HWiNFO64 Version 5.83-3435
Bus -----------------------------------------------------------------------
PCI Bus #0 ----------------------------------------------------------------
AMD Zen - Root Complex ----------------------------------------------------
[General Information]
Device Name: AMD Zen - Root Complex
Original Device Name: AMD Zen - Root Complex
Device Class: Host-to-PCI Bridge
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:0:0
PCI Latency Timer: 0
Hardware ID: PCI\VEN_1022&DEV_1450&SUBSYS_14501849&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Bus Mastering: Disabled
Running At 66 MHz: Not Capable
Fast Back-to-Back Transactions: Not Capable
[Driver Information]
Driver Manufacturer: (Standardsystemgeräte)
Driver Description: PCI Standard-Host-CPU-Brücke
Driver Provider: Microsoft
Driver Version: 10.0.17134.1
Driver Date: 21-Jun-2006
DeviceInstanceId PCI\VEN_1022&DEV_1450&SUBSYS_14501849&REV_00\3&11583659&0&00
Location Paths PCIROOT(0)#PCI(0000)
AMD Zen - IOMMU -----------------------------------------------------------
Device Name: AMD Zen - IOMMU
Original Device Name: AMD Zen - IOMMU
Device Class: IOMMU
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:0:2
Hardware ID: PCI\VEN_1022&DEV_1451&SUBSYS_14511022&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
AMD Zen - PCIe Dummy Host Bridge ------------------------------------------
Device Name: AMD Zen - PCIe Dummy Host Bridge
Original Device Name: AMD Zen - PCIe Dummy Host Bridge
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:1:0
Hardware ID: PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&08
Location Paths PCIROOT(0)#PCI(0100)
AMD Zen - PCIe GPP Bridge -------------------------------------------------
Device Name: AMD Zen - PCIe GPP Bridge
Original Device Name: AMD Zen - PCIe GPP Bridge
Device Class: PCI-to-PCI Bridge
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:1:1
Hardware ID: PCI\VEN_1022&DEV_1453&SUBSYS_00000000&REV_00
[PCI Express]
Version: 3.0
Maximum Link Width: 4x
Current Link Width: 4x
Maximum Link Speed: 8.0 GT/s
Current Link Speed: 8.0 GT/s
Device/Port Type: Root Port of PCI Express Root Complex
Slot Implemented: Yes
Hot-Plug: Not Capable
Hot-Plug Surprise: Not Capable
Emergency Power Reduction: Not Supported
Active State Power Management (ASPM) Support: L1
Active State Power Management (ASPM) Status: Disabled
L0s Exit Latency: >4 us
L1 Exit Latency: 32 - 64 us
Maximum Payload Size Supported: 512 bytes
Maximum Payload Size: 256 bytes
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Bus Mastering: Enabled
Driver Description: PCI Express-Stammport
DeviceInstanceId PCI\VEN_1022&DEV_1453&SUBSYS_14531022&REV_00\3&11583659&0&09
Location Paths PCIROOT(0)#PCI(0101)
PCI Express x4 Bus #1 -----------------------------------------------------
Samsung Electronics SSD 960 NVMe PCIe SSD Controller ----------------------
Device Name: Samsung Electronics SSD 960 NVMe PCIe SSD Controller
Original Device Name: Samsung Electronics SSD 960 NVMe PCIe SSD Controller
Device Class: NVMe Controller
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 1:0:0
Hardware ID: PCI\VEN_144D&DEV_A804&SUBSYS_A801144D&REV_00
[PCI Express]
Version: 3.0
Device/Port Type: PCI Express Endpoint
Slot Implemented: No
Maximum Payload Size Supported: 256 bytes
[System Resources]
Interrupt Line: N/A
Interrupt Pin: INTA#
Memory Base Address 0 FD600000
[Features]
Driver Manufacturer: Samsung Electronics Co., Ltd
Driver Description: Samsung NVMe Controller
Driver Provider: Samsung Electronics Co., Ltd
Driver Version: 2.2.0.1703
Driver Date: 17-Mar-2017
DeviceInstanceId PCI\VEN_144D&DEV_A804&SUBSYS_A801144D&REV_00\4&2EEC526C&0&0009
Location Paths PCIROOT(0)#PCI(0101)#PCI(0000)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:1:3
[PCI Express]
Version: 3.0
L1 Exit Latency: 16 - 32 us
Maximum Payload Size: 128 bytes
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1453&SUBSYS_14531022&REV_00\3&11583659&0&0B
Location Paths PCIROOT(0)#PCI(0103)
