi-surround71)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71+input:analog-stereo - will not be able to open output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71+input:iec958-stereo - will not be able to open output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI/DTS) (hdmi-dts-surround)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround+input:analog-stereo - will not be able to open output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround+input:iec958-stereo - will not be able to open output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 2) (hdmi-stereo-extra1)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.1:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:analog-stereo - will not be able to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 2) (hdmi-surround-extra1)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:analog-stereo - will not be able to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:iec958-stereo - will not be able to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 2) (hdmi-surround71-extra1)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra1+input:analog-stereo - will not be able to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra1+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 2/DTS) (hdmi-dts-surround-extra1)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra1+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra1+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 3) (hdmi-stereo-extra2)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,2 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.2:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,2: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:analog-stereo - will not be able to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 3) (hdmi-surround-extra2)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:analog-stereo - will not be able to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:iec958-stereo - will not be able to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 3) (hdmi-surround71-extra2)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra2+input:analog-stereo - will not be able to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra2+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 3/DTS) (hdmi-dts-surround-extra2)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,2 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,2: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra2+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra2+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 4) (hdmi-stereo-extra3)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,3 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.3:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,3: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:analog-stereo - will not be able to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 4) (hdmi-surround-extra3)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:analog-stereo - will not be able to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:iec958-stereo - will not be able to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 4) (hdmi-surround71-extra3)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra3+input:analog-stereo - will not be able to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra3+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 4/DTS) (hdmi-dts-surround-extra3)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,3 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,3: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra3+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra3+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 5) (hdmi-stereo-extra4)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,4 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.4:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,4: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra4+input:analog-stereo - will not be able to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra4+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 5) (hdmi-surround-extra4)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra4+input:analog-stereo - will not be able to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra4+input:iec958-stereo - will not be able to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 5) (hdmi-surround71-extra4)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra4+input:analog-stereo - will not be able to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra4+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 5/DTS) (hdmi-dts-surround-extra4)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,4 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,4: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra4+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra4+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 6) (hdmi-stereo-extra5)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,5 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.5:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,5: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra5+input:analog-stereo - will not be able to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra5+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 6) (hdmi-surround-extra5)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra5+input:analog-stereo - will not be able to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra5+input:iec958-stereo - will not be able to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 6) (hdmi-surround71-extra5)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra5+input:analog-stereo - will not be able to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra5+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 6/DTS) (hdmi-dts-surround-extra5)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,5 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,5: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra5+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra5+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 7) (hdmi-stereo-extra6)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,6 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.6:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,6: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra6+input:analog-stereo - will not be able to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra6+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 7) (hdmi-surround-extra6)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra6+input:analog-stereo - will not be able to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra6+input:iec958-stereo - will not be able to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 7) (hdmi-surround71-extra6)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra6+input:analog-stereo - will not be able to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra6+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 7/DTS) (hdmi-dts-surround-extra6)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,6 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,6: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra6+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra6+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 8) (hdmi-stereo-extra7)
D: [pulseaudio] alsa-util.c: Trying hdmi:1,7 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)confmisc.c: Unable to find definition 'cards.USB-Audio.pcm.hdmi.7:CARD=1,AES0=4,AES1=130,AES2=0,AES3=2'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM hdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,7: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra7+input:analog-stereo - will not be able to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra7+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 8) (hdmi-surround-extra7)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra7+input:analog-stereo - will not be able to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra7+input:iec958-stereo - will not be able to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 8) (hdmi-surround71-extra7)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra7+input:analog-stereo - will not be able to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra7+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 8/DTS) (hdmi-dts-surround-extra7)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:1,7 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,7: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra7+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra7+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra7
D: [pulseaudio] flist.c: ../pulseaudio/src/pulsecore/idxset.c: entries flist is full (don't worry)
D: [pulseaudio] alsa-mixer.c: Profile set 0x55ebf6a6bac0, auto_profiles=yes, probed=yes, n_mappings=8, n_profiles=26, n_decibel_fixes=0
D: [pulseaudio] alsa-mixer.c: Mapping analog-stereo (Analog Stereo), priority=65, channel_map=front-left,front-right, supported=yes, direction=0
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-21 (Analog Surround 2.1), priority=13, channel_map=front-left,front-right,lfe, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-40 (Analog Surround 4.0), priority=12, channel_map=front-left,front-right,rear-left,rear-right, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-41 (Analog Surround 4.1), priority=13, channel_map=front-left,front-right,rear-left,rear-right,lfe, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-50 (Analog Surround 5.0), priority=12, channel_map=front-left,front-right,rear-left,rear-right,front-center, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-51 (Analog Surround 5.1), priority=13, channel_map=front-left,front-right,rear-left,rear-right,front-center,lfe, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping analog-surround-71 (Analog Surround 7.1), priority=12, channel_map=front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right, supported=yes, direction=1
D: [pulseaudio] alsa-mixer.c: Mapping iec958-stereo (Digital Stereo (IEC958)), priority=55, channel_map=front-left,front-right, supported=yes, direction=0
D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo (Analog Stereo-Eingabe), input=analog-stereo, output=(null) priority=65, supported=yes n_input_mappings=1, n_output_mappings=0
D: [pulseaudio] alsa-mixer.c: Input analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile input:iec958-stereo (Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=(null) priority=55, supported=yes n_input_mappings=1, n_output_mappings=0
D: [pulseaudio] alsa-mixer.c: Input iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo (Analog Stereo-Ausgabe), input=(null), output=analog-stereo priority=6500, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo (Analog Stereo Duplex), input=analog-stereo, output=analog-stereo priority=6565, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:iec958-stereo (Analog Stereo-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-stereo priority=6555, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21 (Analog Surround 2.1-Ausgabe), input=(null), output=analog-surround-21 priority=1300, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-21
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21+input:analog-stereo (Analog Surround 2.1-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-21 priority=1365, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-21+input:iec958-stereo (Analog Surround 2.1-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-21 priority=1355, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40 (Analog Surround 4.0-Ausgabe), input=(null), output=analog-surround-40 priority=1200, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-40
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40+input:analog-stereo (Analog Surround 4.0-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-40 priority=1265, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-40+input:iec958-stereo (Analog Surround 4.0-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-40 priority=1255, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41 (Analog Surround 4.1-Ausgabe), input=(null), output=analog-surround-41 priority=1300, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-41
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41+input:analog-stereo (Analog Surround 4.1-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-41 priority=1365, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-41+input:iec958-stereo (Analog Surround 4.1-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-41 priority=1355, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50 (Analog Surround 5.0-Ausgabe), input=(null), output=analog-surround-50 priority=1200, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-50
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50+input:analog-stereo (Analog Surround 5.0-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-50 priority=1265, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-50+input:iec958-stereo (Analog Surround 5.0-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-50 priority=1255, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51 (Analog Surround 5.1-Ausgabe), input=(null), output=analog-surround-51 priority=1300, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-51
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51+input:analog-stereo (Analog Surround 5.1-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-51 priority=1365, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-51+input:iec958-stereo (Analog Surround 5.1-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-51 priority=1355, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71 (Analog Surround 7.1-Ausgabe), input=(null), output=analog-surround-71 priority=1200, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-surround-71
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71+input:analog-stereo (Analog Surround 7.1-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=analog-surround-71 priority=1265, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:analog-surround-71+input:iec958-stereo (Analog Surround 7.1-Ausgabe + Digital Stereo (IEC958)-Eingabe), input=iec958-stereo, output=analog-surround-71 priority=1255, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo (Digital Stereo (IEC958)-Ausgabe), input=(null), output=iec958-stereo priority=5500, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output iec958-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:analog-stereo (Digital Stereo (IEC958)-Ausgabe + Analog Stereo-Eingabe), input=analog-stereo, output=iec958-stereo priority=5565, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Profile output:iec958-stereo+input:iec958-stereo (Digital Stereo Duplex (IEC958)), input=iec958-stereo, output=iec958-stereo priority=5555, supported=yes n_input_mappings=1, n_output_mappings=1
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.usb-0d8c_USB_Sound_Device-00.