PCI Express x4 Bus #3 -----------------------------------------------------
AMD 400-Series Chipset - USB Controller A ---------------------------------
Device Name: AMD 400-Series Chipset - USB Controller A
Original Device Name: AMD 400-Series Chipset - USB Controller A
Device Class: USB xHCI Controller
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 3:0:0
Hardware ID: PCI\VEN_1022&DEV_43D0&SUBSYS_43D01849&REV_01
[PCI Express]
Version: 3.0
Device/Port Type: Legacy PCI Express Endpoint
Active State Power Management (ASPM) Support: L0s and L1
L0s Exit Latency: 1 - 2 us
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FCEA0000
[Features]
Driver Manufacturer: Generischer USB-xHCI-Hostcontroller
Driver Description: USB-xHCI-kompatibler Hostcontroller
Driver Date: 10-Apr-2018
DeviceInstanceId PCI\VEN_1022&DEV_43D0&SUBSYS_43D01849&REV_01\4&288C77C7&0&000B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0000)
AMD 400-Series Chipset - SATA Controller ----------------------------------
Device Name: AMD 400-Series Chipset - SATA Controller
Original Device Name: AMD 400-Series Chipset - SATA Controller
Device Class: SATA AHCI Controller
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 3:0:1
Hardware ID: PCI\VEN_1022&DEV_43C8&SUBSYS_43C81849&REV_01
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: INTB#
Memory Base Address 5 FCEE0000
[Features]
[SATA Host Controller]
[SATA Port#0]
[SATA Port#1]
[SATA Port#2]
[SATA Port#3]
[SATA Port#4]
[SATA Port#5]
[SATA Port#6]
[SATA Port#7]
Driver Manufacturer: Standardmäßiger SATA AHCI- Controller
Driver Description: Standardmäßiger SATA AHCI- Controller
DeviceInstanceId PCI\VEN_1022&DEV_43C8&SUBSYS_43C81849&REV_01\4&288C77C7&0&010B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0001)
AMD 400-Series Chipset - PCIe Function ------------------------------------
Device Name: AMD 400-Series Chipset - PCIe Function
Original Device Name: AMD 400-Series Chipset - PCIe Function
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 3:0:2
Hardware ID: PCI\VEN_1022&DEV_43C6&SUBSYS_00000000&REV_01
[PCI Express]
Version: 3.0
Device/Port Type: Upstream Port of PCI Express Switch
[System Resources]
Interrupt Line: N/A
Interrupt Pin: INTC#
[Features]
Driver Description: Upstream-Switchport für PCI-Express
DeviceInstanceId PCI\VEN_1022&DEV_43C6&SUBSYS_43C61849&REV_01\4&288C77C7&0&020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)
PCI Express x4 Bus #29 ----------------------------------------------------
AMD 400-Series Chipset - PCIe Downstream Function -------------------------
Device Name: AMD 400-Series Chipset - PCIe Downstream Function
Original Device Name: AMD 400-Series Chipset - PCIe Downstream Function
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 29:0:0
Hardware ID: PCI\VEN_1022&DEV_43C7&SUBSYS_00000000&REV_01
[PCI Express]
Version: 2.0
Maximum Link Width: 2x
Current Link Width: 2x
Maximum Link Speed: 5.0 GT/s
Current Link Speed: 5.0 GT/s
Device/Port Type: Downstream Port of PCI Express Switch
Slot Power Limit: 26.000 W
[System Resources]
Interrupt Line: N/A
[Features]
Driver Description: Downstream-Switchport für PCI-Express
DeviceInstanceId PCI\VEN_1022&DEV_43C7&SUBSYS_43C71849&REV_01\5&331D27D3&0&00020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0000)
PCI Express x2 Bus #30 ----------------------------------------------------
ASMedia ASM2142 USB 3.1 xHCI Controller -----------------------------------
Device Name: ASMedia ASM2142 USB 3.1 xHCI Controller
Original Device Name: ASMedia ASM2142 USB 3.1 xHCI Controller
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 30:0:0
Hardware ID: PCI\VEN_1B21&DEV_2142&SUBSYS_21421B21&REV_00
[PCI Express]
Version: 3.0
L1 Exit Latency: >64 us
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FCD00000
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_2142&SUBSYS_21421B21&REV_00\6&353AA021&0&0000020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0000)#PCI(0000)