D: [pulseaudio] module-alsa-card.c: Found 0 jacks.
D: [pulseaudio] card.c: Looking for initial profile for card alsa_card.usb-0d8c_USB_Sound_Device-00
D: [pulseaudio] card.c: input:analog-stereo availability unknown
D: [pulseaudio] card.c: input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-stereo+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-stereo+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-21 availability unknown
D: [pulseaudio] card.c: output:analog-surround-21+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-21+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-40 availability unknown
D: [pulseaudio] card.c: output:analog-surround-40+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-40+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-41 availability unknown
D: [pulseaudio] card.c: output:analog-surround-41+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-41+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-50 availability unknown
D: [pulseaudio] card.c: output:analog-surround-50+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-50+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-51 availability unknown
D: [pulseaudio] card.c: output:analog-surround-51+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-51+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-71 availability unknown
D: [pulseaudio] card.c: output:analog-surround-71+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-surround-71+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:iec958-stereo availability unknown
D: [pulseaudio] card.c: output:iec958-stereo+input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:iec958-stereo+input:iec958-stereo availability unknown
D: [pulseaudio] card.c: off availability unknown
I: [pulseaudio] card.c: alsa_card.usb-0d8c_USB_Sound_Device-00: active_profile: output:analog-stereo+input:analog-stereo
I: [pulseaudio] module-card-restore.c: Restoring profile 'output:iec958-stereo' for card alsa_card.usb-0d8c_USB_Sound_Device-00.
D: [pulseaudio] card.c: alsa_card.usb-0d8c_USB_Sound_Device-00: active_profile: output:analog-stereo+input:analog-stereo -> output:iec958-stereo
I: [pulseaudio] card.c: Created 0 "alsa_card.usb-0d8c_USB_Sound_Device-00"
D: [pulseaudio] reserve-wrap.c: Successfully create reservation lock monitor for device 'Audio1'
I: [pulseaudio] alsa-util.c: Cannot disable ALSA period wakeups
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 5461 ms
D: [pulseaudio] alsa-util.c: Set buffer size first (to 96000 samples), period size second (to 96000 samples).
I: [pulseaudio] alsa-util.c: ALSA period wakeups were not disabled
I: [pulseaudio] alsa-sink.c: Successfully opened device iec958:1.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Digital Stereo (IEC958)' (iec958-stereo).
I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:1'
D: [pulseaudio] alsa-mixer.c: Added 1 ports
I: [pulseaudio] module-device-restore.c: Restoring port for sink sink:alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo: front-left: 68157 / 104%, front-right: 68157 / 104%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo: unmuted
I: [pulseaudio] sink.c: Created sink 0 "alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo" with sample spec s16le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: alsa.resolution_bits = "16"
I: [pulseaudio] sink.c: device.api = "alsa"
I: [pulseaudio] sink.c: device.class = "sound"
I: [pulseaudio] sink.c: alsa.class = "generic"
I: [pulseaudio] sink.c: alsa.subclass = "generic-mix"
I: [pulseaudio] sink.c: alsa.name = "USB Audio"
I: [pulseaudio] sink.c: alsa.id = "USB Audio"
I: [pulseaudio] sink.c: alsa.subdevice = "0"
I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] sink.c: alsa.device = "0"
I: [pulseaudio] sink.c: alsa.card = "1"
I: [pulseaudio] sink.c: alsa.card_name = "ICUSBAUDIO7D"
I: [pulseaudio] sink.c: alsa.long_card_name = "ICUSBAUDIO7D at usb-0000:00:14.0-1.2.3, full speed"
I: [pulseaudio] sink.c: alsa.driver_name = "snd_usb_audio"
I: [pulseaudio] sink.c: device.bus_path = "pci-0000:00:14.0-usb-0:1.2.3:1.0"
I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2.3/3-1.2.3:1.0/sound/card1"
I: [pulseaudio] sink.c: udev.id = "usb-0d8c_USB_Sound_Device-00"
I: [pulseaudio] sink.c: device.bus = "usb"
I: [pulseaudio] sink.c: device.vendor.id = "0d8c"
I: [pulseaudio] sink.c: device.vendor.name = "C-Media Electronics, Inc."
I: [pulseaudio] sink.c: device.product.id = "0102"
I: [pulseaudio] sink.c: device.product.name = "CM106 Like Sound Device"
I: [pulseaudio] sink.c: device.serial = "0d8c_USB_Sound_Device"
I: [pulseaudio] sink.c: device.string = "iec958:1"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "384000"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "192000"
I: [pulseaudio] sink.c: device.access_mode = "mmap+timer"
I: [pulseaudio] sink.c: device.profile.name = "iec958-stereo"
I: [pulseaudio] sink.c: device.profile.description = "Digital Stereo (IEC958)"
I: [pulseaudio] sink.c: device.description = "CM106 Like Sound Device Digital Stereo (IEC958)"
I: [pulseaudio] sink.c: module-udev-detect.discovered = "1"
I: [pulseaudio] sink.c: device.icon_name = "audio-card-usb"
I: [pulseaudio] source.c: Created source 0 "alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor" with sample spec s16le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of CM106 Like Sound Device Digital Stereo (IEC958)"
I: [pulseaudio] source.c: device.class = "monitor"
I: [pulseaudio] source.c: alsa.card = "1"
I: [pulseaudio] source.c: alsa.card_name = "ICUSBAUDIO7D"
I: [pulseaudio] source.c: alsa.long_card_name = "ICUSBAUDIO7D at usb-0000:00:14.0-1.2.3, full speed"
I: [pulseaudio] source.c: alsa.driver_name = "snd_usb_audio"
I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:14.0-usb-0:1.2.3:1.0"
I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2.3/3-1.2.3:1.0/sound/card1"
I: [pulseaudio] source.c: udev.id = "usb-0d8c_USB_Sound_Device-00"
I: [pulseaudio] source.c: device.bus = "usb"
I: [pulseaudio] source.c: device.vendor.id = "0d8c"
I: [pulseaudio] source.c: device.vendor.name = "C-Media Electronics, Inc."
I: [pulseaudio] source.c: device.product.id = "0102"
I: [pulseaudio] source.c: device.product.name = "CM106 Like Sound Device"
I: [pulseaudio] source.c: device.serial = "0d8c_USB_Sound_Device"
I: [pulseaudio] source.c: device.string = "1"
I: [pulseaudio] source.c: module-udev-detect.discovered = "1"
I: [pulseaudio] source.c: device.icon_name = "audio-card-usb"
I: [pulseaudio] alsa-sink.c: Using 2,0 fragments of size 192000 bytes (1000,00ms), buffer size is 384000 bytes (2000,00ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20,00ms
D: [pulseaudio] alsa-sink.c: hwbuf_unused=0
D: [pulseaudio] alsa-sink.c: setting avail_min=95041
D: [pulseaudio] alsa-mixer.c: Activating path iec958-stereo-output
I: [pulseaudio] alsa-sink.c: Driver does not support hardware volume control, falling back to software volume control.