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 29:2:0
[PCI Express]
Version: 2.0
Maximum Link Width: 1x
Current Link Width: 1x
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_43C7&SUBSYS_43C71849&REV_01\5&331D27D3&0&10020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0200)
PCI Express x1 Bus #32 ----------------------------------------------------
ASMedia ASM1061 PCI-E x1 SATA 6Gbps Controller ----------------------------
Device Name: ASMedia ASM1061 PCI-E x1 SATA 6Gbps Controller
Original Device Name: ASMedia ASM1061 PCI-E x1 SATA 6Gbps Controller
Revision ID: 2
PCI Address (Bus
evice:Function) Number: 32:0:0
Hardware ID: PCI\VEN_1B21&DEV_0612&SUBSYS_06121849&REV_02
[PCI Express]
Version: 2.0
L1 Exit Latency: 1 - 2 us
[System Resources]
Interrupt Line: N/A
I/O Base Address 0 EFD8
I/O Base Address 1 EFCC
I/O Base Address 2 EFD0
I/O Base Address 3 EFC8
I/O Base Address 4 EFE0
Memory Base Address 5 FCCFFE00
[Features]
[SATA Port#0]
[SATA Port#1]
DeviceInstanceId PCI\VEN_1B21&DEV_0612&SUBSYS_06121849&REV_02\6&14CFDA8F&0&0010020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0200)#PCI(0000)
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 29:3:0
[PCI Express]
Version: 2.0
Active State Power Management (ASPM) Status: L0s Entry
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_43C7&SUBSYS_43C71849&REV_01\5&331D27D3&0&18020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)
PCI Express x1 Bus #33 ----------------------------------------------------
ASMedia ASM1184 PCI-E Switch ----------------------------------------------
Device Name: ASMedia ASM1184 PCI-E Switch
Original Device Name: ASMedia ASM1184 PCI-E Switch
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 33:0:0
Hardware ID: PCI\VEN_1B21&DEV_1184&SUBSYS_00000000&REV_00
[PCI Express]
Version: 2.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_1184&SUBSYS_11841849&REV_00\6&3B4AF5E0&0&0018020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)
PCI Express x1 Bus #38 ----------------------------------------------------
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 38:1:0
[PCI Express]
Version: 2.0
Current Link Speed: 2.5 GT/s
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_1184&SUBSYS_11841849&REV_00\7&35896FF8&0&080018020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0100)
PCI Express x1 Bus #39 ----------------------------------------------------
Intel Dual Band Wireless-AC 3168 ------------------------------------------
Device Name: Intel Dual Band Wireless-AC 3168
Original Device Name: Intel Dual Band Wireless-AC 3168
Device Class: Unknown Network Adapter
Revision ID: 10
PCI Address (Bus
evice:Function) Number: 39:0:0
Hardware ID: PCI\VEN_8086&DEV_24FB&SUBSYS_21108086&REV_10
[PCI Express]
Version: 1.1
Maximum Link Speed: 2.5 GT/s
L0s Exit Latency: 2 - 4 us
Maximum Payload Size Supported: 128 bytes
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FCBFE000
[Features]
Driver Manufacturer: Intel Corporation
Driver Description: Intel(R) Dual Band Wireless-AC 3168
Driver Version: 19.50.1.6
Driver Date: 01-Jun-2017
DeviceInstanceId PCI\VEN_8086&DEV_24FB&SUBSYS_21108086&REV_10\68ECC5FFFFC3162600
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0100)#PCI(0000)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 38:3:0
[PCI Express]
Version: 2.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_1184&SUBSYS_11841849&REV_00\7&35896FF8&0&180018020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0300)
PCI Express x1 Bus #40 ----------------------------------------------------
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 38:5:0
[PCI Express]
Version: 2.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_1184&SUBSYS_11841849&REV_00\7&35896FF8&0&280018020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0500)
PCI Express x1 Bus #42 ----------------------------------------------------
Intel I211AT Copper (Pearsonville) Network Adapter ------------------------