I: [pulseaudio] alsa-sink.c: Driver does not support hardware mute control, falling back to software mute control.
D: [pulseaudio] alsa-util.c: snd_pcm_dump():
D: [pulseaudio] alsa-util.c: Hardware PCM card 1 'ICUSBAUDIO7D' device 0 subdevice 0
D: [pulseaudio] alsa-util.c: Its setup is:
D: [pulseaudio] alsa-util.c: stream : PLAYBACK
D: [pulseaudio] alsa-util.c: access : MMAP_INTERLEAVED
D: [pulseaudio] alsa-util.c: format : S16_LE
D: [pulseaudio] alsa-util.c: subformat : STD
D: [pulseaudio] alsa-util.c: channels : 2
D: [pulseaudio] alsa-util.c: rate : 48000
D: [pulseaudio] alsa-util.c: exact rate : 48000 (48000/1)
D: [pulseaudio] alsa-util.c: msbits : 16
D: [pulseaudio] alsa-util.c: buffer_size : 96000
D: [pulseaudio] alsa-util.c: period_size : 48000
D: [pulseaudio] alsa-util.c: period_time : 1000000
D: [pulseaudio] alsa-util.c: tstamp_mode : ENABLE
D: [pulseaudio] alsa-util.c: tstamp_type : MONOTONIC
D: [pulseaudio] alsa-util.c: period_step : 1
D: [pulseaudio] alsa-util.c: avail_min : 95041
D: [pulseaudio] alsa-util.c: period_event : 0
D: [pulseaudio] alsa-util.c: start_threshold : -1
D: [pulseaudio] alsa-util.c: stop_threshold : 6755399441055744000
D: [pulseaudio] alsa-util.c: silence_threshold: 0
D: [pulseaudio] alsa-util.c: silence_size : 0
D: [pulseaudio] alsa-util.c: boundary : 6755399441055744000
D: [pulseaudio] alsa-util.c: appl_ptr : 0
D: [pulseaudio] alsa-util.c: hw_ptr : 0
D: [alsa-sink-USB Audio] alsa-sink.c: Thread starting up
D: [alsa-sink-USB Audio] util.c: SCHED_RR|SCHED_RESET_ON_FORK worked.
I: [alsa-sink-USB Audio] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5.
D: [pulseaudio] sink.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo: state: INIT -> IDLE
I: [alsa-sink-USB Audio] alsa-sink.c: Starting playback.
D: [pulseaudio] source.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor: state: INIT -> IDLE
I: [pulseaudio] core.c: default_source: (unset) -> alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor
I: [pulseaudio] core.c: default_sink: (unset) -> alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo
D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event.
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #6; argument: "device_id="1" name="usb-0d8c_USB_Sound_Device-00" card_name="alsa_card.usb-0d8c_USB_Sound_Device-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=no use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.2/3-1.2.3/3-1.2.3:1.0/sound/card1 (alsa_card.usb-0d8c_USB_Sound_Device-00) module loaded.
D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC0 is accessible: yes
D: [pulseaudio] module-udev-detect.c: /devices/pci0000:00/0000:00:1b.0/sound/card0 is busy: no
D: [pulseaudio] module-udev-detect.c: Loading module-alsa-card with arguments 'device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=no use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"'
D: [pulseaudio] reserve-wrap.c: Successfully acquired reservation lock on device 'Audio0'
I: [pulseaudio] (alsa-lib)parser.c: UCM is not supported for this HDA model (HDA Intel PCH at 0xd3430000 irq 33)
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:0 use case configuration -6
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HDA Intel PCH use case configuration -6
I: [pulseaudio] alsa-ucm.c: UCM not available for card HDA Intel PCH
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf'
D: [pulseaudio] alsa-mixer.c: Looking at profile input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Checking for recording on Analog Stereo (analog-stereo)
D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open front:0
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 178000 ms
D: [pulseaudio] alsa-util.c: Set buffer size first (to 4800 samples), period size second (to 1200 samples).
D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf'
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0'
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-front-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Capture' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Input Source' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Capture Source' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Internal Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Dock Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost' succeeded (volume=2, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Dock Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Internal Mic Boost' succeeded (volume=2, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line Boost' succeeded (volume=2, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Aux' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Video' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic/Line' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'TV Tuner' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'FM' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Inverted Internal Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Jack Mode' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-front-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-rear-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-rear-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-internal-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Internal Mic Phantom Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Internal Mic Boost' succeeded (volume=1, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Int Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Int Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-dock-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-dock-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Mic - Input Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost' succeeded (volume=1, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM Capture Source' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Select' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic Boost (+20dB)' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-linein'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line - Input Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line Boost' succeeded (volume=1, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-aux'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Aux' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-video'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Video' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-tvtuner'
D: [pulseaudio] alsa-mixer.c: Probe of element 'TV Tuner' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-fm'
D: [pulseaudio] alsa-mixer.c: Probe of element 'FM' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-mic-line'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Mic/Line' failed.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-headphone-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Auto-Mute Mode' succeeded (volume=0, switch=0, enumeration=1, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-headphone-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-input-headset-mic'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headset Mic Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headset Mic Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset Mic Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset Mic' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headset' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-input-headset-mic', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Available mixer paths (after tidying):
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6bfb7e0, direction=2
D: [pulseaudio] alsa-mixer.c: Path analog-input-internal-mic (Internal Microphone), direction=2, priority=89, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=15, min_dB=0, max_dB=52,5
D: [pulseaudio] alsa-mixer.c: Element 'Capture', direction=2, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'Internal Mic Boost', direction=2, switch=0, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'Mic Boost', direction=2, switch=0, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Element 'Line Boost', direction=2, switch=0, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Jack Mic, alsa_name='Mic Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Jack Dock Mic, alsa_name='Dock Mic Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Mic, alsa_name='Front Mic Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Rear Mic, alsa_name='Rear Mic Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Internal Mic Phantom, alsa_name='Internal Mic Phantom Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Path analog-input-mic (Microphone), direction=2, priority=87, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=15, min_dB=0, max_dB=52,5
D: [pulseaudio] alsa-mixer.c: Element 'Mic Boost', direction=2, switch=0, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'Internal Mic Boost', direction=2, switch=0, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Jack Mic Phantom, alsa_name='Mic Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Mic - Input, alsa_name='Mic - Input Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Path analog-input-linein (Line In), direction=2, priority=81, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=15, min_dB=0, max_dB=52,5
D: [pulseaudio] alsa-mixer.c: Element 'Line Boost', direction=2, switch=0, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Jack Line, alsa_name='Line Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Jack Line Phantom, alsa_name='Line Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line - Input, alsa_name='Line - Input Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Looking at profile input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Checking for recording on Digital Stereo (IEC958) (iec958-stereo)
D: [pulseaudio] alsa-util.c: Trying iec958:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:0: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Stereo (analog-stereo)
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo supported.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf'
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf'
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output'
D: [pulseaudio] alsa-mixer.c: Probe of element 'Hardware Master' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Master' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Master Mono' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Rear' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Side' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Center' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'CLFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'PCM' succeeded (volume=1, switch=0, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'External Amplifier' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Boost' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'IEC958 Optical Raw' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Analog Output' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-lineout'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Line Out Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Rear Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Front Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Front Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out CLFE Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out CLFE Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Surround Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Surround Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Side Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Line Out Side Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Line Out Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Line Out Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker+LO' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone+LO' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Line HP Swap' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=2, switch=2, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone',1 succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone2' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Desktop Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Bass Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Front' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Surround' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker Side' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker CLFE' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-speaker'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Headphone Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Phantom Jack' succeeded (found!)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker Front Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Speaker - Output Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Front Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Surround Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Center Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probe of element 'LFE Speaker' succeeded (volume=0, switch=0, enumeration=0, has_dB=0).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Dock Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Front Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone Phantom Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Headphone - Output Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Speaker+LO' succeeded (volume=2, switch=2, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=1, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Probing path 'analog-output-headphones-2'
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Jack',1 succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of jack 'Front Headphone Surround Jack' succeeded (not found)
D: [pulseaudio] alsa-mixer.c: Probe of element 'Headphone' succeeded (volume=3, switch=1, enumeration=0, has_dB=1).