Device Name: Intel I211AT Copper (Pearsonville) Network Adapter
Original Device Name: Intel I211AT Copper (Pearsonville) Network Adapter
Device Class: Ethernet Adapter
Revision ID: 3
PCI Address (Bus
evice:Function) Number: 42:0:0
Hardware ID: PCI\VEN_8086&DEV_1539&SUBSYS_15391849&REV_03
[PCI Express]
Version: 1.1
L1 Exit Latency: 8 - 16 us
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FCAE0000
I/O Base Address 2 0
Memory Base Address 3 FCADC000
[Features]
Driver Description: Intel(R) I211 Gigabit Network Connection
Driver Provider: Intel
Driver Version: 12.15.184.0
Driver Date: 08-Dec-2016
DeviceInstanceId PCI\VEN_8086&DEV_1539&SUBSYS_15391849&REV_03\7085C2FFFF8253EA00
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0500)#PCI(0000)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 38:7:0
[PCI Express]
Version: 2.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1B21&DEV_1184&SUBSYS_11841849&REV_00\7&35896FF8&0&380018020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0300)#PCI(0000)#PCI(0700)
PCI Express x1 Bus #43 ----------------------------------------------------
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 29:4:0
[PCI Express]
Version: 2.0
Current Link Width: Not negotiated
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_43C7&SUBSYS_43C71849&REV_01\5&331D27D3&0&20020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0400)
PCI Express x4 Bus #44 ----------------------------------------------------
Revision ID: 1
PCI Address (Bus
evice:Function) Number: 29:9:0
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_43C7&SUBSYS_33061B21&REV_01\5&331D27D3&0&48020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0900)
PCI Express x2 Bus #45 ----------------------------------------------------
Aquantia AQtion AQC107 10Gbit Network Adapter -----------------------------
Device Name: Aquantia AQtion AQC107 10Gbit Network Adapter
Original Device Name: Aquantia AQtion AQC107 10Gbit Network Adapter
Revision ID: 2
PCI Address (Bus
evice:Function) Number: 45:0:0
Hardware ID: PCI\VEN_1D6A&DEV_D107&SUBSYS_D1071849&REV_02
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FC8F0000
Memory Base Address 2 FC8EF000
Memory Base Address 4 FC400000
[Features]
Driver Manufacturer: Aquantia
Driver Description: Aquantia AQtion 10Gbit Network Adapter (NDIS 6.50 Miniport)
Driver Provider: Aquantia
Driver Version: 1.42.33.0
Driver Date: 23-Oct-2017
DeviceInstanceId PCI\VEN_1D6A&DEV_D107&SUBSYS_D1071849&REV_02\6&19C17EFF&0&0048020B
Location Paths PCIROOT(0)#PCI(0103)#PCI(0002)#PCI(0900)#PCI(0000)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:2:0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&10
Location Paths PCIROOT(0)#PCI(0200)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:3:0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&18
Location Paths PCIROOT(0)#PCI(0300)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:3:1
[PCI Express]
Version: 3.0
Maximum Link Width: 16x
Current Link Width: 16x
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1453&SUBSYS_14531022&REV_00\3&11583659&0&19
Location Paths PCIROOT(0)#PCI(0301)
PCI Express x16 Bus #46 ---------------------------------------------------
AMD Vega10 - Switch Upstream in PCIe --------------------------------------
Device Name: AMD Vega10 - Switch Upstream in PCIe
Original Device Name: AMD Vega10 - Switch Upstream in PCIe
Revision ID: C3
PCI Address (Bus
evice:Function) Number: 46:0:0
Hardware ID: PCI\VEN_1022&DEV_1470&SUBSYS_00000000&REV_C3
[PCI Express]
Version: 3.0
L0s Exit Latency: 256 - 512 ns
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FD400000
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1470&SUBSYS_00000000&REV_C3\4&1C3D25BB&0&0019
Location Paths PCIROOT(0)#PCI(0301)#PCI(0000)
PCI Express x16 Bus #47 ---------------------------------------------------
AMD Vega10 - Switch Downstream in NBIF ------------------------------------
Device Name: AMD Vega10 - Switch Downstream in NBIF
Original Device Name: AMD Vega10 - Switch Downstream in NBIF
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 47:0:0
Hardware ID: PCI\VEN_1022&DEV_1471&SUBSYS_00000000&REV_00
[PCI Express]
Version: 3.0
L0s Exit Latency: < 64 ns
L1 Exit Latency: < 1 us
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1471&SUBSYS_14711022&REV_00\5&14DB8B86&0&000019
Location Paths PCIROOT(0)#PCI(0301)#PCI(0000)#PCI(0000)
PCI Express x16 Bus #48 ---------------------------------------------------
AMD Radeon RX Vega 56 -----------------------------------------------------
Device Name: AMD Radeon RX Vega 56
Original Device Name: ATI/AMD Radeon RX Vega 56 (Vega 10 XL)
Device Class: VGA Compatible Adapter
Revision ID: C3
PCI Address (Bus
evice:Function) Number: 48:0:0
Hardware ID: PCI\VEN_1002&DEV_687F&SUBSYS_6B761002&REV_C3
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 E0000000
Memory Base Address 2 F0000000
I/O Base Address 4 FF00
Memory Base Address 5 FD300000
[Features]
Driver Manufacturer: Advanced Micro Devices, Inc.
Driver Description: Radeon RX Vega
Driver Provider: Advanced Micro Devices, Inc.
Driver Version: 24.20.11001.5003 (Radeon Software Adrenalin Edition 18.4.1)
Driver Date: 25-Apr-2018
DeviceInstanceId PCI\VEN_1002&DEV_687F&SUBSYS_6B761002&REV_C3\6&2CBC9480&0&00000019
Location Paths PCIROOT(0)#PCI(0301)#PCI(0000)#PCI(0000)#PCI(0000)
ATI/AMD Vega - High Definition Audio Controller ---------------------------
Device Name: ATI/AMD Vega - High Definition Audio Controller
Original Device Name: ATI/AMD Vega - High Definition Audio Controller
Device Class: Mixed mode device
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 48:0:1
Hardware ID: PCI\VEN_1002&DEV_AAF8&SUBSYS_AAF81002&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: IRQ55
Memory Base Address 0 FD3FC000
[Features]
Driver Manufacturer: Microsoft
Driver Description: High Definition Audio-Controller
Driver Date: 11-Apr-2018
DeviceInstanceId PCI\VEN_1002&DEV_AAF8&SUBSYS_AAF81002&REV_00\6&2CBC9480&0&01000019
Location Paths PCIROOT(0)#PCI(0301)#PCI(0000)#PCI(0000)#PCI(0001)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:4:0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&20
Location Paths PCIROOT(0)#PCI(0400)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:7:0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&38
Location Paths PCIROOT(0)#PCI(0700)
AMD Zen - Internal PCIe GPP Bridge 0 to Bus B/C ---------------------------
Device Name: AMD Zen - Internal PCIe GPP Bridge 0 to Bus B/C
Original Device Name: AMD Zen - Internal PCIe GPP Bridge 0 to Bus B/C
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:7:1
Hardware ID: PCI\VEN_1022&DEV_1454&SUBSYS_00000000&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1454&SUBSYS_14541022&REV_00\3&11583659&0&39
Location Paths PCIROOT(0)#PCI(0701)
PCI Express x16 Bus #49 ---------------------------------------------------
AMD Zen - PCIe Dummy Function ---------------------------------------------
Device Name: AMD Zen - PCIe Dummy Function
Original Device Name: AMD Zen - PCIe Dummy Function
Device Class: Non-Essential Instrumentation Function
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 49:0:0
Hardware ID: PCI\VEN_1022&DEV_145A&SUBSYS_145A1022&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Driver Description: AMD PCI
Driver Version: 1.0.0.55
Driver Date: 12-Apr-2018
DeviceInstanceId PCI\VEN_1022&DEV_145A&SUBSYS_145A1022&REV_00\4&C93BEE2&0&0039
Location Paths PCIROOT(0)#PCI(0701)#PCI(0000)
AMD Zen - Cryptographic Coprocessor PSPCPP --------------------------------
Device Name: AMD Zen - Cryptographic Coprocessor PSPCPP
Original Device Name: AMD Zen - Cryptographic Coprocessor PSPCPP
Device Class: Unknown En/Decryption
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 49:0:2
Hardware ID: PCI\VEN_1022&DEV_1456&SUBSYS_14561022&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 2 FD200000
Memory Base Address 5 FD1FE000
[Features]
Driver Manufacturer: Advanced Micro Devices Inc.