D: [pulseaudio] alsa-mixer.c: Skipping path 'analog-output-headphones-2', none of required-any elements preset.
D: [pulseaudio] alsa-mixer.c: Removing path 'analog-output' as it is a subset of 'analog-output-lineout'.
D: [pulseaudio] alsa-mixer.c: Path Set 0x55ebf6ce03d0, direction=1
D: [pulseaudio] alsa-mixer.c: Path analog-output-lineout (Line Out), direction=1, priority=90, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=127, min_dB=-200051, max_dB=0
D: [pulseaudio] alsa-mixer.c: Element 'Master', direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x7ffffffffffff, n_channels=1, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'Speaker+LO', direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Element 'Headphone', direction=1, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Element 'PCM', direction=1, switch=0, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Jack Line Out, alsa_name='Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Phantom, alsa_name='Line Out Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Line Out, alsa_name='Front Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Line Out Phantom, alsa_name='Front Line Out Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Rear Line Out, alsa_name='Rear Line Out Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Rear Line Out Phantom, alsa_name='Rear Line Out Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Front, alsa_name='Line Out Front Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Front Phantom, alsa_name='Line Out Front Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out CLFE, alsa_name='Line Out CLFE Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out CLFE Phantom, alsa_name='Line Out CLFE Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Surround, alsa_name='Line Out Surround Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Surround Phantom, alsa_name='Line Out Surround Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Side, alsa_name='Line Out Side Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Line Out Side Phantom, alsa_name='Line Out Side Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Dock Line Out, alsa_name='Dock Line Out Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Jack Dock Line Out Phantom, alsa_name='Dock Line Out Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Path analog-output-speaker (Speakers), direction=1, priority=100, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=127, min_dB=-200051, max_dB=0
D: [pulseaudio] alsa-mixer.c: Jack Headphone, alsa_name='Headphone Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Jack Dock Headphone, alsa_name='Dock Headphone Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Headphone, alsa_name='Front Headphone Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker, alsa_name='Speaker Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker Phantom, alsa_name='Speaker Phantom Jack', index='0', detection possible
D: [pulseaudio] alsa-mixer.c: Jack Speaker Front Phantom, alsa_name='Speaker Front Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Speaker - Output, alsa_name='Speaker - Output Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Path analog-output-headphones (Headphones), direction=1, priority=99, probed=yes, supported=yes, has_mute=yes, has_volume=yes, has_dB=yes, min_volume=0, max_volume=127, min_dB=-200051, max_dB=0
D: [pulseaudio] alsa-mixer.c: Element 'Speaker+LO', direction=1, switch=2, volume=2, volume_limit=-1, enumeration=0, required=0, required_any=0, required_absent=0, mask=0x6, n_channels=2, override_map=00
D: [pulseaudio] alsa-mixer.c: Element 'Headphone', direction=1, switch=1, volume=1, volume_limit=-1, enumeration=0, required=0, required_any=4, required_absent=0, mask=0x3600000000f66, n_channels=2, override_map=03
D: [pulseaudio] alsa-mixer.c: Jack Dock Headphone Phantom, alsa_name='Dock Headphone Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Headphone Front, alsa_name='Front Headphone Front Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Front Headphone Phantom, alsa_name='Front Headphone Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Headphone Phantom, alsa_name='Headphone Phantom Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Headphone Mic, alsa_name='Headphone Mic Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Jack Headphone - Output, alsa_name='Headphone - Output Jack', index='0', detection unavailable
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-stereo+input:analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo supported.
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-stereo+input:iec958-stereo - will not be able to open input:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-21
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 2.1 (analog-surround-21)
D: [pulseaudio] alsa-util.c: Trying surround21:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm_route.c: Found no matching channel map
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-21
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-21+input:analog-stereo - will not be able to open output:analog-surround-21
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-21+input:iec958-stereo - will not be able to open output:analog-surround-21
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-40
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 4.0 (analog-surround-40)
D: [pulseaudio] alsa-util.c: Trying surround40:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround40:0
D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_set_channels(4) failed: Das Argument ist ungültig
D: [pulseaudio] alsa-util.c: Trying surround40:0 without SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Trying plug:surround40:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open plug:surround40:0
D: [pulseaudio] alsa-util.c: Trying plug:surround40:0 without SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround40:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-40+input:analog-stereo - will not be able to open output:analog-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-40+input:iec958-stereo - will not be able to open output:analog-surround-40
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-41
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 4.1 (analog-surround-41)
D: [pulseaudio] alsa-util.c: Trying surround41:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-41
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-41+input:analog-stereo - will not be able to open output:analog-surround-41
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-41+input:iec958-stereo - will not be able to open output:analog-surround-41
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-50
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 5.0 (analog-surround-50)
D: [pulseaudio] alsa-util.c: Trying surround50:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-50
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-50+input:analog-stereo - will not be able to open output:analog-surround-50
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-50+input:iec958-stereo - will not be able to open output:analog-surround-50
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 5.1 (analog-surround-51)
D: [pulseaudio] alsa-util.c: Trying surround51:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround51:0
D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_set_channels(6) failed: Das Argument ist ungültig
D: [pulseaudio] alsa-util.c: Trying surround51:0 without SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Trying plug:surround51:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open plug:surround51:0
D: [pulseaudio] alsa-util.c: Trying plug:surround51:0 without SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround51:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-51+input:analog-stereo - will not be able to open output:analog-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-51+input:iec958-stereo - will not be able to open output:analog-surround-51
D: [pulseaudio] alsa-mixer.c: Looking at profile output:analog-surround-71
D: [pulseaudio] alsa-mixer.c: Checking for playback on Analog Surround 7.1 (analog-surround-71)
D: [pulseaudio] alsa-util.c: Trying surround71:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open surround71:0
D: [pulseaudio] alsa-util.c: snd_pcm_hw_params_set_channels(8) failed: Das Argument ist ungültig
D: [pulseaudio] alsa-util.c: Trying surround71:0 without SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Trying plug:surround71:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open plug:surround71:0
D: [pulseaudio] alsa-util.c: Trying plug:surround71:0 without SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Failed to set hardware parameters on plug:surround71:0: Das Argument ist ungültig
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:analog-surround-71
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-71+input:analog-stereo - will not be able to open output:analog-surround-71
D: [pulseaudio] alsa-mixer.c: Skipping profile output:analog-surround-71+input:iec958-stereo - will not be able to open output:analog-surround-71
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (IEC958) (iec958-stereo)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-stereo+input:analog-stereo - will not be able to open output:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-stereo+input:iec958-stereo - will not be able to open output:iec958-stereo
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 4.0 (IEC958/AC3) (iec958-ac3-surround-40)
D: [pulseaudio] alsa-util.c: Trying a52:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:0
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:analog-stereo - will not be able to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-40+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-40
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (IEC958/AC3) (iec958-ac3-surround-51)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:analog-stereo - will not be able to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-ac3-surround-51+input:iec958-stereo - will not be able to open output:iec958-ac3-surround-51
D: [pulseaudio] alsa-mixer.c: Looking at profile output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (IEC958/DTS) (iec958-dts-surround-51)
D: [pulseaudio] alsa-util.c: Trying dca:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:0: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:analog-stereo - will not be able to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Skipping profile output:iec958-dts-surround-51+input:iec958-stereo - will not be able to open output:iec958-dts-surround-51
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI) (hdmi-stereo)
D: [pulseaudio] alsa-util.c: Trying hdmi:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:analog-stereo - will not be able to open output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo+input:iec958-stereo - will not be able to open output:hdmi-stereo
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI) (hdmi-surround)
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:analog-stereo - will not be able to open output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround+input:iec958-stereo - will not be able to open output:hdmi-surround
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI) (hdmi-surround71)
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71+input:analog-stereo - will not be able to open output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71+input:iec958-stereo - will not be able to open output:hdmi-surround71
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI/DTS) (hdmi-dts-surround)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround+input:analog-stereo - will not be able to open output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround+input:iec958-stereo - will not be able to open output:hdmi-dts-surround
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 2) (hdmi-stereo-extra1)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:analog-stereo - will not be able to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra1+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 2) (hdmi-surround-extra1)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:analog-stereo - will not be able to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra1+input:iec958-stereo - will not be able to open output:hdmi-surround-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 2) (hdmi-surround71-extra1)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra1+input:analog-stereo - will not be able to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra1+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 2/DTS) (hdmi-dts-surround-extra1)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,1 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,1: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra1+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra1+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra1
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 3) (hdmi-stereo-extra2)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,2 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,2: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:analog-stereo - will not be able to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra2+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 3) (hdmi-surround-extra2)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:analog-stereo - will not be able to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra2+input:iec958-stereo - will not be able to open output:hdmi-surround-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 3) (hdmi-surround71-extra2)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra2+input:analog-stereo - will not be able to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra2+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 3/DTS) (hdmi-dts-surround-extra2)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,2 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,2: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra2+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra2+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra2
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 4) (hdmi-stereo-extra3)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,3 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,3: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:analog-stereo - will not be able to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra3+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 4) (hdmi-surround-extra3)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:analog-stereo - will not be able to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra3+input:iec958-stereo - will not be able to open output:hdmi-surround-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 4) (hdmi-surround71-extra3)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra3+input:analog-stereo - will not be able to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra3+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 4/DTS) (hdmi-dts-surround-extra3)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,3 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,3: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra3+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra3+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra3
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 5) (hdmi-stereo-extra4)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,4 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,4: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra4+input:analog-stereo - will not be able to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra4+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 5) (hdmi-surround-extra4)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra4+input:analog-stereo - will not be able to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra4+input:iec958-stereo - will not be able to open output:hdmi-surround-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 5) (hdmi-surround71-extra4)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra4+input:analog-stereo - will not be able to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra4+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 5/DTS) (hdmi-dts-surround-extra4)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,4 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,4: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra4+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra4+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra4
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 6) (hdmi-stereo-extra5)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,5 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,5: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra5+input:analog-stereo - will not be able to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra5+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 6) (hdmi-surround-extra5)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra5+input:analog-stereo - will not be able to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra5+input:iec958-stereo - will not be able to open output:hdmi-surround-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 6) (hdmi-surround71-extra5)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra5+input:analog-stereo - will not be able to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra5+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 6/DTS) (hdmi-dts-surround-extra5)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,5 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,5: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra5+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra5+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra5
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 7) (hdmi-stereo-extra6)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,6 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,6: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra6+input:analog-stereo - will not be able to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra6+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 7) (hdmi-surround-extra6)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra6+input:analog-stereo - will not be able to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra6+input:iec958-stereo - will not be able to open output:hdmi-surround-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 7) (hdmi-surround71-extra6)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra6+input:analog-stereo - will not be able to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra6+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 7/DTS) (hdmi-dts-surround-extra6)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,6 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,6: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra6+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra6+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra6
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Stereo (HDMI 8) (hdmi-stereo-extra7)
D: [pulseaudio] alsa-util.c: Trying hdmi:0,7 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,7: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra7+input:analog-stereo - will not be able to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-stereo-extra7+input:iec958-stereo - will not be able to open output:hdmi-stereo-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 8) (hdmi-surround-extra7)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra7+input:analog-stereo - will not be able to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround-extra7+input:iec958-stereo - will not be able to open output:hdmi-surround-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 7.1 (HDMI 8) (hdmi-surround71-extra7)
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra7+input:analog-stereo - will not be able to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-surround71-extra7+input:iec958-stereo - will not be able to open output:hdmi-surround71-extra7
D: [pulseaudio] alsa-mixer.c: Looking at profile output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Checking for playback on Digital Surround 5.1 (HDMI 8/DTS) (hdmi-dts-surround-extra7)
D: [pulseaudio] alsa-util.c: Trying dcahdmi:0,7 with SND_PCM_NO_AUTO_FORMAT ...
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,7: Datei oder Verzeichnis nicht gefunden
D: [pulseaudio] alsa-mixer.c: Caching failure to open output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra7+input:analog-stereo - will not be able to open output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Skipping profile output:hdmi-dts-surround-extra7+input:iec958-stereo - will not be able to open output:hdmi-dts-surround-extra7
D: [pulseaudio] alsa-mixer.c: Profile set 0x55ebf6ad77d0, auto_profiles=yes, probed=yes, n_mappings=1, n_profiles=3, n_decibel_fixes=0
D: [pulseaudio] alsa-mixer.c: Mapping analog-stereo (Analog Stereo), priority=65, channel_map=front-left,front-right, supported=yes, direction=0
D: [pulseaudio] alsa-mixer.c: Profile input:analog-stereo (Analog Stereo-Eingabe), input=analog-stereo, output=(null) priority=65, supported=yes n_input_mappings=1, n_output_mappings=0
D: [pulseaudio] alsa-mixer.c: Input analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo (Analog Stereo-Ausgabe), input=(null), output=analog-stereo priority=6500, supported=yes n_input_mappings=0, n_output_mappings=1
D: [pulseaudio] alsa-mixer.c: Output analog-stereo
D: [pulseaudio] alsa-mixer.c: Profile output:analog-stereo+input:analog-stereo (Analog Stereo Duplex), input=analog-stereo, output=analog-stereo priority=6565, supported=yes n_input_mappings=1, n_output_mappings=1
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 1 from port analog-input-internal-mic
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 2 from port analog-input-mic
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 3 from port analog-input-linein
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 4 from port analog-output-lineout
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 5 from port analog-output-speaker
D: [pulseaudio] module-alsa-card.c: Pruned singleton availability group Legacy 6 from port analog-output-headphones
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_00_1b.0.
D: [pulseaudio] module-alsa-card.c: Found 9 jacks.