Driver Description: AMD PSP 3.0 Device
Driver Provider: Advanced Micro Devices Inc.
Driver Version: 4.5.0.0
Driver Date: 27-Oct-2017
DeviceInstanceId PCI\VEN_1022&DEV_1456&SUBSYS_14561022&REV_00\4&C93BEE2&0&0239
Location Paths PCIROOT(0)#PCI(0701)#PCI(0002)
AMD Zen - Reserved --------------------------------------------------------
Device Name: AMD Zen - Reserved
Original Device Name: AMD Zen - Reserved
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 49:0:3
Hardware ID: PCI\VEN_1022&DEV_145F&SUBSYS_79141849&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FD000000
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_145F&SUBSYS_79141849&REV_00\4&C93BEE2&0&0339
Location Paths PCIROOT(0)#PCI(0701)#PCI(0003)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:8:0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1452&SUBSYS_00000000&REV_00\3&11583659&0&40
Location Paths PCIROOT(0)#PCI(0800)
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:8:1
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1454&SUBSYS_14541022&REV_00\3&11583659&0&41
Location Paths PCIROOT(0)#PCI(0801)
PCI Express x16 Bus #50 ---------------------------------------------------
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 50:0:0
Hardware ID: PCI\VEN_1022&DEV_1455&SUBSYS_14551022&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1455&SUBSYS_14551022&REV_00\4&2B9CC193&0&0041
Location Paths PCIROOT(0)#PCI(0801)#PCI(0000)
AMD Carrizo FCH - SATA AHCI Controller (MS) -------------------------------
Device Name: AMD Carrizo FCH - SATA AHCI Controller (MS)
Original Device Name: AMD Carrizo FCH - SATA AHCI Controller (MS)
Revision ID: 51
PCI Address (Bus
evice:Function) Number: 50:0:2
Hardware ID: PCI\VEN_1022&DEV_7901&SUBSYS_79011849&REV_51
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 5 FD5FF000
[Features]
[SATA Port#0]
DeviceInstanceId PCI\VEN_1022&DEV_7901&SUBSYS_79011849&REV_51\4&2B9CC193&0&0241
Location Paths PCIROOT(0)#PCI(0801)#PCI(0002)
AMD Zen - HD Audio Controller ---------------------------------------------
Device Name: AMD Zen - HD Audio Controller
Original Device Name: AMD Zen - HD Audio Controller
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 50:0:3
Hardware ID: PCI\VEN_1022&DEV_1457&SUBSYS_22211849&REV_00
[PCI Express]
Version: 3.0
[System Resources]
Interrupt Line: IRQ43
Memory Base Address 0 FD5F0000
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1457&SUBSYS_22211849&REV_00\4&2B9CC193&0&0341
Location Paths PCIROOT(0)#PCI(0801)#PCI(0003)
AMD Carrizo FCH - SMBus and ACPI Controller -------------------------------
Device Name: AMD Carrizo FCH - SMBus and ACPI Controller
Original Device Name: AMD Carrizo FCH - SMBus and ACPI Controller
Device Class: SMBus (System Management Bus)
Revision ID: 59
PCI Address (Bus
evice:Function) Number: 0:20:0
Hardware ID: PCI\VEN_1022&DEV_790B&SUBSYS_790B1849&REV_59
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Running At 66 MHz: Capable
Driver Description: AMD SMBus
Driver Version: 5.12.0.38
Driver Date: 10-Oct-2017
DeviceInstanceId PCI\VEN_1022&DEV_790B&SUBSYS_790B1849&REV_59\3&11583659&0&A0
Location Paths PCIROOT(0)#PCI(1400)
AMD Carrizo FCH - LPC Bridge ----------------------------------------------
Device Name: AMD Carrizo FCH - LPC Bridge
Original Device Name: AMD Carrizo FCH - LPC Bridge
Device Class: PCI-to-ISA Bridge
Revision ID: 51
PCI Address (Bus
evice:Function) Number: 0:20:3
Hardware ID: PCI\VEN_1022&DEV_790E&SUBSYS_790E1849&REV_51
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Driver Description: PCI Standard-ISA-Brücke
DeviceInstanceId PCI\VEN_1022&DEV_790E&SUBSYS_790E1849&REV_51\3&11583659&0&A3
Location Paths PCIROOT(0)#PCI(1403)
AMD Zen - Data Fabric: Function 0 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 0
Original Device Name: AMD Zen - Data Fabric: Function 0
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:0
Hardware ID: PCI\VEN_1022&DEV_1460&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1460&SUBSYS_00000000&REV_00\3&11583659&0&C0
Location Paths PCIROOT(0)#PCI(1800)
AMD Zen - Data Fabric: Function 1 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 1
Original Device Name: AMD Zen - Data Fabric: Function 1
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:1
Hardware ID: PCI\VEN_1022&DEV_1461&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1461&SUBSYS_00000000&REV_00\3&11583659&0&C1
Location Paths PCIROOT(0)#PCI(1801)
AMD Zen - Data Fabric: Function 2 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 2
Original Device Name: AMD Zen - Data Fabric: Function 2
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:2
Hardware ID: PCI\VEN_1022&DEV_1462&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1462&SUBSYS_00000000&REV_00\3&11583659&0&C2
Location Paths PCIROOT(0)#PCI(1802)
AMD Zen - Data Fabric: Function 3 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 3
Original Device Name: AMD Zen - Data Fabric: Function 3
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:3
Hardware ID: PCI\VEN_1022&DEV_1463&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1463&SUBSYS_00000000&REV_00\3&11583659&0&C3
Location Paths PCIROOT(0)#PCI(1803)
AMD Zen - Data Fabric: Function 4 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 4
Original Device Name: AMD Zen - Data Fabric: Function 4
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:4
Hardware ID: PCI\VEN_1022&DEV_1464&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1464&SUBSYS_00000000&REV_00\3&11583659&0&C4
Location Paths PCIROOT(0)#PCI(1804)
AMD Zen - Data Fabric: Function 5 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 5
Original Device Name: AMD Zen - Data Fabric: Function 5
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:5
Hardware ID: PCI\VEN_1022&DEV_1465&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1465&SUBSYS_00000000&REV_00\3&11583659&0&C5
Location Paths PCIROOT(0)#PCI(1805)
AMD Zen - Data Fabric: Function 6 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 6
Original Device Name: AMD Zen - Data Fabric: Function 6
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:6
Hardware ID: PCI\VEN_1022&DEV_1466&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1466&SUBSYS_00000000&REV_00\3&11583659&0&C6
Location Paths PCIROOT(0)#PCI(1806)
AMD Zen - Data Fabric: Function 7 -----------------------------------------
Device Name: AMD Zen - Data Fabric: Function 7
Original Device Name: AMD Zen - Data Fabric: Function 7
Revision ID: 0
PCI Address (Bus
evice:Function) Number: 0:24:7
Hardware ID: PCI\VEN_1022&DEV_1467&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1467&SUBSYS_00000000&REV_00\3&11583659&0&C7
Location Paths PCIROOT(0)#PCI(1807)