D: [pulseaudio] module-alsa-card.c: Jack 'Dock Line Out Jack' is now unplugged
D: [pulseaudio] device-port.c: Setting port analog-output-lineout to status no
D: [pulseaudio] module-alsa-card.c: Jack 'Headphone Jack' is now unplugged
D: [pulseaudio] module-alsa-card.c: Jack 'Speaker Phantom Jack' is now plugged in
D: [pulseaudio] device-port.c: Setting port analog-output-headphones to status no
D: [pulseaudio] module-alsa-card.c: Jack 'Mic Jack' is now unplugged
D: [pulseaudio] module-alsa-card.c: Jack 'Internal Mic Phantom Jack' is now plugged in
D: [pulseaudio] device-port.c: Setting port analog-input-mic to status no
D: [pulseaudio] module-alsa-card.c: Jack 'Line Jack' is now unplugged
D: [pulseaudio] device-port.c: Setting port analog-input-linein to status no
D: [pulseaudio] card.c: Looking for initial profile for card alsa_card.pci-0000_00_1b.0
D: [pulseaudio] card.c: input:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-stereo availability unknown
D: [pulseaudio] card.c: output:analog-stereo+input:analog-stereo availability unknown
D: [pulseaudio] card.c: off availability unknown
I: [pulseaudio] card.c: alsa_card.pci-0000_00_1b.0: active_profile: output:analog-stereo+input:analog-stereo
I: [pulseaudio] module-card-restore.c: Restoring profile 'output:analog-stereo' for card alsa_card.pci-0000_00_1b.0.
D: [pulseaudio] card.c: alsa_card.pci-0000_00_1b.0: active_profile: output:analog-stereo+input:analog-stereo -> output:analog-stereo
I: [pulseaudio] card.c: Created 1 "alsa_card.pci-0000_00_1b.0"
D: [pulseaudio] reserve-wrap.c: Successfully create reservation lock monitor for device 'Audio0'
D: [pulseaudio] alsa-util.c: Trying front:0 with SND_PCM_NO_AUTO_FORMAT ...
D: [pulseaudio] alsa-util.c: Managed to open front:0
I: [pulseaudio] alsa-util.c: Trying to disable ALSA period wakeups, using timers only
D: [pulseaudio] alsa-util.c: Maximum hw buffer size is 178000 ms
D: [pulseaudio] alsa-util.c: Set buffer size first (to 96000 samples), period size second (to 96000 samples).
I: [pulseaudio] alsa-util.c: ALSA period wakeups disabled
I: [pulseaudio] alsa-sink.c: Successfully opened device front:0.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Analog Stereo' (analog-stereo).
I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode.
D: [pulseaudio] alsa-mixer.c: Added 3 ports
I: [pulseaudio] module-device-restore.c: Restoring port for sink sink:alsa_output.pci-0000_00_1b.0.analog-stereo.
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.pci-0000_00_1b.0.analog-stereo: front-left: 74711 / 114%, front-right: 74711 / 114%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.pci-0000_00_1b.0.analog-stereo: unmuted
I: [pulseaudio] sink.c: Created sink 1 "alsa_output.pci-0000_00_1b.0.analog-stereo" with sample spec s16le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: alsa.resolution_bits = "16"
I: [pulseaudio] sink.c: device.api = "alsa"
I: [pulseaudio] sink.c: device.class = "sound"
I: [pulseaudio] sink.c: alsa.class = "generic"
I: [pulseaudio] sink.c: alsa.subclass = "generic-mix"
I: [pulseaudio] sink.c: alsa.name = "92HD81B1X5 Analog"
I: [pulseaudio] sink.c: alsa.id = "92HD81B1X5 Analog"
I: [pulseaudio] sink.c: alsa.subdevice = "0"
I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] sink.c: alsa.device = "0"
I: [pulseaudio] sink.c: alsa.card = "0"
I: [pulseaudio] sink.c: alsa.card_name = "HDA Intel PCH"
I: [pulseaudio] sink.c: alsa.long_card_name = "HDA Intel PCH at 0xd3430000 irq 33"
I: [pulseaudio] sink.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] sink.c: device.bus_path = "pci-0000:00:1b.0"
I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
I: [pulseaudio] sink.c: device.bus = "pci"
I: [pulseaudio] sink.c: device.vendor.id = "8086"
I: [pulseaudio] sink.c: device.vendor.name = "Intel Corporation"
I: [pulseaudio] sink.c: device.product.id = "1e20"
I: [pulseaudio] sink.c: device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
I: [pulseaudio] sink.c: device.form_factor = "internal"
I: [pulseaudio] sink.c: device.string = "front:0"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "384000"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "192000"
I: [pulseaudio] sink.c: device.access_mode = "mmap+timer"
I: [pulseaudio] sink.c: device.profile.name = "analog-stereo"
I: [pulseaudio] sink.c: device.profile.description = "Analog Stereo"
I: [pulseaudio] sink.c: device.description = "Internes Audio Analog Stereo"
I: [pulseaudio] sink.c: module-udev-detect.discovered = "1"
I: [pulseaudio] sink.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] module-device-restore.c: Restoring mute state for source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor: muted
I: [pulseaudio] source.c: Created source 1 "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor" with sample spec s16le 2ch 48000Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of Internes Audio Analog Stereo"
I: [pulseaudio] source.c: device.class = "monitor"
I: [pulseaudio] source.c: alsa.card = "0"
I: [pulseaudio] source.c: alsa.card_name = "HDA Intel PCH"
I: [pulseaudio] source.c: alsa.long_card_name = "HDA Intel PCH at 0xd3430000 irq 33"
I: [pulseaudio] source.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:1b.0"
I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
I: [pulseaudio] source.c: device.bus = "pci"
I: [pulseaudio] source.c: device.vendor.id = "8086"
I: [pulseaudio] source.c: device.vendor.name = "Intel Corporation"
I: [pulseaudio] source.c: device.product.id = "1e20"
I: [pulseaudio] source.c: device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
I: [pulseaudio] source.c: device.form_factor = "internal"
I: [pulseaudio] source.c: device.string = "0"
I: [pulseaudio] source.c: module-udev-detect.discovered = "1"
I: [pulseaudio] source.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] alsa-sink.c: Using 2,0 fragments of size 192000 bytes (1000,00ms), buffer size is 384000 bytes (2000,00ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20,00ms
D: [pulseaudio] alsa-sink.c: hwbuf_unused=0
D: [pulseaudio] alsa-sink.c: setting avail_min=95041
D: [pulseaudio] alsa-mixer.c: Activating path analog-output-speaker
I: [pulseaudio] alsa-sink.c: Hardware volume ranges from -200050,98 dB to 0,00 dB.
I: [pulseaudio] alsa-sink.c: Fixing base volume to 0,00 dB
I: [pulseaudio] alsa-sink.c: Using hardware volume control. Hardware dB scale supported.
I: [pulseaudio] alsa-sink.c: Using hardware mute control.
D: [pulseaudio] alsa-util.c: snd_pcm_dump():
D: [pulseaudio] alsa-util.c: Soft volume PCM
D: [pulseaudio] alsa-util.c: Control: PCM Playback Volume
D: [pulseaudio] alsa-util.c: min_dB: -51
D: [pulseaudio] alsa-util.c: max_dB: 0
D: [pulseaudio] alsa-util.c: resolution: 256
D: [pulseaudio] alsa-util.c: Its setup is:
D: [pulseaudio] alsa-util.c: stream : PLAYBACK
D: [pulseaudio] alsa-util.c: access : MMAP_INTERLEAVED
D: [pulseaudio] alsa-util.c: format : S16_LE
D: [pulseaudio] alsa-util.c: subformat : STD
D: [pulseaudio] alsa-util.c: channels : 2
D: [pulseaudio] alsa-util.c: rate : 48000
D: [pulseaudio] alsa-util.c: exact rate : 48000 (48000/1)
D: [pulseaudio] alsa-util.c: msbits : 16
D: [pulseaudio] alsa-util.c: buffer_size : 96000
D: [pulseaudio] alsa-util.c: period_size : 48000
D: [pulseaudio] alsa-util.c: period_time : 1000000
D: [pulseaudio] alsa-util.c: tstamp_mode : ENABLE
D: [pulseaudio] alsa-util.c: tstamp_type : MONOTONIC
D: [pulseaudio] alsa-util.c: period_step : 1
D: [pulseaudio] alsa-util.c: avail_min : 95041
D: [pulseaudio] alsa-util.c: period_event : 0
D: [pulseaudio] alsa-util.c: start_threshold : -1
D: [pulseaudio] alsa-util.c: stop_threshold : 6755399441055744000
D: [pulseaudio] alsa-util.c: silence_threshold: 0
D: [pulseaudio] alsa-util.c: silence_size : 0
D: [pulseaudio] alsa-util.c: boundary : 6755399441055744000
D: [pulseaudio] alsa-util.c: Slave: Hardware PCM card 0 'HDA Intel PCH' device 0 subdevice 0
D: [pulseaudio] alsa-util.c: appl_ptr : 0
D: [pulseaudio] alsa-util.c: hw_ptr : 0
D: [pulseaudio] alsa-sink.c: Requested volume: front-left: 74711 / 114% / 3,41 dB, front-right: 74711 / 114% / 3,41 dB
D: [pulseaudio] alsa-sink.c: Got hardware volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
D: [pulseaudio] alsa-sink.c: Calculated software volume: front-left: 74711 / 114% / 3,41 dB, front-right: 74711 / 114% / 3,41 dB (accurate-enough=no)
D: [alsa-sink-92HD81B1X5 Analog] alsa-sink.c: Thread starting up
D: [alsa-sink-92HD81B1X5 Analog] util.c: SCHED_RR|SCHED_RESET_ON_FORK worked.
I: [alsa-sink-92HD81B1X5 Analog] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5.
D: [pulseaudio] sink.c: alsa_output.pci-0000_00_1b.0.analog-stereo: state: INIT -> IDLE
I: [alsa-sink-92HD81B1X5 Analog] alsa-sink.c: Starting playback.
D: [pulseaudio] source.c: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor: state: INIT -> IDLE
D: [pulseaudio] module-device-restore.c: Could not set format on sink alsa_output.pci-0000_00_1b.0.analog-stereo
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #7; argument: "device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=no use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:1b.0/sound/card0 (alsa_card.pci-0000_00_1b.0) module loaded.
I: [pulseaudio] module-udev-detect.c: Found 2 cards.
I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: "").
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-jackdbus-detect.so': success
D: [pulseaudio] module-jackdbus-detect.c: jackdbus isn't running.
I: [pulseaudio] module.c: Loaded "module-jackdbus-detect" (index: #8; argument: "channels=2").
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-bluetooth-policy.so': success
I: [pulseaudio] module.c: Loaded "module-bluetooth-policy" (index: #9; argument: "").
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-bluetooth-discover.so': success
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-bluez5-discover.so': success
D: [pulseaudio] dbus-util.c: Successfully connected to D-Bus system bus 4f269cc7f392ad4bf591413660806b27 as :1.39
I: [pulseaudio] module.c: Loaded "module-bluez5-discover" (index: #11; argument: "").
I: [pulseaudio] module.c: Loaded "module-bluetooth-discover" (index: #10; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Memstats added for object /org/pulseaudio/core1/memstats
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile3
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile4
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile5
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile6
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile7
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile8
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile9
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile10
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile11
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile12
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile13
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile14
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile15
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile16
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile17
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile18
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile19
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile20
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile21
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile22
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile23
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile24
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile25
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card0/profile26
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Card added for object /org/pulseaudio/core1/card0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.CardProfile added for object /org/pulseaudio/core1/card1/profile3
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Card added for object /org/pulseaudio/core1/card1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.DevicePort added for object /org/pulseaudio/core1/sink0/port0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Device added for object /org/pulseaudio/core1/sink0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Sink added for object /org/pulseaudio/core1/sink0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.DevicePort added for object /org/pulseaudio/core1/sink1/port0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.DevicePort added for object /org/pulseaudio/core1/sink1/port1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.DevicePort added for object /org/pulseaudio/core1/sink1/port2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Device added for object /org/pulseaudio/core1/sink1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Sink added for object /org/pulseaudio/core1/sink1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Device added for object /org/pulseaudio/core1/source0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Source added for object /org/pulseaudio/core1/source0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Device added for object /org/pulseaudio/core1/source1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Source added for object /org/pulseaudio/core1/source1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module0
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module1
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module2
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module3
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module4
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module5
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module6
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module7
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module8
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module9
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module10
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module11
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module12
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1 added for object /org/pulseaudio/core1
I: [pulseaudio] module.c: Loaded "module-dbus-protocol" (index: #12; argument: "").
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-esound-protocol-unix.so': failure
I: [pulseaudio] socket-server.c: Found socket activation socket for '/run/user/1000/pulse/native' \o/
I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #13; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module13
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-gsettings.so': success
I: [pulseaudio] module.c: Loaded "module-gsettings" (index: #14; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module14
I: [pulseaudio] module-default-device-restore.c: Restoring default sink 'alsa_output.pci-0000_00_1b.0.analog-stereo'.
I: [pulseaudio] core.c: configured_default_sink: (unset) -> alsa_output.pci-0000_00_1b.0.analog-stereo
D: [pulseaudio] core-subscribe.c: Dropped redundant event due to change event.
I: [pulseaudio] core.c: default_sink: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo -> alsa_output.pci-0000_00_1b.0.analog-stereo
I: [pulseaudio] module-default-device-restore.c: Restoring default source 'alsa_output.pci-0000_00_1b.0.analog-stereo.monitor'.
I: [pulseaudio] core.c: configured_default_source: (unset) -> alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
I: [pulseaudio] core.c: default_source: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor -> alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #15; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module15
I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #16; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module16
I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #17; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module17
D: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo becomes idle, timeout in 5 seconds.
D: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.pci-0000_00_1b.0.analog-stereo becomes idle, timeout in 5 seconds.
I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #18; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module18
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-console-kit.so': success
I: [pulseaudio] module.c: Loaded "module-console-kit" (index: #19; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module19
D: [pulseaudio] module.c: Checking for existence of '/usr/lib/pulse-14.2/modules/module-systemd-login.so': success
I: [pulseaudio] client.c: Created 0 "Login Session 1"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client0
D: [pulseaudio] module-systemd-login.c: Added new session 1
I: [pulseaudio] core.c: exit_idle_time: 20 -> 0
I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #20; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module20
I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #21; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module21
D: [pulseaudio] stream-interaction.c: Using role 'phone' as trigger role.
D: [pulseaudio] stream-interaction.c: Using roles 'music' and 'video' as cork roles.
I: [pulseaudio] module.c: Loaded "module-role-cork" (index: #22; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module22
I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #23; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module23
I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #24; argument: "").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module24
D: [pulseaudio] main.c: Got org.PulseAudio1!
D: [pulseaudio] main.c: Got org.pulseaudio.Server!
I: [pulseaudio] main.c: Daemon startup complete.
I: [pulseaudio] client.c: Created 1 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client1
D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC1 is accessible: yes
D: [pulseaudio] module-udev-detect.c: Resuming all sinks and sources of card alsa_card.usb-0d8c_USB_Sound_Device-00.
D: [pulseaudio] module-udev-detect.c: /dev/snd/controlC0 is accessible: yes
D: [pulseaudio] module-udev-detect.c: Resuming all sinks and sources of card alsa_card.pci-0000_00_1b.0.
D: [pulseaudio] bluez5-util.c: Unknown interface org.freedesktop.DBus.Introspectable found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.AgentManager1 found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.ProfileManager1 found, skipping
D: [pulseaudio] bluez5-util.c: Adapter /org/bluez/hci0 found
D: [pulseaudio] bluez5-util.c: Registering /MediaEndpoint/A2DPSink/sbc on adapter /org/bluez/hci0
D: [pulseaudio] bluez5-util.c: Registering /MediaEndpoint/A2DPSource/sbc on adapter /org/bluez/hci0
D: [pulseaudio] bluez5-util.c: Unknown interface org.freedesktop.DBus.Properties found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.GattManager1 found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.LEAdvertisingManager1 found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.Media1 found, skipping
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.NetworkServer1 found, skipping
D: [pulseaudio] bluez5-util.c: Device /org/bluez/hci0/dev_30_C0_1B_E7_C2_D5 found
D: [pulseaudio] bluez5-util.c: Address: 30:C0:1B:E7:C2
5
D: [pulseaudio] bluez5-util.c: Alias: JBL E55BT
D: [pulseaudio] bluez5-util.c: Class: 2360324
D: [pulseaudio] bluez5-util.c: UUIDs: 00001108-0000-1000-8000-00805f9b34fb
D: [pulseaudio] bluez5-util.c: UUIDs: 0000110b-0000-1000-8000-00805f9b34fb
D: [pulseaudio] bluez5-util.c: UUIDs: 0000110c-0000-1000-8000-00805f9b34fb
D: [pulseaudio] bluez5-util.c: UUIDs: 0000110e-0000-1000-8000-00805f9b34fb
D: [pulseaudio] bluez5-util.c: UUIDs: 0000111e-0000-1000-8000-00805f9b34fb
D: [pulseaudio] bluez5-util.c: Adapter: /org/bluez/hci0
D: [pulseaudio] bluez5-util.c: Unknown interface org.bluez.MediaControl1 found, skipping
D: [pulseaudio] backend-native.c: Bluetooth Headset Backend API support using the native backend
D: [pulseaudio] backend-native.c: Registering Profile /Profile/HSPAGProfile 00001112-0000-1000-8000-00805f9b34fb
D: [pulseaudio] protocol-native.c: Protocol version: remote 34, local 34
I: [pulseaudio] protocol-native.c: Got credentials: uid=1000 gid=1001 success=1
D: [pulseaudio] protocol-native.c: SHM possible: yes
D: [pulseaudio] protocol-native.c: Negotiated SHM: yes
D: [pulseaudio] protocol-native.c: Memfd possible: yes
D: [pulseaudio] protocol-native.c: Negotiated SHM type: shared memfd
D: [pulseaudio] memblock.c: Using shared memfd memory pool with 1024 slots of size 64,0 KiB each, total size is 64,0 MiB, maximum usable slot size is 65472
D: [pulseaudio] srbchannel.c: SHM block is 65472 bytes, ringbuffer capacity is 2 * 32712 bytes
D: [pulseaudio] protocol-native.c: Enabling srbchannel...
I: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
D: [pulseaudio] bluez5-util.c: oFono is running: no
D: [pulseaudio] backend-native.c: Registering Profile /Profile/HSPHSProfile 00001108-0000-1000-8000-00805f9b34fb
D: [pulseaudio] module-augment-properties.c: Looking for .desktop file for xfwm4
D: [pulseaudio] protocol-native.c: Client enabled srbchannel.
D: [pulseaudio] bluez5-util.c: Properties changed in adapter /org/bluez/hci0
I: [pulseaudio] client.c: Created 2 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client2
D: [pulseaudio] module-augment-properties.c: Looking for .desktop file for wrapper-2.0
I: [pulseaudio] client.c: Created 3 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client3
D: [pulseaudio] module-augment-properties.c: Looking for .desktop file for pactl
I: [pulseaudio] module.c: Loaded "module-x11-publish" (index: #25; argument: "display=:0.0 xauthority=/home/ladmin/.Xauthority").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module25
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client removed from object /org/pulseaudio/core1/client3
I: [pulseaudio] client.c: Freed 3 "pactl"
I: [pulseaudio] protocol-native.c: Connection died.
I: [pulseaudio] client.c: Created 4 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client4
I: [pulseaudio] module-x11-xsmp.c: Connected to session manager 'xfce4-session' as '25599a138-e462-48e9-8198-e3a6bbfaa972'.
I: [pulseaudio] client.c: Created 5 "XSMP Session on xfce4-session as 25599a138-e462-48e9-8198-e3a6bbfaa972"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client5
I: [pulseaudio] module.c: Loaded "module-x11-xsmp" (index: #26; argument: "display=:0.0 xauthority=/home/ladmin/.Xauthority session_manager=local/elite.bnetza.lan:@/tmp/.ICE-unix/1026,unix/elite.bnetza.lan:/tmp/.ICE-unix/1026").
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Module added for object /org/pulseaudio/core1/module26
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client removed from object /org/pulseaudio/core1/client4
I: [pulseaudio] client.c: Freed 4 "pactl"
I: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.pci-0000_00_1b.0.analog-stereo idle for too long, suspending ...
I: [alsa-sink-92HD81B1X5 Analog] alsa-sink.c: Device suspended...
D: [pulseaudio] sink.c: alsa_output.pci-0000_00_1b.0.analog-stereo: suspend_cause: (none) -> IDLE
D: [pulseaudio] sink.c: alsa_output.pci-0000_00_1b.0.analog-stereo: state: IDLE -> SUSPENDED
D: [pulseaudio] source.c: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor: suspend_cause: (none) -> IDLE
D: [pulseaudio] source.c: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor: state: IDLE -> SUSPENDED
D: [pulseaudio] core.c: Hmm, no streams around, trying to vacuum.
I: [pulseaudio] module-suspend-on-idle.c: Sink alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo idle for too long, suspending ...
I: [alsa-sink-USB Audio] alsa-sink.c: Device suspended...
D: [pulseaudio] sink.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo: suspend_cause: (none) -> IDLE
D: [pulseaudio] sink.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo: state: IDLE -> SUSPENDED
D: [pulseaudio] source.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor: suspend_cause: (none) -> IDLE
D: [pulseaudio] source.c: alsa_output.usb-0d8c_USB_Sound_Device-00.iec958-stereo.monitor: state: IDLE -> SUSPENDED
I: [pulseaudio] client.c: Created 6 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client6
D: [pulseaudio] module-augment-properties.c: Looking for .desktop file for caja
D: [pulseaudio] module-augment-properties.c: Found /usr/share//applications/caja.desktop.
D: [pulseaudio] conf-parser.c: Parsing configuration file '/usr/share//applications/caja.desktop'
I: [pulseaudio] client.c: Created 7 "Native client (UNIX socket client)"
D: [pulseaudio] protocol-dbus.c: Interface org.PulseAudio.Core1.Client added for object /org/pulseaudio/core1/client7
D: [pulseaudio] module-augment-properties.c: Looking for .desktop file for xfdesktop
